For those with wings - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-24-2013, 12:24 PM   #11
Points 10,249, Level 67
Points: 10,249, Level: 67 Points: 10,249, Level: 67 Points: 10,249, Level: 67
Forum Activity 37%
Originally Posted by misfire View Post
hurry up and get here.
Confirmed, I have the part in hand now, well its in the car, I still have yet to eat lunch so that's what I'm working on now.
suss6052 is online now
Old 01-24-2013, 02:30 PM   #12
RonMaiden
RonMaiden's Avatar
Fan#: 99230
Points 4,224, Level 41
Points: 4,224, Level: 41 Points: 4,224, Level: 41 Points: 4,224, Level: 41
Level Up 37% Completed
Can't you just extend the hose with another piece of hose like a splice? I like the red and want to keep it.
'99 Toyota 4Runner Sport
'11 Subaru WRX STI Hatch
RonMaiden is offline
Old 01-24-2013, 02:39 PM   #13
Forum Activity 37%
You can modify the hose to work in the new wing with the original lamp however the original lamp won't spray the rear window properly as the nozzle on the stock lamp is closer to the edge of the lamp than it is on the ST lamp.
So when you spray the rear window it sprays past the wiper and then the wiper does not turn on until you've sufficiently wet the glass, where as it used to turn on right away.
Perhaps the red lamp from the base ST or the black pack with the 3d carbon wing would have the nozzle also moved to compensate for the longer wing.
The stock lamp physically works with the spoiler, and it only matters if you want the washer to work properly and spray the glass rather than the bumper cover.
Old 01-24-2013, 02:53 PM   #14
RonMaiden
RonMaiden's Avatar
Fan#: 99230
Does the rear wiper use a spray sensor? That seems pricey vs just it coming on when you activate the sprayer.
Old 01-24-2013, 02:57 PM   #15
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,086, Level 34
Points: 3,086, Level: 34 Points: 3,086, Level: 34 Points: 3,086, Level: 34
Level Up 24% Completed
Yeah, was unaware of this if it does! Especially since it doesn't come on by itself when it's raining - so I never thought it would have any kind of sensor for it.
EDIT: Just bought the ST light from Tousley.
PratoN is online now
Old 01-24-2013, 03:05 PM   #16
Forum Activity 37%
I'm not sure if it has a sensor to tell or not, however it used to turn on right away as soon as I'd activated the spray on the rear window, however with the new wing and the stock lamp it sprays for a long period of time before it starts to actually activate the rear wiper. This seems to me to indicate that if the fluid isn't actually hitting the glass the wiper doesn't seem to turn on.
Old 01-24-2013, 03:11 PM   #17
PratoN
PratoN's Avatar
Fan#: 88058
I'll have to experiment... if only it were warmer outside!
Old 01-24-2013, 03:14 PM   #18
RonMaiden
RonMaiden's Avatar
Fan#: 99230
I doubt it has a sensor and I'm hoping a few others that have added the wing will chime is with a similar experience or not. I'm hoping not.
Old 01-24-2013, 03:17 PM   #19
Forum Activity 37%
If I briefly pushed the stalk forward to engage the spray for the rear wiper after this past saturday when I had the wing put on the car it sprayed a stream of fluid but did not engage the wiper if I immediately let go following the stream of fluid. If I held it longer eventually the wiper engaged, so I'm not sure if that was due to the weather or not, but its hard to ignore the fact that the nozzle is in a different orientation now than when it was with the original wing.
If you actually look at the ST rear spoiler it is physically longer than the standard mk3 spoiler, therefore the same nozzle orientation that works properly in one configuration will not work properly in another configuration.
Old 01-24-2013, 03:36 PM   #20
Forum Activity 37%
There were at least two people with this issue in this very discussion, the O.P. with the 3D carbon wing and the stock third brake lamp was complaining about the wiper/ washer no longer working properly in pretty much the same manner. Misfire had also installed the clear ST lamp and seems to be happy with it.
There may be a non clear version with the corrected nozzle angle/ location which would should be part 8A6Z-13A613-B if you're looking to maintain the red appearance.
The clear part is available under service part number 8A6Z-13A613-C.
The stock part is 8A6Z-13A613-A at least as far as I can tell.
