Screwed - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-02-2013, 07:57 PM   #11
adam6976
adam6976's Avatar
Fan#: 108265
What I Drive: 2002 white se
FF Reputation: 1 adam6976 Good Standing Member
just weld the mount to the top of the bolt with nice spot weld . An you ever have to take it out agin you'd have to grind ott th spot weld. Good luck on what ever u deside .
adam6976 is offline
Old 03-02-2013, 08:04 PM   #12
anarchy0392
Fan#: 102873
What I Drive: 2002, Silver, SE
Points 1,634, Level 23
Points: 1,634, Level: 23 Points: 1,634, Level: 23 Points: 1,634, Level: 23
Level Up 34% Completed
FF Reputation: 2 anarchy0392 Good Standing Member
Buy-Sell-Trade Rating: (9)
Well thank for all the advice I'd like to do this but I dont know how to weld nor do I have a welder yet. Which is why I took it to a shop.
anarchy0392 is offline
Old 03-02-2013, 08:13 PM   #13
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
That's precisely what left handed cobalt drill bits were made for.
The shop you to sounds like the lube monkeys got access to tools while nobody was looking.
Definitely remove the mount to get access, and so it isn't pushing on the remnant and helping hold it in place.
Absolute, worse case scenario:
Grind it flat, have a piece of flat bar stock welded to the mount to make it wider footprint, and it gets a new bolt hole and threadsert into the unibody/frame.
elsolo is offline
Old 03-02-2013, 08:23 PM   #14
Elder
Points 13,412, Level 75
Points: 13,412, Level: 75 Points: 13,412, Level: 75 Points: 13,412, Level: 75
Level Up 41% Completed
Drill will work, but you'll need to get things out of the way for access. Grinding the top flat will let you center punch & drill easier, as well as removing the surface that the welding attempts may have hardened.
It'll take time, but if you work up in sizes to avoid taking out the threads you'll eventually be able to pick out the last half moon shaped piece of bolt that's usually left because the drilling is seldom exactly centered.
If a tap isn't available, a spare bolt of the same size with slots cut lengthwise in the threads makes a good one use thread chaser to clean out the welded in nut.
To avoid rushing it & getting frustrated, remember what you said about this job being worth the whole car! Take breaks with your beverage of choice (grin) and it'll be done before you know it!
Luck!
P.S. - hah! we're all typing at once again...
sailor is offline
Old 03-02-2013, 08:26 PM   #15
my_beautious_ZX3
Fan#: 32386
Points 1,374, Level 20
Level Up 74% Completed
that's not a bad idea. A 13-year old Focus ain't gonna outlive new motor mounts.
my_beautious_ZX3 is offline
Old 03-02-2013, 08:37 PM   #16
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,705, Level 94
Points: 23,705, Level: 94 Points: 23,705, Level: 94 Points: 23,705, Level: 94
Level Up 36% Completed
Forum Activity 17%
interesting bit on the stainless welding.
Yeah I don't know how they keep breaking drill bits. You can drill the length of the bolt, and keep opening it up if all else fails. it should collapse in on itself.
mikebontoft is online now
Old 03-03-2013, 12:38 AM   #17
whimsicalpouch2
Fan#: 87978
What I Drive: 2002, black SVT focus
Points 4,736, Level 43
Points: 4,736, Level: 43 Points: 4,736, Level: 43 Points: 4,736, Level: 43
Level Up 93% Completed
FF Reputation: 4 whimsicalpouch2 Good Standing Member
that was the same bolt that i thought i broke when i did my engine mounts 2 weeks ago. scariest pop ever trying to get that off with a breaker bar. too bad i didn't put any anti seize on it before putting back in ahhah
Most Excellence!
#586 of #4788
whimsicalpouch2 is offline
Old 03-03-2013, 03:33 AM   #18
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 2 tmittelstaedt Good Standing Member
I used to drill holes in a machine shop years ago.
You need the right drill bits and they need to be sharp, and they will get very dull very quick if you don't use cutting oil to lube the bit.
Carbite tip (colbalt will likely NOT work very well) and cutting oil (not motor oil, get cutting oil) and a slow speed to start followed by moderate speed, that will cut through it. Even if the top was hardened by welding. have an assistant continue to drip cutting oil on it while you drill.
tmittelstaedt is offline
Old 03-03-2013, 03:35 AM   #19
tmittelstaedt
Fan#: 108093
Points 233, Level 4
One other hint - almost always when you drill these it's impossible to get the hole in dead center.
What you do is get the hole started then use a diamond tip bit on a Dremel to widen the hole in the direction it needs to go to center.
Old 03-03-2013, 08:30 AM   #20
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,748, Level 78
Points: 14,748, Level: 78 Points: 14,748, Level: 78 Points: 14,748, Level: 78
Level Up 75% Completed
Forum Activity 12%
FF Reputation: 90 goinloco1 Excellent Standing Member
and why has no one mentioned pulling the fender liner to get at it from the bottom side.
goinloco1 is online now
