Old 02-15-2013, 11:07 PM   #11
Deftmetal
Deftmetal's Avatar
Fan#: 105884
What I Drive: 2013 Red focus se sport
FF Reputation: 4 Deftmetal Good Standing Member
I typed that before I took the picture. I thought it was like the gm version. It might be fine to attach there on this style. With this kind of clamp where the nut is 90° to the clamping direction the part of the fastener that re directs the force gets jammed, if you tap the stud the nut came off of down lightly it should loosen the clamp. Rotating it might help as well. As the picture sits there is nothing actively holding it on besides deformation of terminal or clamp
Sedan revolution #259, Rally Revolution #14, Sonic's MK3 Crew #23
Josh
Originally Posted by teamDFL View Post
You can sleep in your car, but you cannot race your house.
Deftmetal is offline
Old 02-15-2013, 11:14 PM   #12
FamousMassacre
Fan#: 104066
What I Drive: 2012 Gray Metallic Focus SEL
FF Reputation: 1 FamousMassacre Good Standing Member
OH So you're saying to disconnect the positive that I have to unclamp it at the 90° section?
Could you give a simpler explanation of how to take it off? lol sorry
Thanks though!
FamousMassacre is offline
Old 02-15-2013, 11:23 PM   #13
Deftmetal
Deftmetal's Avatar
Fan#: 105884
The nut is off, that means its loose. It is simply stuck. Sorry about all the extra information.
clamps that work like this one does go on easy but don't come loose very easy. Tap on the stud gently to make it go down towards the battery. That will allow clamp to spread more easily
Josh
Old 02-15-2013, 11:30 PM   #14
FamousMassacre
Fan#: 104066
Oh I completely understand you now.
Unscrew the negative and then unscrew the nut on the positive and tap it/ pull it up?
Old 02-15-2013, 11:36 PM   #15
Deftmetal
Deftmetal's Avatar
Fan#: 105884
Thats how to get the terminals free of the clamps. I'm not sure how maneuver the battery out of the battery tray
Josh
