A $20 Short Ram - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-25-2013, 07:01 PM   #1
BWM2006ZX3
BWM2006ZX3's Avatar
Fan#: 89475
What I Drive: 2006 Yellow ZX3
Points 1,808, Level 25
Points: 1,808, Level: 25 Points: 1,808, Level: 25 Points: 1,808, Level: 25
Level Up 8% Completed
FF Reputation: 2 BWM2006ZX3 Good Standing Member
Lightbulb A $20 Short Ram
Hey guys whats up?
I've been getting a decent amount of questions asking how to do a short ram as seen in the first picture below. I AM NOT LIABLE FOR ANYTHING YOU DO TO YOUR CAR!
AEM Filter
K&N Filter
Spectre Filter
I recommend using a Specter Air Filter as pictured because of the ease of fit with the stock parts. The stock piece i will be showing you has a 3.25" opening. Just the size of the opening on the filter.
It is finally time that i take the time and sit down to write up exactly what i had done.
*NOTE! IN ORDER FOR YOU TO DO THIS YOU WILL NEED TO HAVE YOUR STOCK INTAKE ALREADY REMOVED*
1.Remove the stock lifetime filter by undoing the two bolts and loosen the pipe clamp holding the rubber cover over the throttle body.
2.Remove the pipe from the ACTUAL AIR FILTER BOX! Image below for the piece i am talking about.
3.Remove your MAF sensor before Proceeding to step 4!
4.Place the tube with the throttle body housing away from you and on the left. Cut the tube on the RIGHT side of the RIGHT ridge.
5.Take a filter with a 3.25" opening and insert the tube in the filter as pictured below.
6.Place and tighten the MAF sensor back into the tube and insert the cut end into the throttle body opening as shown.
*DO NOT FORGET TO PLUG THE MAF SENSOR BACK IN*
7.The tube may fit loose but hold it in place and tighten it until it is like the picture below.
*ONLY INSERT THE TUBE UNTIL THE RIDGE AS PICTURED ABOVE!*
8.Start your car and drive "around the block" making sure you have even acceleration and have no jerking around.
(At first i had inserted the tube in the opposite direction and the MAF sensor was reading negative values. This caused the car to lurk and the pedal be planted to the floor and me not move an inch while in drive)
9.Enjoy driving around hearing your cone filter!
Please let me know if you have any suggestion or something you would like me to add or if there is anything that more explaining!
Thanks!
2006ZX3Skittle
RallyRevolution:#23
AVIDRallier
3”Magnaflow - Focus Rally BLACK EAPS FRPP
Originally Posted by UnbridledCarnage View Post
drop it on its nuts asap
BWM2006ZX3 is offline
Old 02-25-2013, 07:57 PM   #2
leh0825
[:)][:)][:)][:)] I got this!!!!
leh0825's Avatar
Fan#: 63206
What I Drive: 04 F250 FX4 6.0L
FF Reputation: 8 leh0825 Good Standing Member
nice write up... .looks decent too!
Team Duratec #220/Sedan Revolution #179/NW Posse#5
Originally Posted by jmiller_1974 View Post
Geesh. I mean I know it's just a Focus to the repair shop, but they couldn't give You something other than a rolling vagina to drive?
leh0825 is offline
Old 02-25-2013, 08:53 PM   #3
Drumr90
Drumr90's Avatar
Fan#: 99659
What I Drive: 2006 Black ZX5 auto
Points 3,816, Level 39
Points: 3,816, Level: 39 Points: 3,816, Level: 39 Points: 3,816, Level: 39
Level Up 11% Completed
FF Reputation: 3 Drumr90 Good Standing Member
Thanks man ill pas it on
Ive been bleeding ford blue since birth.
CO2 is nutrition not a polluitant ask a tree.
Hatch nation #03
Rally revolution #06 [HOONIGAN]
Team Duratec #30
Drumr90 is offline
Old 02-25-2013, 09:02 PM   #4
BWM2006ZX3
BWM2006ZX3's Avatar
Fan#: 89475
I believe i gained 2-4 hwy mpgs when driving normal.
thanks guys!
2006ZX3Skittle
RallyRevolution:#23
AVIDRallier
Old 02-25-2013, 09:20 PM   #5
sk8salomon
sk8salomon's Avatar
Fan#: 86112
What I Drive: '02 SE Wagon
FF Reputation: 1 sk8salomon Good Standing Member
wow, interesting and easy mod. thanks for the input. i guess i need to check if this will work on a zetec?
sk8salomon is offline
Old 02-25-2013, 09:44 PM   #6
BWM2006ZX3
BWM2006ZX3's Avatar
Fan#: 89475
There is a way i believe... ive just never had a zetec so i dont know.
2006ZX3Skittle
RallyRevolution:#23
AVIDRallier
Old 02-26-2013, 02:54 AM   #7
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,723, Level 94
Points: 23,723, Level: 94 Points: 23,723, Level: 94 Points: 23,723, Level: 94
Level Up 38% Completed
Forum Activity 13%
Nice. it's just as effective as a $200 or more SRI. pretty much done it to every car I've owned. The spi doesnt make any intake noise though. Not like the zetec and I'm sure the duratec.
For the zetec/spi it's even easier. Just unbolt the airbox from the tube and clamp on the filter.
mikebontoft is online now
Old 02-26-2013, 09:19 AM   #8
WiscoGTI
Turböner
WiscoGTI's Avatar
Fan#: 70225
What I Drive: 2002 VW GTI
Points 162,986, Level 100
Points: 162,986, Level: 100 Points: 162,986, Level: 100 Points: 162,986, Level: 100
FF Reputation: 33 WiscoGTI Great Standing Member
Buy-Sell-Trade Rating: (9)
Definitely more of a hack, IMO. But at least it looks cleanish. Nowhere near as good as a true SRI or CAI would look though.
Sent from my Man Cannon via FF Mobile
WiscoGTI is offline
Old 02-26-2013, 08:21 PM   #9
BWM2006ZX3
BWM2006ZX3's Avatar
Fan#: 89475
It is a hack job... but i think it looks and performs better then the stock set up...
2006ZX3Skittle
RallyRevolution:#23
AVIDRallier
Old 03-05-2013, 12:26 PM   #10
GreySkorpion
saved from the grave
GreySkorpion's Avatar
Fan#: 94674
Points 6,225, Level 51
This is EXACTLY what I did to mine last April. I have been researching to try and find a AEM dry-flow to replace the Spectre.
GreySkorpion is offline
