Valentine One - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-26-2013, 09:18 PM   #41
thejordan
thejordan's Avatar
Fan#: 107706
Points 1,041, Level 17
Level Up 41% Completed
Originally Posted by Jdog913 View Post
Yes mine shuts off when the car is off. But I should note I have an actual key, I don't have the key less start.
Mine is a key too. I'll try #85 then. Are you using a 20amp fuse for the detector?
thejordan is offline
Old 01-27-2013, 01:09 PM   #42
Jdog913
Guest
Fan#: 84424
What I Drive: .
FF Reputation: 3 Jdog913 Good Standing Member
Did you have any luck? That I'm not sure. Is there one that comes with the 12v adapter? I would just use that same one as that.
Jdog913 is offline
Old 01-30-2013, 11:08 PM   #43
thejordan
thejordan's Avatar
Fan#: 107706
nope, the #85 didn't work. #61 is doing the 30min shut off.
i tried a bunch of different ones to see if any worked with ignition with no luck. if someone could tell me which wire has 12v acc, I'd just use my vampire tap and be done with it instead of using add-a-fuse.
Old 02-06-2013, 02:50 PM   #44
nmd55
nmd55's Avatar
Fan#: 38246
What I Drive: 2007 Tungsten Grey ST
FF Reputation: 1 nmd55 Good Standing Member
Question for the group:
I am hard-wiring a bunch of electronics and would like everything connected via a keyed 12V source.
I used this fuse locations with an add-a-fuse:
To that fuse I added a 10A fuse and connected the following:
1) homelink mirror (less than 2 amp draw)
2) V1 radar detector (less than 2 amp draw)
3) Cheetah GPS detector (less than 1.5amp draw)
4) Garmin nuvi (less than 2 amp draw)
The items above work wonderfully and turn off/on with the key.
I want to add the following:
5) Blinder Xtreme m47 (less than 2 amp draw)
6) Blinder Xtreme m27 (less than 2 amp draw)
7) Nav-TV backup camera video board (less than 2 amp draw)
I believe if I add items 5,6,7 then I will blow the 10amp fuse. I do not want to add a 20amp fuse to the mini add-a-fuse (i believe these are only rated for 10amp max). Does anyone know of another keyed source in the Smart Junction box on the passenger side?
Thanks for the help this site is the best!!!
nmd55 is offline
Old 02-06-2013, 03:43 PM   #45
thejordan
thejordan's Avatar
Fan#: 107706
What car? My '13 BCM does not look like that.
Old 02-06-2013, 03:50 PM   #46
nmd55
nmd55's Avatar
Fan#: 38246
what BCM are you referring to?
my car is a 2013 Focus ST and the Smart Junction box in the passenger footwell looks exactly like that picture.
nmd55 is offline
Old 02-06-2013, 06:20 PM   #47
thejordan
thejordan's Avatar
Fan#: 107706
focusst.org has the info you're looking for.
Old 04-28-2013, 02:08 AM   #48
fiveofocus
fiveofocus's Avatar
Fan#: 60237
What I Drive: 2013 Ford Focus SFE
Points 1,195, Level 18
Points: 1,195, Level: 18 Points: 1,195, Level: 18 Points: 1,195, Level: 18
Level Up 95% Completed
FF Reputation: 1 fiveofocus Good Standing Member
hey man great writeup! #85 worked perfect for me! thanks to you my hardwire on my blendmount took 10 minutes!
fiveofocus is offline
Old 06-11-2013, 03:53 PM   #49
dbsimms63
Fan#: 110359
What I Drive: 2013 Performance Blue Titanium 5dr
Points 1,825, Level 25
Points: 1,825, Level: 25 Points: 1,825, Level: 25 Points: 1,825, Level: 25
Level Up 25% Completed
Forum Activity 6%
FF Reputation: 2 dbsimms63 Good Standing Member
getting ready to do this for my V-1
dbsimms63 is offline
Old 06-12-2013, 12:11 PM   #50
mikesusz
mikesusz's Avatar
Fan#: 326
What I Drive: 2013 PB Ti Hatch +Handling
Points 16,540, Level 82
Points: 16,540, Level: 82 Points: 16,540, Level: 82 Points: 16,540, Level: 82
Level Up 38% Completed
FF Reputation: 4 mikesusz Good Standing Member
i got a MirrorMount for my (bel 995) from amazon for about thirty bucks. holds the detector pretty well. i didn't really want it on the mirror but i wanted it up high and not attached to the windshield, and that seemed to be the only place (that would still let me flip the visors and not hit the detector)
i've got a remote mute switch ("smartcord") mounted with double-sided tape down by my knee.
one important note - if you go this route, make sure the pillar you choose will reach where you want to power it (and optionally, where you want the mute button to be). i had everything wired under the dash and pulled up the passenger A-pillar before i realized (due to where i put the mute button) it wouldn't reach over to the mirror and down to the detector. i had to switch and run it up the driver's A-pillar instead. d'oh!
here are some pics of the mount i have:
http://girder.net/focus/mirror-mount.1.jpg
http://girder.net/focus/mirror-mount.2.jpg
and where i located my Mute button:
http://girder.net/focus/mirror-mount.3.jpg
mikesusz is online now
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
