MK3 Headlight Adjust - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-13-2013, 06:18 AM   #1
scada
Fan#: 107778
What I Drive: 2013, Silver, Focus S
Points 310, Level 6
Points: 310, Level: 6 Points: 310, Level: 6 Points: 310, Level: 6
Level Up 20% Completed
FF Reputation: 1 scada Good Standing Member
Anyone know how to adjust the headlights in a MK3? I had a headlight replaced and now one is higher than the other.
I am at work and it is dark out. Figured I'd ask so when I go look I can fix it quick.
scada is offline
Old 02-13-2013, 06:36 AM   #2
BrApple
BrApple's Avatar
Fan#: 95810
Points 576, Level 11
Points: 576, Level: 11 Points: 576, Level: 11 Points: 576, Level: 11
Level Up 52% Completed
Its in the owners manual.
However there should just be a screw somewhere to adjust the height of the beam. There is no horizontal adjusted iirc.
- 12 Focus SE - 5spd
- 2k Contour SVT - #2137
BrApple is offline
Old 02-13-2013, 01:43 PM   #3
jdetzel
Fan#: 102548
Points 173, Level 3
Level Up 46% Completed
I have seen it in the owner’s manual as well, but have looked at the headlamp and I can’t see any adjusting screw.
jdetzel is offline
Old 02-13-2013, 02:27 PM   #4
scada
Fan#: 107778
Points 310, Level 6
It is in the owners manual. The photo is useless went out to the car and can't make heads or tails of where it is. Might have to remove the headlight to find it.
scada is offline
Old 02-13-2013, 02:34 PM   #5
jdetzel
Fan#: 102548
Points 173, Level 3
I have and still did not see it.
I figured I would stop by the dealer sometime and ask someone to show me.
Or maybe someone here who knows will post a pic with a BIG RED ARROW to point it out.
jdetzel is offline
Old 02-13-2013, 04:26 PM   #6
wilsonfocus86
wilsonfocus86's Avatar
Fan#: 23099
What I Drive: 14 Fusion 2.0
It is in the manual and it tells you to use a Number 2 Phillips screw driver (+). ON the back of the headlight housing there is a small vertical hole in which the screwdriver goes into and turns a plastic cog basically that heightens or lowers the beam up or down.
wilsonfocus86 is offline
Old 02-13-2013, 04:30 PM   #7
IngotMK3
IngotMK3's Avatar
Fan#: 42911
What I Drive: MK3 Focus
Points 4,121, Level 40
Points: 4,121, Level: 40 Points: 4,121, Level: 40 Points: 4,121, Level: 40
Level Up 86% Completed
FF Reputation: 1 IngotMK3 Good Standing Member
And whats the deal with bulb replacement, everything is so jammed in the bay..
IngotMK3 is offline
Old 02-13-2013, 04:41 PM   #8
jdetzel
Fan#: 102548
Points 173, Level 3
On the back, Ok I'll look next time I have one out.
jdetzel is offline
Old 02-13-2013, 04:47 PM   #9
jdetzel
Fan#: 102548
Points 173, Level 3
Just take the whole housing out, it is only 2 screws and then you can get to the bulbs on the back.
You can also reach down and get to the fog light bulbs with the housing out.
jdetzel is offline
Old 02-13-2013, 04:56 PM   #10
IngotMK3
IngotMK3's Avatar
Fan#: 42911
Thats what I was thinking - way easy to handle that way.
I dont have fogs
IngotMK3 is offline
