Dropped Valve Seat Rebuilds - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-12-2012, 01:01 PM   #1
PuntaGorda
Fan#: 105933
What I Drive: 2001, Maroon, SE
FF Reputation: 1 PuntaGorda Good Standing Member
I'm rebuilding a SOHC 2.0 SPI and have less than complete faith in the specifications provided by our trusty friends at Fel-Pro. Could I get a few second opinions on the torque specifications and end sequence for the Head Bolts? I currently have them all at 44 ft/lbs and will hold sequence until a consensus of the SPI gods has been made. Thank you.
PuntaGorda is offline
Old 02-24-2013, 10:00 AM   #2
dromeda
Fan#: 28157
FF Reputation: 1 dromeda Good Standing Member
Here's what my haynes manual says (I would also be interested in what the FSM says too if anyone has it...):
1) Tighten to 37 ft-lbs in special sequence pattern starting from the center going to the outside
2) Loosen half a turn in reverse pattern
3) Tighten to 37 ft-lbs in forward pattern
4) Tighten 1/4 turn in forward pattern
5) Tighten 1/4 turn in forward pattern
Doesn't really give a final torque but 44 seems ball parkish.
[edit - changed word "star", not really a star pattern, but starting from the center and moving out pattern]
dromeda is offline
Old 02-24-2013, 11:49 AM   #3
Donnyd21
Fan#: 109211
What I Drive: 2002
FF Reputation: 1 Donnyd21 Good Standing Member
1) Tighten to 37 ft-lbs in star pattern starting from the center
2) Loosen half a turn in reverse star pattern
3) Tighten to 37 ft-lbs in star pattern
4) Tighten 1/4 turn in star pattern
5) Tighten 1/4 turn in star pattern
Dont do the star pattern, do what the manual says as far as the head bolt numbers go, this is very important!
I HAVE GOOD USED OEM PISTON AND ROD ASSEMBLIES FOR ALL 2.0L SPI ENGINES (FOCUS, ESCORT AND TRACERS)!! PM ME.
Donnyd21 is offline
Old 02-24-2013, 06:11 PM   #4
dromeda
Fan#: 28157
Yeah, it's not a true star pattern. The haynes manual does have the certain sequence. I was using "star" as a generic term. I edited my reply so as not to confuse anyone else that comes along and reads it.
dromeda is offline
Old 02-25-2013, 12:30 AM   #5
murrayjay57
murrayjay57's Avatar
Fan#: 97961
What I Drive: 2002 Blue Focus SE
FF Reputation: 1 murrayjay57 Good Standing Member
I am also replacing my spi head. This helped alot. :-D
Sent from my MOTWX435KT using FF Mobile
HONK!!!!!!
murrayjay57 is offline
