How-To: Getrag Transmission Fluid Flush - Page 11 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-15-2012, 10:50 AM   #101
Lscman
Fan#: 95211
What I Drive: 2007 ZX3
Points 1,224, Level 19
Points: 1,224, Level: 19 Points: 1,224, Level: 19 Points: 1,224, Level: 19
Level Up 24% Completed
Originally Posted by SrDudley View Post
You do not want to put automatic transmission fluid into your manual gearbox that's what gear oil is for. Completely different....
Not accurate.
First of all, the slang term "gear oil" is often confused with conventional 75W-90 or similar gear lubricant which is GL-5 certified for use in certain older manual transmissions and hypoid gear differntials. That heavy duty stuff will work fine in a 60's muscle car or the differential of a new 5 liter Mustang, but it will literally eat and destroy yellow brass synchro rings and other parts found in any modern manual transmission built since about 1975. It has the wrong additives for a modern manual transmission. Gas mileage will suffer, the transmssion will feel baulky upon shifting and it will likely fail.
Are you aware that automatic transmissions have gears inside?
Ford SVT service documentation instructs SVT Focus owners to put Mercon V into their manual transmission based upon Getrag Engineering recommendation. Many manual transmissions designed in the 80's until about 5 yrs ago were specifically optimized for running ATF. Getrag's whole manual transmission product line used ATF until the late '90's when they started the switch to mfr-specific manual transmission lube for the M3 Getrag 6spd and some other's. You shouldn't just arbitrarily substitute a gear lube assuming it will be better than what the OEM specified. This is what foolish Toyota Supra owners did in the 90's. Those Getrag 6spds that were built for Dextron quickly failed on redline manual transmission fluid. Owner's manuals describe what lubricants to use. Mercon V is not just for automatic transmissions. It's used for power steering systems too.
Lscman is offline
Old 01-24-2013, 08:04 PM   #102
jvert
jvert's Avatar
Fan#: 80613
What I Drive: 2004 Red ZX5 SVT
Points 222, Level 4
Points: 222, Level: 4 Points: 222, Level: 4 Points: 222, Level: 4
Level Up 44% Completed
FF Reputation: 1 jvert Good Standing Member
Great write up. Plan to do this once the weather gets better here in Chicago.
2004 Red ZX5 SVT #132 of 1079
jvert is offline
Old 01-25-2013, 10:11 AM   #103
SBK86
SBK86's Avatar
Fan#: 108959
What I Drive: 2004 Black SVT
Points 472, Level 9
Points: 472, Level: 9 Points: 472, Level: 9 Points: 472, Level: 9
FF Reputation: 1 SBK86 Good Standing Member
I did this a couple weeks ago with royal purple when I did my regular oil change. It took about 15 minutes. Shifting feels a little smoother.. but it could all be in my head. Still glad I did it since the car is just shy of 100k.
SBK86 is offline
Old 01-29-2013, 05:11 PM   #104
1lowfocus05
Fan#: 106685
What I Drive: Sonic Blue 02 SVT
FF Reputation: 1 1lowfocus05 Good Standing Member
I work for Ford and according to our maintenance schedule it should be every 50000. I always suggest doing it every year and if you are doing a lot of track driving I do mine 2 times a year. You cant hurt the car by doing it to often its going to long that you really need to worry about.
1lowfocus05 is offline
Old 07-13-2013, 11:08 PM   #105
srsairbags
Fan#: 114742
What I Drive: 07 350z WW, 04 SVTF DD
Points 110, Level 2
Points: 110, Level: 2 Points: 110, Level: 2 Points: 110, Level: 2
Level Up 20% Completed
FF Reputation: 1 srsairbags Good Standing Member
subbed
srsairbags is online now
Old 07-16-2013, 09:19 PM   #106
DoctorJ
Fan#: 113834
What I Drive: 2001 Twilight Blue sedan
Points 63, Level 1
Points: 63, Level: 1 Points: 63, Level: 1 Points: 63, Level: 1
Level Up 26% Completed
FF Reputation: 1 DoctorJ Good Standing Member
I recently changed out the transmission fluid in my MTX-75 for Ford XT-M5-QS fluid. The dealership didn't even know what this stuff was and had to order it. This is a hillbilly town though. If it isn't a truck or V8 they don't know anything.
The transmission with it's new fluid and Poly lower mount, shifts 100% better.
You could use anything in the transmission. Cooking oil if you wanted to. But what is the "best" for you, isn't always the "best" for someone else.
My daily beater doesn't take the beating like a drag or Auto X car does.
DoctorJ is offline
Similar Threads
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 10:59 AM
Every trouble code defined 03OrangeSVT General Forced Induction 9 05-25-2011 01:53 PM
is transmission fluid power flush good ? leev General Technical Chat 26 07-30-2009 12:53 AM
how do you fill a mtx-75 with fluid?!!!! help please!!!! firemanchev General Technical Chat 26 09-11-2008 07:18 PM
auto trans fluid change robr General Technical Chat 9 06-07-2005 06:38 AM
