Old 02-21-2013, 07:04 PM   #1
Faygo Focus
Faygo Focus's Avatar
Fan#: 85587
What I Drive: 2012 Tuxedo Ti with James Bond Pkg
FF Reputation: 2 Faygo Focus Good Standing Member
Cool Tires rotated; now pulls to the left
Got my oil changed and tires rotated at the dealer.
They suggested new wiper blades and tire balancing, which I declined.
Maybe I shouldnt have declined the balancing because now the car pulls to the left, most noticeably in the left lane of the expressway.
Should I see if the treads wear themselves back, or could this simply be due to balancing issues?
I was turned off to extra services when some guy hit me up for "windshield inspection", but maybe I should have done the rebalance.
Thoughts? How much is a rebalance anyway?
Faygo Focus is offline
Old 02-21-2013, 07:12 PM   #2
OPsDad
OPsDad's Avatar
Fan#: 108661
What I Drive: 2x2013-TI4drPlat'mNAV,SE5drSterling
Pulling is typically not balance, but either alignment or inflation.
Obviously, checking inflation would be step 1, I think....
OPsDad is offline
Old 02-21-2013, 10:08 PM   #3
aperson9923
aperson9923's Avatar
Fan#: 90061
What I Drive: 2012 SGM Ti Hatch
FF Reputation: 1 aperson9923 Good Standing Member
You need to have them aligned when they are rotated.
2012 Sterling Grey Metallic Ford Focus Titanium Hatch
401A, Navi, MFT, Rain Sensing Wipers
Built: 11/28/11
Arrived: 12/16/11 (4 Miles)
aperson9923 is offline
Old 02-21-2013, 10:12 PM   #4
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2013 Performance Blue Ti Hatch
FF Reputation: 15 jdubhack Great Standing Member
Uhhh... Are you suggesting an alignment with every rotation?
Sonic's Crew #015 "Werehog" --- HN005
April 2013 HOTM
jdubhack is offline
Old 02-21-2013, 10:16 PM   #5
Sonic MK3 Crew #06
I think that's what they said, but I've never found an alignment to be necessary after every single tire rotation if the tires were wearing evenly and not pulling before hand.
suss6052 is offline
Old 02-21-2013, 10:22 PM   #6
ralck
Fan#: 96372
What I Drive: My sister's car while it is salty
FF Reputation: 1 ralck Good Standing Member
Do you have the stock Continental tires or have you upgraded to something else? If you have upgraded, could you have directional tires that are now backwards on the car?
ralck is offline
Old 02-21-2013, 10:29 PM   #7
05focusST91
05focusST91's Avatar
Fan#: 83640
What I Drive: 2005 ST
FF Reputation: 4 05focusST91 Good Standing Member
Probably off tire pressures or an alignment issue as said earlier, we do comp alignment checks at my dealer and mk3s are usually out slightly in camber/toe
D23 crew #27, the look on their face when they see foci taillights
05focusST91 is offline
Old 02-21-2013, 10:30 PM   #8
jdetzel
Fan#: 102548
If you car is shaking get your tires balanced. Balancing will not have any effect on pulling.
You shouldn't need to get an alignment when you rotate your tires.
You would think they would make sure the tire pressure is correct when they rotated the tires but check it anyway.
You could try swapping the two front tires. That may take care of it.
I just had mine rotated and thought I noticed a little drift that it did not have before. A few days later I don't notice it any longer.
jdetzel is offline
Old 02-21-2013, 11:21 PM   #9
Elizabeth
Elizabeth's Avatar
Fan#: 89280
What I Drive: '12 Yellow Focus SE stick, 17"rims
FF Reputation: 9 Elizabeth Good Standing Member
Rotating tires is a waste of money.
If you get it free, well maybe.
I would NEVER pay to rotate tires.
With the right inflation, tires will wear evenly across the tread.
True fronts wear out faster..
When the fronts are worn out, new on back and the rear to front.
Works for me.
Elizabeth is offline
Old 02-22-2013, 12:52 AM   #10
StingRay
StingRay's Avatar
Fan#: 67421
What I Drive: 2013 Ingot Silver ST
FF Reputation: 4 StingRay Good Standing Member
With how aggressive the factory camber angles are on the MK3, Proper inflation will cut down on uneven tread wear, but there will still be a slight imbalance.
StingRay is offline
