PCV valve location? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-03-2013, 03:55 PM   #1
GUM85
Fan#: 109288
What I Drive: 2006 Pitch Black ZX4 ST
Points 266, Level 5
Points: 266, Level: 5 Points: 266, Level: 5 Points: 266, Level: 5
Level Up 32% Completed
FF Reputation: 1 GUM85 Good Standing Member
Angry PCV valve location?
I know this subject has probably been covered already but I've searched all over and can't seem to find an answer. I need to know where the PCV valve is located on my 2002 Focus LX with the SPI engine. I'm having rough idle issues and suspect this might be the problem considering a lot of people seem to have the rough idle issue and the hose coming from the PCV valve are known for collapsing or getting holes in them. There is a little valve on the top back of the valve cover at the top of the engine that twist in and out of the valve cover. Is that it? I've been reading that it's located on the back of the engine below the valve cover but I think that's only on the Zetec engines not the SPI. Any help (and possibly pictures) would be greatly appreciated. This rough idle is really starting to get on my last nerve
GUM85 is offline
Old 02-04-2013, 07:36 AM   #2
zpellicone
Fan#: 105007
What I Drive: 2001 Pitch Black ZTS
FF Reputation: 1 zpellicone Good Standing Member
Yes, that is your pcv valve. Should be on the top right side of the engine when facing it. When I had my escort with the spi engine, I replaced it and I actually noticed a very slight increase in power. Of course, 1 year later itcoughed up a valve seat. I have a zetec now and as far as I know, the collapsed pcv hose only applies to those engines. The pcv is on the front of the block on those engines and the house runs under a lot of heated elements. As I remember though it was one of the easiest things I did on that engine.
zpellicone is offline
Old 02-04-2013, 08:20 AM   #3
BlueFocusSE5
Fan#: 97166
What I Drive: 2002 Ford Focus
FF Reputation: 1 BlueFocusSE5 Good Standing Member
What you described is the PCV valve and it's location, yes. It's also a good idea to check the PCV valve hose that goes to the PCV valve, as they characteristically wear out, collapse on themselves and cause all sorts of drivability problems.
When the engine is cold and off, (of course), with a strong light lean over and into the engine bay right on top of the engine and follow the PCV hose from the PVC valve to the back lower part of the engine. Right at the bottom of the hose there is a 90 degree turn and right there is where the hose tends to collapse and/or develop a large vacuum leak. If this has happened, you'll need to replace it of course. It makes life much easier if you disconnect that plastic air tube leading to the throttle body and remove it for better access. All you need is a screwdriver to do this. Take your time and go easy. Plastic parts with a lot of time and mileage on them tend to get very brittle and break easily, so slow and easy does it.
These are the part numbers from my local Ford dealership, but check yours to be certain. Your Ford parts department will need the VIN number of your car to provide you with the correct parts -
1. PCV Valve - YS4Z 6A66 AC
2. PCV Valve Hose - YS4Z 6758 A
Bring some cash. The hose is a whopping $44 and the PCV valve is $16. Plead poverty and ask for a discount!
The hose itself simply pulls off of the PCV valve and also the back of the engine. A pair of needle nose pliers can help pull it off the back of the engine, as that's not an easy area to reach. If the PCV valve hose hasn't failed yet, it will. The 90 degree bend is made of very thin/cheap rubber and it always develops leaks.
I hope this helps you out.
BlueFocusSE5 is offline
Old 02-04-2013, 10:30 AM   #4
GUM85
Fan#: 109288
Points 266, Level 5
Thanks, I was pretty sure that was the PCV valve but I just wanted to double check with someone that knew for sure.
GUM85 is offline
Old 02-04-2013, 10:54 AM   #5
BlueFocusSE5
Fan#: 97166
Make sure to check that PCV valve hose too, as that is likely the problem and not the PCV valve itself.
Old 02-05-2013, 04:39 AM   #6
BlueFocusSE5
Fan#: 97166
I have found that a Ford dealer by the name of Village Ford is sponsoring this forum and has much lower prices than what other Ford dealers are charging. The PCV valve hose that my local for dealer ripped me off for to the tune of $45, is available from Village Ford for only $31.
Here is the link. Contact them directly for the forum discount -
http://www.focusfanatics.com/forum/s...=306858&page=2
Old 02-05-2013, 04:45 AM   #7
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
What I Drive: 97 Impreza coupe, 04 Mazda6
Points 35,631, Level 100
Points: 35,631, Level: 100 Points: 35,631, Level: 100 Points: 35,631, Level: 100
Forum Activity 8%
FF Reputation: 13 TheGlassMaker Great Standing Member
Do one thing every day that scares you. -Eleanor Roosevelt
TheGlassMaker is online now
Old 02-05-2013, 05:19 AM   #8
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
Forum Activity 8%
Rockauto.com has dirt cheap prices too. Always been my go to parts store.
Sent from 34.0764 N, 118.4296 W
Old 02-05-2013, 06:08 PM   #9
BlueFocusSE5
Fan#: 97166
But do they sell O.E. quality Ford parts with a nationwide warranty?
Also, do they sponsor this great forum we have for us like Village Ford does?
Old 02-06-2013, 01:17 AM   #10
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
Forum Activity 8%
Not sure if they sponser the site. But I question how you haven't heard of rock auto. Yes they sell all OEM brands, cheaper than any other parts store I guarantee. Open any car magazine and you'll find a rockauto ad, watch any car program and you'll see ad for rockauto.
http://www.rockauto.com
