Replacing my catalytic converter - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-07-2013, 09:51 AM   #11
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 2 tmittelstaedt Good Standing Member
Hmmm....I suspect that either one of 2 things happened. Either when they were fixing the evap system the mechanic discovered one of the O2 sensors was unplugged or the sensor was just loose and tightened it, or when they cleared codes, it erased both codes and whatever is setting the P0422 code is only doing it intermittently. In which case if you have emissions inspection next month you might be able to slide through. If the light goes on again just go to an auto parts store and ask them to clear the codes and see if the light stays off for a while.
tmittelstaedt is offline
Old 02-07-2013, 11:59 AM   #12
Zeroe31890
Fan#: 109481
What I Drive: 2000 grey ZX3
FF Reputation: 1 Zeroe31890 Good Standing Member
Hmm, are they suppose to clear the codes? If it matters, the lady at the desk told me that the engine light would still be on, but its not. I am not sure if she meant it will eventually come on again. I hope it was a loose o2 sensor though because I saw the mechanic wiggle, disconnect, and reconnect the upstream o2 sensor. But I appreciate your advice a lot!
Zeroe31890 is offline
Old 02-07-2013, 02:14 PM   #13
tmittelstaedt
Fan#: 108093
Points 233, Level 4
they need to clear the codes to make sure the evap code does not come back.
if you did not tell them to fix the catcon code then they won't admit to fixing it because they do not want to warranty the work. But, if the mechanic is in there fixing something else and he happens to see a quick 1 minute fix like replacing a connector that got unplugged, most of them will do it and then just not record anywhere that they did it. That way, if the quick fix didn't fix anything the customer doesen't know the difference, and if it did fix something then the customer is going to be happy. (and if it breaks a week later again, then the customer won't want it fixed for free)
Old 02-21-2013, 02:34 PM   #14
Zeroe31890
Fan#: 109481
You said that you had error code P0422. When you changed both 02 sensors that actually worked? Cuz I dont have the money to replace a cat and inspection is in a few days.
Old 02-21-2013, 08:16 PM   #15
coldbear
Fan#: 78292
What I Drive: 2014 Race Red 6/spd. SE
Points 1,358, Level 20
Points: 1,358, Level: 20 Points: 1,358, Level: 20 Points: 1,358, Level: 20
Level Up 58% Completed
Cats do not just go bad. People kill em with bad gas and additives. Pull the o2 sensors out and clean the thermocouples(can) around it with emeory cloth. Thread em back in with never sieze , reset you code light and put a bottle of Sea Foam or a pint of Colemans Camp Fuel to the gas tank. I doubt the cat. is bad. Drive it like you stole it . All's will be well again.
coldbear is offline
Old 02-25-2013, 10:41 PM   #16
tmittelstaedt
Fan#: 108093
Points 233, Level 4
If the emery cloth thing does not work and your really hard up for cash then try replacing just the front O2 sensor first and give it some time. The theory is that if the front O2 sensor is bad then your exhaust mixture will be wrong and the cat won't reach operating temperature, thus the downstream o2 might get sooted up. When the upstream O2 is working then the cat is likely going to be working, it will be at operating temp, and that may "clean" the downstream o2.
Also in the cheap fix dept. make sure that the gasket upstream of the cat is not leaking. There's a big gasket on the flange that has 3 bolts that hold it together, right above the cat.
But yes, in my case I was getting that code and I replaced both sensors. That was 3 months ago and it's still working fine. But of course I was planning on replacing the cat if I had to.
Don't you have a pick-and-pull wrecker nearby?
Also one other thing - no insult intended here - but many if not most states have emissions repair programs for low income residents. If your on unemployment or something like that, then contact the state as you may get a voucher or some such to get the thing repaired.
Good luck and let us know how it works out.
