Tune Issues - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Focus Tuning Chat
Old 09-02-2012, 03:06 PM   #1
tspitts
Fan#: 70839
What I Drive: 2004 Black SVT
FF Reputation: 1 tspitts Good Standing Member
Tune Issues
I posted this in another thread but am re-posting it under this new thread so that it does not get lost over there.
I have Tom's tune and want to throw this out and see if anyone else has these issues with Tom's or anyone else's tune. My SVTF had a tune on it when I bought it and I got Tom's tune around the beginning of this year to see if I could get a little more out of the car short of going FI. After loading the tune, the car runs 100% better off the line but has the following problems:
1. Every now and then, when I push in the clutch when coming to a stop, RPMs immediately drop off and the car stalls. I pulled the IACV and cleaned it out.
2. When cruising at 50 - 60 mph, car has a definite stutter almost like a plug is misfiring.
3. Car throws a CEL. If I remember correctly, it was P0133 having to do with the upstream O2 sensor.
I finally went back to the old tune and don't have any of the problems with this other tune. After running the old tune for a few months, I tried reloading Tom's tune yesterday and problems 1 & 2 immediately came back. I am not taking anything away from Tom because I love how the car accelerates with his tune and he has been very responsive in trying to address these issues. Unfortunately, nothing shows up on a datalog to indicate what is causing these issues. Since I would love to go back to running his tune, has anyone else had similar issues for which they have found a solution? Thanks.
tspitts is offline
Old 09-02-2012, 05:20 PM   #2
TopGearTerror
Fan#: 81069
What I Drive: 2008 Silver SES
FF Reputation: 1 TopGearTerror Good Standing Member
No expert on tuning, but while perusing tuning threads I had read about similar symptoms coming from either a faulty or misconnected MAF sensor. Check that, maybe?
Edit: What also leads me to this conclusion is it sounds symptomatic of a fuel/air mixture imbalance. Your car is running under it's own power while the clutch is forcing the engine to turn over, but when you push in the clutch and separate the wheels from the engine, it cannot keep itself running. You also mentioned that stutter at cruising speeds.
"So, a dog over-steers, which is more fun than an under-steering Hyena so... you want a Mazda MX-5 because it's rear-wheel drive!"
TopGearTerror is offline
Old 09-02-2012, 05:25 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
FF Reputation: 153 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
How many datalog have you sent me , Problems 1 and 2 I can adjust , problem 3 has more to do with the o2 , placement , etc
Sorry hard to do names , email names , forum names , IM names etc
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 09-02-2012, 06:08 PM   #4
tspitts
Fan#: 70839
Tom - looking at my laptop, it appears I have sent you 7 datalog files. Should I run another one tomorrow and send it to you? Thanks.
tspitts is offline
Old 09-02-2012, 08:26 PM   #5
1turbofocus
FF Affiliate
Fan#: 1123
If your having issues never stop sending me datalogs till I tell you its something other then an issues with the tune and even then I will give you things to test or check , If I send you a tune for an issue and dont hear back then I am guessing its fixed and your good to go
The issue with the stalling has to be done in small steps or you will go from stalling to flair when you push in the clutch , high revs when you cone to a stop etc
Tom
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 09-02-2012, 08:36 PM   #6
tspitts
Fan#: 70839
Thanks Tom. I will do a datalog in the morning and send it to you. Is there anything special I should do on this datalog or just the normal 5 minute session with some aggressive driving thrown in?
tspitts is offline
Old 11-12-2012, 10:02 AM   #7
swansong
swansong's Avatar
Fan#: 83576
Gonna bump this to ask if any resolution was found. I'm having the exact same symptoms, #1, #2, and #3. Recently replaced O2 sensor with new Motorcraft part, but still throws P0133. I'm in the process of datalogging the problems with Tom.
Mine: 2008 Saab 9-3 Aero SportCombi XWD: 87k, Black, Manual, JZW Stage 1. 320hp/400tq.
Gone: 2002 SVT, #1654
Hers: 2010 Focus SES: 78k, Ebony, Auto, Moon and Tune
swansong is online now
Old 02-18-2013, 11:10 PM   #8
NemesisEnforcer
Force-Powered Focus
NemesisEnforcer's Avatar
Fan#: 48598
What I Drive: LIQUID GRAY 2005 ST
FF Reputation: 352 NemesisEnforcer Outstanding Standing MemberNemesisEnforcer Outstanding Standing MemberNemesisEnforcer Outstanding Standing MemberNemesisEnforcer Outstanding Standing Member
Just a bump for the two guys. Was this issue fixed?
GIVE DUE REP!! ST Crew #78 /Duratec Crew #91
Go Pats!! Go Green!! Go Sox!! Go B's!
Seeker of Wisdom, LG Crew #1
Resident Sith Lord & Jedi Master, MMA
Thx to those in the military.
NemesisEnforcer is offline
Old 02-19-2013, 06:57 AM   #9
swansong
swansong's Avatar
Fan#: 83576
Yes, and two things helped. One was replacing the front O2 sensor, then making sure to reset the ECU by disconnecting the the negative battery cable for a few minutes (which should be done anytime an electrical component or sensor is replaced - d'oh!), and the other was a datalog session with Tom. He was able to tweak the tune little by little until my stalling disappeared.
