oil leak on a SVT - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-11-2013, 05:46 PM   #1
ssvhto72
Fan#: 65145
What I Drive: 03, CD silver SVTFocus
FF Reputation: 1 ssvhto72 Good Standing Member
oil leak on a SVT
I have an oil leak and not bad were it makes a puddle but it leaks on to my exhaust and smells.
im not sure what its called but ill give you guys the location and hope someone knows what it is so i can buy one and replace it.
its this baffle/container type thing right under my exhaust header on the block.. looks like 3 bolts hold it on.
ssvhto72 is offline
Old 02-11-2013, 06:40 PM   #2
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,030, Level 74
Points: 13,030, Level: 74 Points: 13,030, Level: 74 Points: 13,030, Level: 74
Level Up 45% Completed
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat".
zetecDon is offline
Old 02-11-2013, 07:39 PM   #3
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
What I Drive: 10 Forte DD,Comp SVTF, 14 Fiesta ST
Points 16,375, Level 82
Points: 16,375, Level: 82 Points: 16,375, Level: 82 Points: 16,375, Level: 82
Level Up 5% Completed
FF Reputation: 28 PumkinSvt Great Standing Member
Buy-Sell-Trade Rating: (33)
that's where your PCV vavle goes. It prolly went bad. you should replace it .
HKS||Garrett||TopSpeed||Tial||Massive||
PumkinSvt is offline
Old 02-11-2013, 07:55 PM   #4
ssvhto72
Fan#: 65145
thanks for moving this,
the pcv valve is that little fitting on top towards the air filter correct?
the issue is that the whole unit is rotted. anyone know what thats called?
and is it the same as the regular ford focus models with the 2.0L?
ssvhto72 is offline
Old 02-11-2013, 07:58 PM   #5
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
I got if you need it. Ill take a pic of it and post it here.
Old 02-11-2013, 10:56 PM   #6
ssvhto72
Fan#: 65145
i do neeed it it is rotted.. pictures would be great.. also do i need to remove the exhaust manifold to replace that?
ssvhto72 is offline
Old 02-12-2013, 10:47 AM   #7
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,408, Level 61
Points: 8,408, Level: 61 Points: 8,408, Level: 61 Points: 8,408, Level: 61
Level Up 86% Completed
Forum Activity 29%
It will be tight, but you should be able to pull it out without removing the exhaust header. The SVT has a little more clearance in that area, if it was a regular Zetec then would have a large CAT right in your way. But I have never pulled it of the motor with the header on.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 02-12-2013, 11:02 AM   #8
SrDudley
Fan#: 100058
What I Drive: 2004 Pitch Black ZX5 EAP SVT
Points 981, Level 16
Points: 981, Level: 16 Points: 981, Level: 16 Points: 981, Level: 16
Level Up 81% Completed
FF Reputation: 1 SrDudley Good Standing Member
are you sure its definitely rotted maybe try pulling it and giving it a clean out maybe thats why the oil is coming out cuz its clogged....if not buy buy buy
SrDudley is offline
Old 02-12-2013, 05:52 PM   #9
ssvhto72
Fan#: 65145
well its either that or my oil pan... that pcv unit thing is higher... thats where ill start.. both are very punky... car did sit for 2 years. and there where no oil leaks before parking it... any body know what that name is or a part #?
ssvhto72 is offline
Old 02-12-2013, 06:51 PM   #10
SrDudley
Fan#: 100058
oil seperator
SrDudley is offline
