Clutch Kit for 2.3L - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-27-2013, 12:36 AM   #1
sneblue
sneblue's Avatar
Fan#: 88919
What I Drive: 2003 Zinc Yellow ZX3 2.3L
FF Reputation: 1 sneblue Good Standing Member
Clutch Kit for 2.3L
Hi Folks,
It's time to replace my clutch... Tough to start more often (pump that pedal!), slipping with high RPM on the big hills, and also on the flats here & there.
It has a "sport" clutch, but I have no idea what's in there. I bought the car after it was repo, so I don't have any records. It has 97k give or take a little.
That said, I have immensely enjoyed whatever is in there. engages right off the floor, grabs hard, takes a beating, fantastic launches. ridiculously fun.
I'm a bit concerned I might pick out a kit that's not as nice....
I can't be without it for a long time, it's my daily driver. So taking it apart checking the ruins & then ordering new stuff won't work...
From what I've been reading in other threads it seems like most have been happier with the Exedy over the Clutch Master brand. Not sure if I should go stage 1 or stage 2. I doubt I will ever do a turbo, but I might do Cosworth headers some time down the road if the opportunity presents itself.
With the 151hp and whatever the Cosworth CAI is bringing to the party, and fantastic poly mounts holding it all together, what do you all think?
I'm interested in opinions & experiences... thanks as always!
sneblue is offline
Old 02-27-2013, 07:08 AM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,926, Level 74
Points: 12,926, Level: 74 Points: 12,926, Level: 74 Points: 12,926, Level: 74
Level Up 19% Completed
I like the Exedy clutch kit my self. The stage 1 will be plenty good. Make sure to get a slave cylinder also. I like the forged aluminum pressure plate cover on the hyper stage 3 instead of stamped steel & has a ceramic 6 puck disc. Thats overkill. With the emmissions down there can you run a header? I thought they check stuff like that.
felixthecat is online now
Old 02-27-2013, 09:24 AM   #3
sneblue
sneblue's Avatar
Fan#: 88919
Hi Felix-
Yes I would like that Hyper too - a little excessive on the cash right now though. I have to do a bunch of other maintenance right now, probably going to spend around $3500. I have a potentially ripped up sync ring, been there the whole time I've had the car so that should be nice and pricey.
I struggled with it, should I buy a different car, exit gracefully? Nope. I couldn't find anything else as fun that I could afford right now. so we're fixin' it. I guess I will keep the ZX3 around, should complement the yello Lotus eventually, right?
that said, yeah they probably check the headers, but I thought Cosworth had some California passes. I know their CAI is the only one for the CARB. I will have to look it up on the emissions board list of ok stuff...
thanks for your thoughts,
Shannon
sneblue is offline
Old 02-27-2013, 07:58 PM   #4
felixthecat
w/ my magic bag
Fan#: 80663
For a fairley stock motor Exdy oem kit would work great. Just add a slave cylinder to the order. Gets rid of the dual mass flywheel & comes w/ a chrome moly flywheel. No car payments= more mods=.
Old 02-27-2013, 09:52 PM   #5
SYZ
FocusFreak
SYZ's Avatar
Fan#: 31122
What I Drive: toxic waste
Points 8,010, Level 60
Points: 8,010, Level: 60 Points: 8,010, Level: 60 Points: 8,010, Level: 60
Level Up 30% Completed
FF Reputation: 106 SYZ Excellent Standing Member SYZ Excellent Standing Member
Buy-Sell-Trade Rating: (14)
Cosworth headers are not CARB certified. Only their CAI is for 2003-2004 Focuses. Furthermore, you will likely trigger a CEL because of the missing catalytic converter. You can run a tune or do the mechanical CEL fix to eliminate it, but you will fail visual inspection regardless.
I also suggest the Exedy stage 1 based upon your needs. The hyper single is way overkill.
2003 Ford Escape 4x4 Limited
On Order: 2015 Porsche Cayman S
SYZ is offline
Old 02-27-2013, 10:41 PM   #6
Budderybunz
Budderybunz's Avatar
Fan#: 107821
What I Drive: 2004 SVT Turbo
FF Reputation: 1 Budderybunz Good Standing Member
I'm stage 2 turbo and I really like my exedy oem clutch kit! It takes 232 whp 240wtq daily.
2004 Screaming Yellow SVT Turbo
Budderybunz is offline
Old 02-28-2013, 09:39 AM   #7
sneblue
sneblue's Avatar
Fan#: 88919
I hadn't really put any time into the header question, thanks for the input.
And yeah, I am well aware there is not any viable reason I "need" the Hyper - but it sure doesn't stop me from wanting it anyway But, I'm not going to do it, just nice to look at it...
I have had the car for 6 years, I got the CAI in 2011 after smog tests tightened up on the visuals here and they busted me on a SRI consisting of the stock MAF tube with a K&N on the end. The car came that way & I didn't have the stock box. (I do now, thanks to a kind soul on this board, good to have the stock back up) I feel lucky to be a 2003 so I could have the Cosworth & pass
Interesting that the Exedy OEM seems to be well liked... it is certainly a lower price point. But I'm not sure that's a deciding factor for me... I really drive hard, oil in the blood & lead in the foot, 2nd daughter no sons, with a gearhead dad... I want that instant grab. sprints are all we get around here, no straightaways for top end speed...
again, thanks for everyone's opinions! keep 'em coming!
sneblue is offline
Old 02-28-2013, 10:02 AM   #8
felixthecat
w/ my magic bag
Fan#: 80663
Your car is fairley stock, So the Exdy oem replacement would be a great upgrade for you. It does get rid of the factory dual mass flywheel= a lighter chrome moly flywheel. That will last a long time. Put the $ difference into a steeda sts= short throw shifter & a tune. If you want a cheap motor mod= do a bsd= balance shaft delete plug. Remove the balance shafts & plug the oil feed hole. Removes 18 lbs of dead weight & less rotating weight & you'll find your motor holds 6qtrs of oil now. Win win.
