P0401 code in Zetec 16V engine ???? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-11-2013, 05:12 PM   #1
just jhon
Fan#: 109578
What I Drive: 2001 Green Hornet ZX3
FF Reputation: 1 just jhon Good Standing Member
Hi, i have a 2001 - ZX3 with a Zetec 16v engine on it, its has the ckeck ligth on, with a P0401 code , the car run fine, just sometimes only oscillates, and go under 800 rpm when i back to neutral (N) without the A/C, but not both at the same time, , please someone help wiyh this, i really appreciate....
just jhon is offline
Old 02-11-2013, 06:42 PM   #2
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,157, Level 74
Points: 13,157, Level: 74 Points: 13,157, Level: 74 Points: 13,157, Level: 74
Level Up 77% Completed
Forum Activity 40%
Buy-Sell-Trade Rating: (46)
Moved to "General Technical Chat".
zetecDon is offline
Old 02-11-2013, 06:46 PM   #3
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Level Up 52% Completed
DPFE sensor failure is common on your year. (EGR = Exhaust Gas Recirculation)
P0401 - EGR Flow Insufficient Detected
The EGR system is monitored during steady state driving conditions while the EGR is commanded on. The test fails when the signal from the DPF EGR sensor indicates that EGR flow is less than the desired minimum.
Causes:
Vacuum supply
EGR valve stuck closed
EGR valve leaks vacuum
EGR flow path restricted
EGRVR circuit shorted to PWR
VREF open to D.P.F. EGR sensor
D.P.F. EGR sensor downstream hose off or plugged
EGRVR circuit open to PCM
VPWR open to EGRVR solenoid
D.P.F. EGR sensor hoses both off
D.P.F. EGR sensor hoses reversed
Damaged EGR orifice tube
Damaged EGRVR solenoid
BC_ZX3 is offline
Old 02-11-2013, 06:55 PM   #4
just jhon
Fan#: 109578
WOW :( and how i know what it is ?????? all this signals is the same code ????
Old 02-11-2013, 08:38 PM   #5
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,910, Level 76
Points: 13,910, Level: 76 Points: 13,910, Level: 76 Points: 13,910, Level: 76
Level Up 65% Completed
Forum Activity 8%
Buy-Sell-Trade Rating: (18)
Check for a Vacuum leak first, if you dont find one, then your best bet is a trip to the mechanic for a diagnostic to find out exactly what part failed.
SkyPilot is offline
Old 02-12-2013, 11:10 PM   #6
Points 3,376, Level 36
Points: 3,376, Level: 36 Points: 3,376, Level: 36 Points: 3,376, Level: 36
Level Up 18% Completed
Forum Activity 54%
Most engine codes have that many different things that cause same code. That's why it's so funny when people throw parts at the problem without checking any of the other possibilities.
In this case though, the DPFE sensor like he says, often the cause.
amc49 is online now
