Old 02-05-2013, 07:52 AM   #1
Pinion Dominion
Pinion Dominion's Avatar
Fan#: 105589
What I Drive: 2012 White Platinum Focus Titanium
FF Reputation: 4 Pinion Dominion Good Standing Member
High Beams will not toggle anymore after service
I took my Focus to the dealer for an oil change a couple of days ago. (+ they repaired my mykey feature).
Last night, while driving I noticed that the toggle function of the high beams does not work anymore. I am referring to page 121 of 5th printing manual where it says "push the [turn signal] lever toward the instrument panel to activate". Before, when I did this, the high beams would stay on after pressing it.
Now, it will just act as a "flash-to-pass" a la what happens when you pull the lever towards you.
So now, pulling and pushing the lever becomes "flash-to-pass". Not very convenient to hold the lever down if I want continuous high beams..
Has anyone ever experienced something like this?
Pinion Dominion is offline
Old 02-05-2013, 09:22 AM   #2
ccelaya
ccelaya's Avatar
Fan#: 92465
What I Drive: 2012 Sterling Grey - Focus HB Sport
FF Reputation: 1 ccelaya Good Standing Member
Yes I have, when your toggle is on the "parking lights" position, the high beams only work as a "flash-to-pass".
Make sure your toggle is on the "full-on" position, and try to switch to high beams with the lever.
I hope that helps.
ccelaya is offline
Old 02-05-2013, 09:51 AM   #3
Pinion Dominion
Fan#: 105589
I hope that helps.
Do you mean the headlamp control knob? (pg 120)
I have that set to autolamp. I'll try it tonight.
Old 02-05-2013, 11:09 AM   #4
feta_mgp
feta_mgp's Avatar
Fan#: 88210
FF Reputation: 6 feta_mgp Good Standing Member
That's what he's referring to yes
2012 SGM SEL Sedan 303a w/o Nav
Job 1 built 6/2011
feta_mgp is offline
Old 02-07-2013, 11:58 AM   #5
Pinion Dominion
Fan#: 105589
I hope that helps.
Thanks ccelaya, what you wrote worked. Now I don't know if my memory is skewed or not but I could have sworn that when I had my lamps set to autolamp, the high beams would still toggle on...
Old 02-07-2013, 12:42 PM   #6
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
FF Reputation: 7 BetaDnB Good Standing Member
My high beams work just fine with my headlamp switch set to auto.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete
www.soundcloud.com/betadnb
www.facebook.com/betadnb
BetaDnB is offline
Old 02-07-2013, 12:58 PM   #7
lewisra
Fan#: 93289
So do they work in auto mode? When your car goes in for service they will usually turn auto mode off.Since you have DRL's you may not have noticed.
lewisra is offline
Old 02-07-2013, 01:04 PM   #8
Pinion Dominion
Fan#: 105589
The high beams "work" in autolamp mode. Pressing (and holding) forward on the turn signal lever turns the high beams on. But as soon as I stop pressing forward (ie. releasing the lever), the high beams go off (so it's in "flash-to-pass" mode).
But before the service, doing this same action, the high beams would remain on. To turn the high beams off I would push the lever forward again then release (I call this toggling - you don't need to keep holding something to keep the effect, it just toggles on and off based on further pressing/de-pressing).
Old 02-07-2013, 01:31 PM   #9
Kabigon
Fan#: 88299
FF Reputation: 5 Kabigon Good Standing Member
You fail to mention the obvious. Are the headlamps themselves on or off???
Of course it will make a difference as to how the high beams operate.
Kabigon is offline
Old 02-07-2013, 01:51 PM   #10
lewisra
Fan#: 93289
My high beams work correctly(stay on) in auto mode. The lights need to be on(dark outside) for the high beams to stay on.
lewisra is offline
