Small clunk when diving from a stop - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus ST > Focus ST
Focus ST The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK3 2013-Current Focus ST.
Old 02-19-2013, 03:34 PM   #1
aernan
Fan#: 105907
What I Drive: 2013 performance blue ST3
FF Reputation: 2 aernan Good Standing Member
Recently I noticed a repeatable small clunk noise from the front left engine area. The car does not always make the sound. When it does I can disengage the clutch and re engage three clutch and it makes the sound again.
I suspect it may be an engine mount. Is it possible to inspect the mounts without removing the bottom skid plate?
aernan is offline
Old 02-19-2013, 07:19 PM   #2
StingRay
StingRay's Avatar
Fan#: 67421
What I Drive: 2014 Tuxedo Black SE Sport
Points 1,765, Level 24
Points: 1,765, Level: 24 Points: 1,765, Level: 24 Points: 1,765, Level: 24
Level Up 65% Completed
Forum Activity 43%
Activity: 43% Activity: 43% Activity: 43%
FF Reputation: 5 StingRay Good Standing Member
Lower rear engine mount is notoriously weak. Most peoples recommended first mod is to replace it with a stronger aftermarket unit. There should be a thread about it around here somewhere...
StingRay is online now
Old 02-19-2013, 07:21 PM   #3
StingRay
StingRay's Avatar
Fan#: 67421
Forum Activity 43%
I can't find an ST specific thread, but the mount is the same in the base models anyway so it doesn't matter. this thread has some good info on the mounts; http://www.focusfanatics.com/forum/showthread.php?t=287381
Old 02-19-2013, 09:01 PM   #4
aernan
Fan#: 105907
somewhere down that long thread it got hijacked. There is some talk about the engine smacking the firewall on hard takeoff (drag racing). I am accelerating quite slowly. I would only expect noise if one of the mounts had torn badly. It looks like you need to get the car up on a lift and remove the skid plate to inspect that portion of the car. I only have a driveway/garage to work in. It's snowing right now so I'm not going to climb under today.
Does anyone have any other ideas what it might be?
aernan is offline
Old 02-24-2013, 09:50 AM   #5
rohmbd
Fan#: 102877
What I Drive: 2009 Fit Sport
FF Reputation: 1 rohmbd Good Standing Member
Spray some WD40/lithium grease on the Airbox 3 rubber mounting points. Stopped my noise. Check it first by moving your air box around. Had the noise for months, took 5 minutes to make it go away.
rohmbd is offline
Old 02-27-2013, 01:09 AM   #6
Burns098356GX
Burns098356GX's Avatar
Fan#: 94777
What I Drive: 2013 Focus ST
Points 1,136, Level 18
Points: 1,136, Level: 18 Points: 1,136, Level: 18 Points: 1,136, Level: 18
Level Up 36% Completed
FF Reputation: 1 Burns098356GX Good Standing Member
I recently had a similar problem on my SEL, also in the left front. Turned out it was the grommet between the airbox and the hose leading from it. It'd make a clunky noise if I stopped quick, went over a curb or sewer cover. I put some silicon goop around it and its resolved.
Might want to check that.
Sent from my HTC-Z710a using FF Mobile
Burns098356GX is offline
Old 02-27-2013, 12:07 PM   #7
aernan
Fan#: 105907
that's good advice. When I get a chance I'll give it a try.
aernan is offline
