Electrical issue - Focus Fanatics
Old 01-09-2013, 05:51 PM   #1
SWEGER
SWEGER's Avatar
Fan#: 88926
What I Drive: 2003 Infra-Red ZX5 SVT
FF Reputation: 1 SWEGER Good Standing Member
Electrical issue
I've searched on this issue before, but everything I have found to be a cause of it I have already fixed.
I have a flickering-type issue with my 03 SVT. While at idle, my lights on my dash, map lights, brake lights, etc flicker (kind of, they never actually go out, but they pulsate between bright and dim). I have replaced my battery, alternator (new, not rebuilt), alternator connector (pigtail), and battery terminal connectors. I had Auto Zone check out my battery and alternator, and they said both were good. All my grounds seem to be tight and clean. I am at a dead end on this...any insight would be greatly appreciated.
2003 Infra-Red ZX5 SVT - Cheap Spectre intake (don't judge, was on there when I got it), Hawk HPS pads front/rear, Russell SS lines, Goodyear Eagle GT 215/45/17
"If guns cause violence, then all of mine are defective" - Ted Nugent
SWEGER is offline
Old 01-09-2013, 10:25 PM   #2
SVTFOCI03
SVTFOCI03's Avatar
Fan#: 103052
What I Drive: 2003 Silver Svt Focus
FF Reputation: 1 SVTFOCI03 Good Standing Member
I have the same issue and replaced the alternator twice and put an optima in it... I heard if you turn the dimmer switch down a little from the max it fixes it but it didn't change mine...
SVTFOCI03 is offline
Old 01-10-2013, 12:44 AM   #3
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
FF Reputation: 28 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat".
zetecDon is offline
Old 01-10-2013, 11:04 AM   #4
SWEGER
SWEGER's Avatar
Fan#: 88926
I am thinking that it might be a grounding issue since I redid those at the same time the rest of the electrical work was done. I'm going to redo the main grounds in the engine bay (battery to chassis, engine to chassis, and the other one) and see if that helps. Any suggestions on the gauge and type of wire needed for this?
SWEGER is offline
Old 01-11-2013, 11:59 AM   #5
cbf1989
Fan#: 106860
What I Drive: 2004 Ford Focus ZTS 2.4L
FF Reputation: 1 cbf1989 Good Standing Member
I'm actually going through the same exact issue right now. I havnt changed anything out yet except the battery and ofcourse it still does the flickering. Thanks for letting us know what you did so far. Saves me from having to change all that out myself.
My next step was going to change out all the ground and such as well, but like you asked, what is the best gauge to use?
cbf1989 is offline
Old 01-12-2013, 07:40 PM   #6
NSTSVT
Fan#: 9552
What I Drive: 2004 P-Blk. SVT 5-DR
FF Reputation: 1 NSTSVT Good Standing Member
Wow. I thought I was on my own w this, as I thought it to be possibly due to a previous fender bender.
SYMPTOM:My dash lights (not radio or dials lighting) will flicker or drain or almost no lighting, again only speedo/ rpm location. As stated if I catch while it starts, I can turn down the illumination potentiometer or dial and it usually holds. I have also a problem with the horn going in op ( perhaps electrically related? )
QUESTION: What/where is the wiring or junction related to the power for the dash and the interior dials? Has anyone figured it to be tied to the illumination dial (potentiometer)?
Any assistance appreciated
Acts1:7-11 " in like manner" :-)
NSTSVT is offline
Old 01-18-2013, 11:22 AM   #7
smallblockfever
smallblockfever's Avatar
Fan#: 95004
What I Drive: 2002 Sonic Blue SVT
FF Reputation: 0 smallblockfever Newbie
not meaning to thread jack here, but im like the rest of you guys and have the same issue.
It used to do it really bad, then i replaced the alternator and it was clearly flickering with the stereo, so i replaced the battery. Fixed a majority of the problem, but its still flickering.
My mechanic says its the ECU playing tricks because of my broken 02 sensors.
But I have an inkling that its the plethora of wires going to my battery.
see my svt wasnt exactly cared for when i bought it.... shes getting the love she needs now but im having to piece it back together. On that note, theres about 6 wires running to my battery, three at each terminal, and half of the wires are crudely spliced together. My thought here is that I need to fish down these wires and make sure it's all solidly connected.
Im gonna suggest that y'all do the same and just make sure your battery connections are solid and wont give you any problems at any end of the cables.
smallblockfever is offline
Old 01-18-2013, 04:58 PM   #8
svtguy88
svtguy88's Avatar
Fan#: 13476
What I Drive: 2003 Infra Red SVT
FF Reputation: 17 svtguy88 Great Standing Member
Replace your grounds (battery to chassis and engine to chassis) with something less meh than factory cables. I have this problem on mine, but it only shows up when my system is up pretty loud.
svtguy88 is offline
Old 01-28-2013, 11:30 PM   #9
Ptreezx3
Ptreezx3's Avatar
Fan#: 97773
What I Drive: 2003 red svt, 06 blue escape,
FF Reputation: 1 Ptreezx3 Good Standing Member
Same issue here. Yet to figure out and it kills me. Sure is something stupid.
Ptreezx3 is offline
Old 02-01-2013, 07:46 PM   #10
baldyredtx
baldyredtx's Avatar
Fan#: 82344
What I Drive: 2003 Sonic Blue SVT 4 dr
FF Reputation: 1 baldyredtx Good Standing Member
I'm having the same issue. My started after I installed Mach headlights. It is completely random. I have tried the dimmer switch and that does not work. I have a new alternator and battery. I was going to work on the grounds. Where is the engine ground?
2003 Sonic Blue 4dr SVT
HFC, 2.5" Borla exhaust, drop in K&N, STS
baldyredtx is offline
