Old 01-25-2013, 03:36 PM   #1
JesseE1981
Fan#: 88551
What I Drive: 2012 Sterling Grey Focus Hatchback
FF Reputation: 1 JesseE1981 Good Standing Member
Low Tire Prssure warning.....now what?
The title may seem self-explanatory, but let me explain further. It's been rather cold here in Michigan, so the PSI in my tires had dropped to 27-28. The recommended PSI on the side of the door says 35, so I added air to each tire to get it back to 35. Well, the low tire pressure warning still comes on when I start the car, the the light stays illuminated. There doesn't appear to be any sort of leaks....any ideas? Has anyone else encountered this? Doesn't seem like something I should have to reset, or do I?
JesseE1981 is offline
Old 01-25-2013, 03:47 PM   #2
scott7278
Fan#: 100021
FF Reputation: 4 scott7278 Good Standing Member
You need to fill them up while the tires are cold...if you drive on them first (warming them up), you could still get a low-pressure warning when the tires get cold again.
scott7278 is offline
Old 01-25-2013, 03:48 PM   #3
scott7278
Fan#: 100021
If that doesn't do it, you have a leak.
Old 01-25-2013, 03:52 PM   #4
Pendarus
Pendarus's Avatar
Fan#: 94411
What I Drive: 2012 Sonic Blue Titanium 5dr
FF Reputation: 2 Pendarus Good Standing Member
The Spare tire?
Sonic Blue Titanium 5dr Titanium Handling Package
Ordered: 01/28/12
Vin: 02/20/12
Build Date: 03/06/12
Delivery Date: 03/30/12
Pendarus is offline
Old 01-25-2013, 04:19 PM   #5
BlueIce
BlueIce's Avatar
Fan#: 93794
FF Reputation: 1 BlueIce Good Standing Member
Check the tire manually to see if it is at 35. If it is, the tire sensor may just need time to reset itself. Sometimes that does happen. If you did lose pressure and its not just the sensor use water to check for leaks.
The story behind my avatar:
http://www.focusfanatics.com/forum/showthread.php?t=293992
BlueIce is offline
Old 01-25-2013, 04:20 PM   #6
05focusST91
05focusST91's Avatar
Fan#: 83640
What I Drive: 2005 ST
FF Reputation: 4 05focusST91 Good Standing Member
Is the light flashing when you first start it? Id double check the pressures with a different pressure gauge
D23 crew #27, the look on their face when they see foci taillights
05focusST91 is offline
Old 01-25-2013, 05:40 PM   #7
Kabigon
Fan#: 88299
FF Reputation: 5 Kabigon Good Standing Member
Did you drive the car after adding air?
The pressure sensors "go to sleep" when the car isn't moving (when the tires are not rotating) to prolong their battery life.
Kabigon is offline
Old 01-25-2013, 06:54 PM   #8
pozi240
Fan#: 94835
How long has the warning been illuminated? Is this just something that started happening very recently? Do you have different winter rims, or are these the original rims that came with the car? If winter rims, do you have extra sensors in them, where are your OEM rims stored in relation to where you park your car (proximity). This could be TPMS sensor issue depending on what answers you give.
pozi240 is offline
Old 01-26-2013, 10:48 AM   #9
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
FF Reputation: 7 BetaDnB Good Standing Member
I know you know a lot about this car, however anytime I've put air in my tires with the light on (including this morning) I do so with the car running. When I reenter my car the light is already off.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete
www.soundcloud.com/betadnb
www.facebook.com/betadnb
BetaDnB is offline
Old 01-26-2013, 12:42 PM   #10
Rogerschro
Rogerschro's Avatar
Fan#: 90661
What I Drive: '12 frosted glass SEL '67 Gal vert.
FF Reputation: 1 Rogerschro Good Standing Member
That's how I did it too. Car was running, warming up while I aired the tires. They were down to 26psi, put in 35psi cold. No issues after that.
Rogerschro is offline
