2001 SE suspension noise - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-29-2013, 10:41 AM   #1
scoobiemario
Fan#: 105614
What I Drive: 2012 WRX, 2001 Focus SE
Points 104, Level 2
Points: 104, Level: 2 Points: 104, Level: 2 Points: 104, Level: 2
Level Up 8% Completed
FF Reputation: 1 scoobiemario Good Standing Member
When I drive above 60 MPH, I feel vibration, and hear rhythmic sound coming from rear driver side wheel.
I jacked the car up, and I can feel something is loose.
When I grab at 3 and 9 and move it side to side, i can hear same sound and feel same amount of movement as when I grab wheel at 12 and 6 and move up and down.
It sounds similar to loose balljoint pop.
What could it be? i need to fix it so it does not eat my tires....
Also, how do I tell which VIN I have? There are two options I can see: VIN 3 or VIN P
Car is 2001 SE with ZETEC, 153 k miles. Tires are all in good condition, one I'm concerned about wears out little more on the outside.
Thanks guys
scoobiemario is offline
Old 01-29-2013, 10:59 AM   #2
don627
Fan#: 56863
What I Drive: 2014 Focus Hatchback
Points 208, Level 4
Points: 208, Level: 4 Points: 208, Level: 4 Points: 208, Level: 4
Level Up 16% Completed
FF Reputation: 1 don627 Good Standing Member
I don't think I would be driving at 60mph until it is repair that's one thing. I would get a buddy to help you by jacking up the car and using jack stands get under there while your buddy moves the tire the same way you did and see what's going on because, it could be any number of things, some of which could be very dangerous for you to drive it that way.
don627 is offline
Old 01-29-2013, 12:09 PM   #3
sjfishon
sjfishon's Avatar
Fan#: 79619
What I Drive: 01 black se wagon/14 white se sedan
Points 684, Level 13
Points: 684, Level: 13 Points: 684, Level: 13 Points: 684, Level: 13
Level Up 68% Completed
Forum Activity 7%
FF Reputation: 7 sjfishon Good Standing Member
if you look real close, you will see, on each side of car, just under the back seat, there is a rubber bushing, its on a long swing arm, called the knuckle, these go bad all the time, and will cause a bunch of bad symptoms. as you look from under, you dont have to jack up, you will see at the end of the knuckle, towards the front of car, it should be in the middle of the bracket, if its hitting either side, there is the prob. the prob is replacing it, DON'T EVEN TRY;; just buy a new knuckle..you can buy a bushing kit. but you cant get the old one out, and polish good enough for the new one... unless you have a hoist and power tools this is not a job you want to do, i had mine done for 250$ stay away from a ford garage'' good luck
sjfishon is offline
