2012 Focus heater - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-02-2013, 05:15 PM   #21
Zeeky
Fan#: 109305
What I Drive: 2012 Black Focus SE
Points 344, Level 6
Points: 344, Level: 6 Points: 344, Level: 6 Points: 344, Level: 6
Level Up 88% Completed
FF Reputation: 1 Zeeky Good Standing Member
Anddddddd now the heater is back to working again. I haven't had the car looked at, but it got to blazing hot when I took it on the highway. Maybe my daily commute just isn't going to be enough time to get the heat going hot? My brother suggested I "push the engine" in order to create more heat to be drawn in (something like that), so maybe I need to just give a bit more gas when possible in my daily drive?
Zeeky is offline
Old 02-03-2013, 10:35 AM   #22
flyboyike
Fan#: 98206
What I Drive: 2012 Race Red SE sedan
Points 335, Level 6
Points: 335, Level: 6 Points: 335, Level: 6 Points: 335, Level: 6
Level Up 70% Completed
Forum Activity 7%
FF Reputation: 3 flyboyike Good Standing Member
Does your coolant temp go up, like it's supposed to?
flyboyike is offline
Old 02-03-2013, 11:44 AM   #23
Points 9,852, Level 66
Points: 9,852, Level: 66 Points: 9,852, Level: 66 Points: 9,852, Level: 66
Level Up 51% Completed
Forum Activity 28%
Don't rely on the dummy gauge on the instrument cluster either, if you want to visually monitor the engine temperature you need to either use an obd ii scantool like a scangauge, or to run the car in test mode on the instrument panel center display. (Hold down the left ok button for at least 5 seconds prior to turning the car from off to run, hold it while starting the car until the screen says TEST). Scroll down or up through the various test menus until you see the coolant temperature sensor reading. It should start off cold, somewhere near 14-25C or less and rise to normal operating temperatures of around 90-97C eventually. 97 is usually slightly on the warm side, and I only have seen it in brief intervals on stop and go freeway driving while the car was warming up due to the acceleration and deceleration.
suss6052 is online now
Old 02-03-2013, 02:21 PM   #24
2012sel
2012sel's Avatar
Fan#: 84814
Adding heated seats
You may want to add heated seat pads if the car doesn't have time to get warm on your commute.
Looks like a fairly straight forward installation whether you have cloth or leather seats. I'll likely do this someday. Your butt will be warm in less then a mile of turning them on and it feels awesome!
Here's a thread about how to do it...
http://www.focusfanatics.com/forum/s...g+heated+seats
Current
Past Rides
2012sel is offline
Old 02-03-2013, 03:18 PM   #25
cuke2u
cuke2u's Avatar
Fan#: 87358
What I Drive: It's in my sig..
FF Reputation: 2 cuke2u Good Standing Member
HI, if the CC is set to automatic it blends the air. What should be measured is the ambient temp inside and outside the car relative to what the temperature setting is at.
Mk3 Focus Titanium X, 1.6 Ecoboost 150ps + Bluefin Remap
Candy Red
Appearance Pack
18" 5 Spoke Alloy Wheels
Manual 6-speed gearbox,,,
cuke2u is offline
Old 02-03-2013, 04:13 PM   #26
cobie56
Fan#: 84403
i agree i have the oem leather heated seats and boy do they roast my butt and back in just a mile or so.... any setting above 3 (once they warm) is too warm for me... i actually find 2 a nice toasty medium..
cobie56 is offline
Old 02-03-2013, 05:51 PM   #27
flyboyike
Fan#: 98206
Points 335, Level 6
Forum Activity 7%
The SE doesn't have automatic climate control.
Old 02-03-2013, 06:28 PM   #28
hand-filer
hand-filer's Avatar
Fan#: 90895
What I Drive: One less Ford
On the highway I could get mine to blow hot. On a -20F day I could drive around town for hours and never get more than lukewarm. I took it to the dealer 3 times and they couldn't find any faults. Even test drove another one on a cold day to confirm it was the same.
This was the primary reason for getting rid of mine.
Sent from my maxiPad
hand-filer is offline
Old 02-04-2013, 12:05 AM   #29
Zeeky
Fan#: 109305
Points 344, Level 6
I'm not too worried about having heated seats :P.
The heater seemed to work well again today. I do have a different question though. While checking for any reason why the heat may be odd, I noticed that little black circle/dot that is directly under the center of the windshield/on top of the dash material. What exactly (if anything) does it do? A sensor of some sort?
Zeeky is offline
Old 02-04-2013, 12:16 AM   #30
Forum Activity 28%
That's the ambient light and solar gain sensor afaik. Its used to tell the auto lamps to turn on when it gets dark enough, as well as for interpreting the sun load when running the climate control. At least that was my understanding if you mean the little black rectangle with a cover over it near the base of the windshield in the middle.
