steering wheel shakes/vibrates over 60mph - Page 2 - Ford Focus Forum, Ford Focus ST Forum
Old 02-07-2013, 11:48 AM   #11
Chris_HT
Chris_HT's Avatar
Fan#: 86229
What I Drive: Blue SVT 2002
Points 1,526, Level 22
Points: 1,526, Level: 22 Points: 1,526, Level: 22 Points: 1,526, Level: 22
Level Up 26% Completed
FF Reputation: 4 Chris_HT Good Standing Member
Posted via FF Mobile
Chris_HT is offline
Old 02-07-2013, 01:00 PM   #12
Dardas
Dardas's Avatar
Fan#: 107673
What I Drive: 2005 Saab 9-3 Turbo 5spd
FF Reputation: 1 Dardas Good Standing Member
Originally Posted by PDQEagle View Post
Wheel imbalance will come on gradually and get worse with speed. With the small tires on the focus, there's not enough mass to bring it on at lower speeds
Do you have steel or stock mags?
Don't look for terrible things to be wrong.
Look for bent or warped wheels. A dented wheel will balance, but wont track even on the road.
Make sure that the balancer centers on the center hole on the wheel and make sure it is clean. Don't use an adjustable lug hole balancer.
I had a Datsun 240Z that had the Datsun "jiggle" and all the balancing never
corrected it, until I used my friends bubble balancer
It could also be a dented steel belt in the tire.
i dont know what mags are... i had an idea it might be the rims. i had to replace one of them about a year ago i got at a junk yard because it was bent. it may be that one or more are significantly bent. i was planning on buying aftermarket rims in the near future anyways. I am also sure the tires are not the problem because before i replaced the tires it was still shaking at high speeds and the new tires only have about 2k miles on them.
Dardas is offline
Old 02-07-2013, 01:01 PM   #13
Dardas
Dardas's Avatar
Fan#: 107673
Originally Posted by Chris_HT View Post
Swap the front and rear wheels. See if problem persist.
i've done tire rotation before and the problem still exists. with new tires and old.
Dardas is offline
Old 02-07-2013, 01:40 PM   #14
Chris_HT
Chris_HT's Avatar
Fan#: 86229
Did this rotation involve moving wheels or just tires?
Chris_HT is offline
Old 02-07-2013, 01:40 PM   #15
Chris_HT
Chris_HT's Avatar
Fan#: 86229
Chris_HT is offline
Old 02-07-2013, 01:51 PM   #16
SteezMuffin
SteezMuffin's Avatar
Fan#: 99549
What I Drive: 2009 Sterling Grey Focus SE
Points 783, Level 14
Points: 783, Level: 14 Points: 783, Level: 14 Points: 783, Level: 14
Level Up 83% Completed
FF Reputation: 2 SteezMuffin Good Standing Member
A bent rim could be the problem
Sent from my iPhone using FF Mobile
SR #237 | CUSE
SteezMuffin is offline
Old 02-07-2013, 01:51 PM   #17
Dardas
Dardas's Avatar
Fan#: 107673
actually, that is a good question. i am going to go back to the mechanics and double check to make sure they didnt just do tire rotation because i cant answer that question. So yes, i will start from there.
Dardas is offline
Old 02-07-2013, 01:52 PM   #18
Dardas
Dardas's Avatar
Fan#: 107673
That is what im hoping the problem is because i want to get new aftermarket rims anyways.. however, if it was bent wouldnt that mean for that rim the tire would start significantly losing air in it? which i havent noticed happening
Dardas is offline
Old 02-07-2013, 02:01 PM   #19
Chris_HT
Chris_HT's Avatar
Fan#: 86229
A rim can be bent enough to cause problems at higher speeds, while showing no visual signs of being damaged.
...ask me how I know :p
Chris_HT is offline
Old 02-07-2013, 03:11 PM   #20
Dardas
Dardas's Avatar
Fan#: 107673
im gonna take a guess and say that scenario happened with you. lol
Dardas is offline
