Murray's new SPI build - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-19-2013, 11:24 AM   #31
murrayjay57
murrayjay57's Avatar
Fan#: 97961
What I Drive: 2002 Blue Focus SE
FF Reputation: 1 murrayjay57 Good Standing Member
so this is what i did today.
new bosch wires and NGK plugs.
removed that shitty hood scoop.
and i changed a radiator overflow hose.
you can tell the new one from the old one.
Sent from my MOTWX435KT using FF Mobile
HONK!!!!!!
murrayjay57 is offline
Old 02-19-2013, 09:19 PM   #32
murrayjay57
Fan#: 97961
i cant really do much with ol blue until it gets warm out. Also because its on and off rain and snow here in northern ohio. so update soon to come.
HONK!!!!!!
Old 02-23-2013, 12:44 AM   #33
murrayjay57
Fan#: 97961
Anyone know how long it would take to do the head swap myself. I just need to know how long my car will be down for.
HONK!!!!!!
Old 02-23-2013, 01:07 AM   #34
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
What I Drive: 97 Impreza coupe, 04 Mazda6
Points 36,735, Level 100
Points: 36,735, Level: 100 Points: 36,735, Level: 100 Points: 36,735, Level: 100
FF Reputation: 13 TheGlassMaker Great Standing Member
Technically it should only take a few hours.
Do one thing every day that scares you. -Eleanor Roosevelt
TheGlassMaker is offline
Old 02-23-2013, 01:43 AM   #35
murrayjay57
Fan#: 97961
So basicly just old head off, new gasket on then new head?
HONK!!!!!!
Old 02-23-2013, 01:49 AM   #36
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
yea, but you gotta set timing, and it wouldn't hurt to change the timing belt while your at it.
Make sure you use new head bolts, you should opt for new manifold bolts too. Being in Ohio i doubt you'll be able to remove the mani bolts with out breaking them.
Old 02-23-2013, 02:26 AM   #37
murrayjay57
Fan#: 97961
Thats true. Iv already looked at the bolts and id be lucky if one came fully out.
HONK!!!!!!
Old 02-24-2013, 02:59 AM   #38
jiangfsh
Fan#: 109856
What I Drive: Focus 2002, SPI, Gold
FF Reputation: 1 jiangfsh Good Standing Member
Why new head bolts is needed ? thanks
jiangfsh is offline
Old 02-24-2013, 03:10 AM   #39
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
You should always replace the head bolts. Head bolts can and will stretch over time due to the fact they are usually steel and the head is aluminum, as the two materials have different thermal rates.
If you reuse the old bolt it could break, or it could bottom out in the threaded hole of the engine block causing damage to the block and/or not tightening down the head all the way.
For safety reasons head bolts should only be used once.
Old 02-24-2013, 03:56 AM   #40
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,703, Level 94
Points: 23,703, Level: 94 Points: 23,703, Level: 94 Points: 23,703, Level: 94
Level Up 36% Completed
Forum Activity 17%
Actually this head and most of the newer engines use torque to yield (TTY) style head bolts... which means you purposely stretch them to a specific length defined by the amount of torque. some allow reuse as long as the bolt measures under a specific length.
mikebontoft is online now
