Old 02-11-2013, 12:51 PM   #1
AtlantaDan
Fan#: 107970
What I Drive: 2012 Focus HB SEL
FF Reputation: 1 AtlantaDan Good Standing Member
windows fogging at idle in rain - with A/C ON
Just as the title states - when sitting at a light with the A/C on, windows up, and its raining, the windows will fog up like mad. Even hitting the defroster doesn't work as well as one would think. Once I get moving, they clear out - but it still pisses me off, and it is dangerous at night.
Anyone have the same issue?
AtlantaDan is offline
Old 02-11-2013, 12:55 PM   #2
HoneyBadger
Fan#: 104860
What I Drive: 2012 Ford Focus SEL
FF Reputation: 1 HoneyBadger Good Standing Member
When was the last time you cleaned the inside of your windows? Dust tends to hold a lot of moisture creating the fog build up quicker than with clean windows.
HoneyBadger is offline
Old 02-11-2013, 03:08 PM   #3
silenthill
Fan#: 85671
I'm convinced it's something to do with the automatic climate control. My car does this from time to time, too. The a/c is shutting off for some reason. There's a thread on here about humid air bursts from the a/c...it's the same problem.
silenthill is offline
Old 02-11-2013, 03:17 PM   #4
AtlantaDan
Fan#: 107970
Um, while I appreciate your taking the time to reply....
Yeah, I searched a bit before I posted here and noticed the 'humid smell' questions too. I also suspect it has something to do with emissions. It would make some oddball 'greenwash' sense to have the compressor kick-off at idle to conserve fuel, but at the expense of safety? It's pretty stupid if you ask me....
Old 02-11-2013, 03:47 PM   #5
1slofofo
1slofofo's Avatar
Fan#: 92422
What I Drive: Mk3 RaceCar
FF Reputation: 4 1slofofo Good Standing Member
Try using only the defroster, defroster won't clear as fast when the a/c was just going.
Sedan Revolution 198. Rally Revolution 42.
'13 Fuze Wheels.
1slofofo is offline
Old 02-11-2013, 03:50 PM   #6
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus
FF Reputation: 3 thejordan Good Standing Member
it's probably switching from vent to recirculation, when you turn on the defrost, a/c kicks on and may kick on the recirc. i think vent is what you want.
thejordan is offline
Old 02-11-2013, 04:20 PM   #7
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
FF Reputation: 7 BetaDnB Good Standing Member
I have the same problem and have all along.
Actually that's not true. A/C blows dry air to help remove humidity. Most vehicles now actually route the defrost air through the air conditioner and that's not even new.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete
www.soundcloud.com/betadnb
www.facebook.com/jirelandphotography
BetaDnB is offline
Old 02-11-2013, 05:15 PM   #8
silenthill
Fan#: 85671
Oh, there goes my auto climate control theory!
I complained once to my dealer, and of course, "could not duplicate" was the response. It seems like, on my car, this occurs when the car isn't under much load--i.e. idling at a traffic light or I've had the a/c cut off while cruising at 65. Have you noticed any patterns?
Old 02-11-2013, 05:26 PM   #9
c5karl
Fan#: 105687
What I Drive: 2013 Hatchback SE, 5-speed, silver
FF Reputation: 1 c5karl Good Standing Member
Make sure you have the recirc button turned off. In any car, this can cause fogged windows when the weather is damp.
From the owner's manual:
Note: Prolonged use of recirculated air may cause windows to fog up.
Note: To reduce humidity build-up inside your vehicle, do not drive with ... recirculated air always switched on.
c5karl is offline
Old 02-11-2013, 05:53 PM   #10
IngotFoFo
IngotFoFo's Avatar
Fan#: 108099
What I Drive: 2012 ingot silver sedan
FF Reputation: 1 IngotFoFo Good Standing Member
I have issues with my drivers window fogging up way to easily, and staying fogged up.
Usually it happens when it is rainy out but thats not the only time.
I never use recirculated air, and it usually happens when the defrosters are on. I usually have to open the window which only slightly helps and makes me cold in the process. Sometimes turning off the defrosters helps, sometimes it doesnt.
Ive never seen a vehicle fog up like this one.
IngotFoFo is offline