Old 02-25-2013, 10:53 PM   #17
Zeroe31890
Fan#: 109481
Thanks for the advice. And no offense taken. I'm a student and am about to graduate. So technically unemployed, yes. I will let you know how it goes. I actually ordered a Magnaflow direct-fit converter for $233. Price was within my budget and I hope its not just the o2 sensors. Though everything is pointing to the converter, so I am just gonna replace it. Again I appreciate your advice and time! :D
Old 03-24-2013, 04:24 PM   #18
Oblivion
Fan#: 92148
What I Drive: 2001 Blue ZX3
FF Reputation: 3 Oblivion Good Standing Member
Originally Posted by Zeroe31890 View Post
I need help figuring out how to properly buy a catalytic converter for my 2000 ZX3. My engine light is on and I am getting code P0422, and unfortunately the cat is the most likely culprit. I also have error P0455, but I don't think that is causing the cat to give that error, but I mention it just incase it may.
Anyways, I have done some research and found out it'll cost between $500 to $1400 to get that fixed (odds are the larger range). I have searched for cats online, and have seen stuff ranging from $100 to $300. I would rather do it myself to save money. Problem is I need to make sure it will make the engine light turn off and make sure the cat works well enough to get me to my internship as well as pass inspection. Hopefully someone can help me figure it out. I believe my cars engine is a 2.0L I4 SOHC 8V FI Engine. I really appreciate any advice and help in the matter!
Hi. I don't mean to jack your thread, but I just wanted to share this:
- http://www.obd-codes.com/p0420
There are about 10 different listed possible culprits for triggering that error (P0420).
My own vehicle is apparently emitting that DTC. Along with P0455 and P0457 (false positive).
I believe in my own vehicle, that it may very well be the temperature sensor causing it.
It (the gauge) behaves very funny. Unless it's being accurate about the temperature fluctuating greatly (bad pressure cap affecting the boiling point?).
Before you even bother replacing it: Try cleaning it! Yes. I understand how foolish that may sound. But what is a potential $2 solution?
If at best, it truly is an old wives tale, and nothing but snake oil: It is $2. If it works: That is a $2 solution!
You can try removing the catalytic converter from the vehicle, and letting it soak in either laundry detergent or lacquer thinner. Let it soak in a bucket 24+ hours minimum (completely submerged).
If I'm not mistaken: It could also be the thermostat malfunctioning, which would be affecting the coolant's temperature, which would be affecting the O2 sensors.
After a moment of Googling, I found this from some forum, "14. If the thermostat open just a bit too soon, and the engine never quite reaches operating temp, the ECM will continue to provide a little bit of enrichment. Meanwhile on the other side of the ECM the O2 is reporting a rich condition. If this goes on for too long it may be recorded as a mixture code that may interpreted as a bad O2."
In short: Instead of randomly replacing parts: You should try to really diagnose the problem first.
You can use a multimeter to check the O2 sensors (http://www.ehow.com/how_4870344_do-v...en-sensor.html).
You can test the thermostat by dumping it in a pot of boiling water (use a thermometer to check the water's temperature first).
You can test the engine temperature sensor with a multimeter (http://www.youtube.com/watch?v=wFHWpgHMAvY or this: http://www.youtube.com/watch?v=G7pE7DQBSV8).
You can test a whole array of things with just a simple multimeter, and basic knowledge. That should really narrow it down and pin-point it to BEING the catalytic converter.
But back on that subject (replacing the catalytic converter): I have a 2001 Ford Focus ZX3 MTX-75.
The only real question I have is regarding the 'hangers' or 'shock absorbers' or 'rubber grommets' that hold up the pipes (and catalytic converter).
How are you supposed to properly uninstall, and reinstall those? I haven't spent much time researching it.
Oblivion is offline
Old 03-25-2013, 02:33 AM   #19
tmittelstaedt
Fan#: 108093
Points 233, Level 4
Testing a cat in these cars is very simple. You replace both O2 sensors and if the CEL does not go off after 4 full drive cycles the cat is bad.
The fact is though that unless you put an automotive scantool on the car you don't know what your doing. A scan tool will give you readouts from both O2 sensors and comparing those readouts will tell you if the cat is bad or not - assuming that is, that the sensors are both OK.
Washing the cat only worked with old style cats that had metal foil substrate and "ball" style catalytic converters (metal can filled with ceramic or stainless steel balls with a specially coated surface). A mix of detergent (as a wetting agent) and citrus cleaner (loosens carbon but does not harm platinum) was used.
That does not work on the modern cats which use a different construction.
There is a tool for the rubber hangars, just get it from an auto parts store.
