Leak from SPI Intake Manifold - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus First Generation > SPI Performance (2000-2004)
Old 07-15-2012, 10:20 PM   #1
tp4pdb
Fan#: 94593
What I Drive: 2000 Blue Wagon
FF Reputation: 1 tp4pdb Good Standing Member
I am in the process of completing a rebuild of a 2000 2.0 SPI. When I added coolant it leaked from the top and bottom of the intake manifold, mostly between cylinders 2 and 3. I pulled the throttle body and also observed coolant entering the bottom of the manifold plenum from the left side.
Am I looking forward to pulling the intake manifold off and having a look, or am I missing something simpler to fix? Or is it something worse?
Paul-West LA
tp4pdb is offline
Old 07-22-2012, 11:32 AM   #2
Condor945
Fan#: 100774
What I Drive: 2001 Focus SE 2.0 SOHC
FF Reputation: 1 Condor945 Good Standing Member
Paul-
Just curious what you found... I'm actually I'm the same boat as you presently...
Todd
Condor945 is offline
Old 07-23-2012, 10:53 AM   #3
tp4pdb
Fan#: 94593
Waiting for a pressure tester adapter to be delivered that I ordered last week. Intend to pressure up the cooling system to better pinpoint leak source. Also will be cracking pan plug to see if coolant ended up in oil.
Possible causes of leak are guesses at the moment. Some of those include flipped head gasket, wrong head gasket or cracked intake manifold.
Is it reasonable to assume that new head bolts can't be used again once they have been installed?
Paul - West LA
tp4pdb is offline
Old 07-23-2012, 08:31 PM   #4
Condor945
Fan#: 100774
Yeah... I wouldn't reuse the head bolts. There a one time use because of how there made/designed.
Old 07-23-2012, 08:41 PM   #5
mikebontoft
Toxx
mikebontoft's Avatar
Fan#: 58647
unfortunately they are torque to yield...
coolant does route through the throttle body, but obviously not within the intake itself.
wow and I junked a perfectly good manifold thinking no one would ever need one.
make sure you didn't hook up. coolant line to a vacuum lone on the manifold though.
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parting) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-sold) | '75 BMW 2002 "Carby" (resto-mod racecar) | '75 BMW 2002 (donor -sold) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (alt. daily).
Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics
mikebontoft is online now
Old 08-06-2012, 05:13 PM   #6
tp4pdb
Fan#: 94593
Problem Solved
It turns out that I apparently installed the two intake manifold gaskets in the wrong order. I guess I wasn't paying enough attention when I took the thing apart a couple of months ago. I then removed the intake manifold (which required a lot more work than the Ford workshop manual indicated), installed the new gaskets in the right order, put it all back together, added water and then pressure tested the cooling system. No leaks.
So far so good.
Paul B-West LA
tp4pdb is offline
Old 03-01-2013, 01:05 PM   #7
danny42984
Fan#: 110560
What I Drive: 2001 maroon focus
FF Reputation: 1 danny42984 Good Standing Member
So far so good.
Paul B-West LA
could you share the right order for the gaskets? im unsure what order they go in. there are four gaskets in my set. thanks
danny42984 is offline
Old 04-10-2013, 10:05 PM   #8
jguzman75
Fan#: 88518
What I Drive: 2002 Silver SE
FF Reputation: 1 jguzman75 Good Standing Member
I also finished a top end rebuild on my 2.0 before it dropped a valve seat. After running it for a few weeks I noticed coolant between cylinder 2-3 on the intake side of the intake gasket. I noticed that when it is hot I can see coolant bubble up in the valley of the bolt that cannot be pulled out with the throttle body on the car. Hope that makes sense.
I think that bolt needs some kind of thread sealer on the threads because it may thread into a water jacket.
Does anyone know?
jguzman75 is offline
