#11 | ||||
FF's Night Security
Moved to Technical Chat
I started out with nothing and I still have most of it left Hatch Nation #15 (Ole' Yeller') & #150 (The SVT) Moderator for Technical Chat Zetec Performance Chat Southern Fanatics Chat |
| Sponsored Links | |||
Advertisement | |||
#12 | ||||
Yup- its called an exhaust heat shield. You can reinstall it by using fender washers (small hole-large OD) instead of the factory ones where the thing is supposed to attach. If you can safely get under the car you can fix it for about $5. You can get the washers from any good parts store or an ACO.
#13 | ||||
Cat converter heat shield?
Yep, I'd say it was the heat shielding falling down. As stated earlier, get some body washers and some 1/8" rivets and go to town with it. My shielding started to fall down and sounded,also felt like, a $5.00 lap dance with a 40# Northern Pike.lol.
#14 | ||||
#15 | ||||
You live in a climate where it can get hot-I don't suggest eliminating the shield. As I recall the nuts that hold the shield on are (I think) only 8mm. a cheepo box end and your in business. As for the dealer helping for no charge, it is very unlikely but it wont hurt to ask.
#16 | ||||
#17 | ||||
Check the bolts on the water pump, mine vibrated off awhile back except for one and caused a horrible rattling sound. Maybe this helps :-P
Sent from my ADR6410LVW using FF Mobile
When I die, I want to go peacefully like my grandfather did, in his sleep, not screaming, like the passengers in his car. |
#18 | ||||
Or a heat shield. Them things are bad about rattling later in the years
