#31 | ||||
Wow thanks, that was really helpful. |
#32 | ||||
"Elder"
On one particular vehicle I drove for work with an outside temp gauge, the temps when sitting still were quite variable compared to the "real" outside temp.. Once moving for a while the readings stabilized close to "reality".
Keeping track of just when it reads "funny", you may learn over time what effects it the most. Sun effects have been mentioned, icing can actually "freeze" it at 32 if it gets caked with enough ice to keep it's temp stable, warm air from the engine area would bump up the readings at low speeds or when stopped (even though they TRIED to isolate the sensor it still gets effected).... Just my personal observations after using that factory model a few years, followed by mounting an aftermarket unit on another rig that showed similar reactions. My current rig has one that sometimes gives useful info., but I gotta tell ya - the educated eye for snow & ice conditions is still what I have to rely on. Ice Warning gauges just sound off at temps near freezing, & really "cry wolf" quite a bit - too many other factors determine when the road gets slick..... Luck! |
#33 | ||||
Of the many type of sensors it's probably a thermistor - fairly inexpensive - resistance changes with temperature. And since they have changed the mirror assembly already then it points to a problem with a connector/contact/resistance that is changing slightly with temp or vibration. Mirrors aren't heated on a 2012/focus?
Member of the Dropped Valve Seat Club. Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything. 40k+ miles, now jinxed? |
#34 | ||||
I have been really surprised at the number of cars I have seen slide off the road. Cars that looked to be going straight as an arrow and at a reasonable speed and then whoosh, they fly 50 feet off into a ditch. Thanks |
#35 | ||||
[QUOTE=a_2000_se;4579342]Of the many type of sensors it's probably a thermistor - fairly inexpensive - resistance changes with temperature. And since they have changed the mirror assembly already then it points to a problem with a connector/contact/resistance that is changing slightly with temp or vibration. Mirrors aren't heated on a 2012/focus?[/QUOTE
The mirrors are not heated on my car. The connectors is something I heard one of the Ford mechanics mention but they did not look any further since it was within the + or - 3 degrees at the time which met factory specs. I would not mind testing the connectors myself. I am guessing there is one at the mirror assembly and one more under the dash somewhere? I would guess I am just looking for loose connections and checking the resistance with a multi meter? Thank you |
#36 | ||||
BEWST AGAIN YAY!!!!!
on another note, if you hit the multiple quote (on the post that you want to quote) then hit quote on the last one you can answer all the posts in one shot and not have to do three or four posts. Just a pointer for ya. |
#37 | ||||
You are right, all except one were 4WD vehicles. Kind of strange. Thanks for the quote tip. |
#38 | ||||
People in 4WDs think they're invincible and they're the first ones in a ditch, it happens in IL and probably anywhere else that gets "occasional" snow/ice.
EAP with 1/3 of the cold weather package. No block heater or TCS. |
#39 | ||||
You are right, I own a 4WD adn always will, but when it snows I still slow down and drive carefully. |
#40 | ||||
Update 4-2-2013 -> I gave up worrying about the temp gauge and for some reason unknown to me it is fairly accurate now. I am not sure why. It is within 1 to 2 degrees.
