2012 Titanium Front Strut Low Speed Noise (Clunk/Rattle) - Page 192 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-25-2013, 10:22 PM   #1911
Shade-010
Sonic Crew # 010
Shade-010's Avatar
Fan#: 87369
Points 14,973, Level 79
Points: 14,973, Level: 79 Points: 14,973, Level: 79 Points: 14,973, Level: 79
Level Up 25% Completed
Forum Activity 43%
Activity: 43% Activity: 43% Activity: 43%
Originally Posted by thejordan View Post
apparently they are different part numbers for 2012 models (Vehicle Build Date before: 12/14/2011) and 2013 models.
6 speed auto
2012:
3B436
(TX-566)
CV Joint Axle Shaft Assembly
6 Speed Auto Transmission DCPS ; RH
$266.38
2013:
3B436
(TX-640)
$222.06
5 speed manual
2012:
3B436
(TX-565)
5-Speed Manual Trans - MTX75 ; RH
$276.80
2013:
3B436
(TX-639)
hmmmm, thats intresting, makes ya wonder.
http://www.rebeldevil.com
Shade-010 is online now
Old 01-25-2013, 10:25 PM   #1912
thejordan
thejordan's Avatar
Fan#: 107706
Points 1,041, Level 17
Level Up 41% Completed
EDIT: see original post for the comprehensive list
thejordan is offline
Old 01-25-2013, 10:28 PM   #1913
Lipshurt
Fan#: 92314
Points 732, Level 14
Level Up 32% Completed
Really? Zero play? That does make sense.
Mine you can move about .030 or more (1/32 inch) and they make sound. I'm taking about lengthwise side to side. Not a twisting kind of play. So in other words you can move then toward the wheel and away from the wheel, and that makes sound when it hits the end of its travel in each direction.
Somebody else here said theirs does that too.
Lipshurt is offline
Old 01-25-2013, 10:35 PM   #1914
Shade-010
Sonic Crew # 010
Shade-010's Avatar
Fan#: 87369
Forum Activity 43%
Ill check mine tomorrow...
Old 01-25-2013, 10:37 PM   #1915
thejordan
thejordan's Avatar
Fan#: 107706
if one side of the car is up in the air on stands. and you face and grab the wheel and move it up/down and left/right and in/out, where is the play (relative to the wheel not the car)?
the up/down play would only be due to the play in the spring as it is unloaded (just look and you'll be able to see if the spring is causing the play or not or slightly load the spring and see). the axles/shafts/cv themselves should NOT have ANY play (they shouldn't wiggle at all), they should only rotate.
Old 01-25-2013, 10:56 PM   #1916
Lipshurt
Fan#: 92314
The play is on the axis parallel to the shaft. Parallel to the centerline of the shaft actually.
So not up/down
not forward/back
Not twisting
Only inboard/outboard.
Both sides do it.
Lipshurt is offline
Old 01-25-2013, 11:04 PM   #1917
thejordan
thejordan's Avatar
Fan#: 107706
So not up/down
not forward/back
Not twisting
Both sides do it.
that's not right at all. it shouldn't be moving. usually there is a pin right before the transmission that "locks" the cv/axle in place. it should pop and lock in but not wiggle in/out.
why else would 2012s have different part numbers than 2013s?
everything else related to steering/suspension/handling seems to match up between '12 and '13 besides the spring.
Front Spring
BV61-5310-NF* Left Front Coil, BV61-5310-NF* Right Front Coil (Front)
$28.87
Vehicle Build Date between: 3/29/2012 and 12/5/2012
5310
Front Spring
BV61-5310-NG* Left Front Coil, BV61-5310-NG* Right Front Coil (Front)
$28.87
Vehicle Build Date between: 3/27/2012 and 12/5/2012
5310
Front Spring
$31.60
Vehicle Build Date after: 12/6/2012
5310
Front Spring
$31.40
Old 01-26-2013, 01:08 AM   #1918
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Level Up 36% Completed
Not true. The CV axle will slide in and out of the output spline of the gearbox. If it didn't, there would be some serious drivetrain bind when the suspension compressed.
Joined the dark side.
Zillon is offline
Old 01-26-2013, 01:23 AM   #1919
thejordan
thejordan's Avatar
Fan#: 107706
no, it should pop in and out, it doesn't just slide in/out effortlessly. there's a ring that holds it in place. drivetrain bind doesn't really occur because of the cv and hub assembly. if you compress the strut, the axle still isn't moving a whole lot. the CVs can bend and rotate internally (it has to for steering to work).
here you go:
regardless, it still doesn't answer why the 12s have different axles/cvs compared to 13s.
Old 01-26-2013, 09:56 AM   #1920
revhigh
Fan#: 98516
What I Drive: 2012 Mazda 3 SkyActiv 6A Touring
FF Reputation: 1 revhigh Good Standing Member
Zillion is 100% correct ... otherwise it would rip the halfshaft out of the trans as it moved up and down with the bumps in the road.
Every halfshaft I've ever seen has that lateral play.
REV
revhigh is offline
