Outside Temperature Incorrect - 2012 Focus - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-29-2013, 05:12 PM   #1
kemoe
Fan#: 109270
What I Drive: 2012 Ford Focus
FF Reputation: 1 kemoe Good Standing Member
Hello, I have seen several posts on the web and here in Focus Fanatics regarding the outside temperature reading being incorrect on later model Focuses. What I have not seen is a solution to this issue.
My 2012 base model is constantly showing 2 to 8 degrees higher than the actual temperature. I brought the car into the dealership and they replaced my passenger side mirror because the sensor is mounted in the mirror. This did not fix the issue. The dealership has now created a trouble ticket with Ford. I have not heard back from the dealership for several days even though I have called them a few times so I have called Ford directly and created another trouble ticket to see if that would help.
I have seen on several posts that Ford has told other posters that the root of problem is that the system first calculates the outside temperature in Celcius and then converts it to Fahrenheit which is hard to believe that Ford's software developers couldn't do basic math. But you never know?
I use the outside temperature to warm me of potential hazardous ice so it is important to me that this works. If I can't get it working correctly, I am going to get rid of this car.
Please let me know if you have a solution to this issue. I will post my solution once and if I find one.
Thanks
kemoe is offline
Old 01-29-2013, 06:41 PM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,708, Level 78
Points: 14,708, Level: 78 Points: 14,708, Level: 78 Points: 14,708, Level: 78
Level Up 65% Completed
Forum Activity 10%
Wow. Tough stance.
Throw away $5K or more trade in loss because you are too cheap to buy some aftermarket temp gauge?
I also note my temp gauge is higher than the real temp outside.
Usually I can tell if it is below freezing. Something I picked up walking outside once in a Blue Moon I guess.
My car is parked in a heated garage, so the temp drops from 78F/68F (year round) down/up to whatever the temp is outside in a minute of so. It stays higher than the real Winter temp by about 8 degrees I guess. Summer it seems to be right on actually.
I might try to change it to Celcius temp range and see if that is correct.
Elizabeth is offline
Old 01-29-2013, 07:22 PM   #3
kemoe
Fan#: 109270
Originally Posted by Elizabeth View Post
Wow. Tough stance.
I tried changing it too Celcius but there doesn't seem to be a way to do it. Probably something the dealer can do via their scantool? (I have the base model)
Sorry for sounding sour but this issue looks to me like a software problem which should be an easy fix. I see all sorts of Ford Focus owners with the same problem but Ford seems to be ignoring them. Our F150 hasn't ever had an bug or did our two previous Ford Mustangs. I wonder if Ford did this work themselves or outsourced it?
I will let you know what I find out.
kemoe is offline
Old 01-29-2013, 07:46 PM   #4
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
Points 9,389, Level 65
Points: 9,389, Level: 65 Points: 9,389, Level: 65 Points: 9,389, Level: 65
Level Up 13% Completed
Buy-Sell-Trade Rating: (12)
Are you serious? Have you read your manual? It is in the menu between the gauges.
Settings: display: temperature: (then choose C or F)
<>< Gal. 6:14
April 2013 HOTM
jdubhack is offline
Old 01-29-2013, 07:59 PM   #5
Points 10,220, Level 67
Points: 10,220, Level: 67 Points: 10,220, Level: 67 Points: 10,220, Level: 67
Level Up 43% Completed
Forum Activity 32%
I've not noticed it being off by 8+F, when it was zero F outside the car read exactly 0F, when I got to the interview it had warmed up to about 5F, and then later in the day by the time I got home it read only about 14F and it felt like it.
suss6052 is online now
Old 01-29-2013, 08:04 PM   #6
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
Points 8,102, Level 60
Points: 8,102, Level: 60 Points: 8,102, Level: 60 Points: 8,102, Level: 60
Level Up 76% Completed
Forum Activity 6%
Remember that the thermometer is under the passenger mirror, and can show higher or lower temps if it's getting direct sunlight, or in the shade, etc.
Hatch Nation #29
Joeywhat is online now
Old 01-29-2013, 10:06 PM   #7
kemoe
Fan#: 109270
Yes, I am serious. Yes, I have read my manual. There is not a menu between my guages. Higher trim models have the menu between the guages, mine does not.
kemoe is offline
Old 01-29-2013, 10:08 PM   #8
kemoe
Fan#: 109270
So you are sure it is dead on? If so, then there goes the theory about the software. Or maybe the version of the software is different?
kemoe is offline
Old 01-29-2013, 10:10 PM   #9
kemoe
Fan#: 109270
This is happening at night (well past sundown) as well. In fact it is worse at night when I am driving home. About an hour ago is was 6 degrees over. This morning at 7AM it was only 2 over.
Thanks
kemoe is offline
Old 01-29-2013, 10:43 PM   #10
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 238,851, Level 100
Points: 238,851, Level: 100 Points: 238,851, Level: 100 Points: 238,851, Level: 100
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
How did I ever survive without a temp sensor on my car...oh wait I till don't have one...
Do what I do, if you suspect ice, scuff your foot on the road and see if it is slick before you get in the car, and YES I'm serious...it works.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
