#11 | ||||
Hatch Nation #31 |
| Sponsored Links | |||
Advertisement | |||
#13 | ||||
t(-_-t)
last time my header glowed red hot was because of the IACV being stuck open.
HKS||Garrett||TopSpeed||Tial||Massive|| |
#14 | ||||
Was it hard to start also? Mine will turn over for about 10 seconds before it actually fires up! How would i fix it if it is sticking?
Hatch Nation #31 |
#15 | ||||
t(-_-t)
take it off the intake manifold and clean it.
also your hard starting could be your battery how old is it?
#16 | ||||
FF Affiliate
Things that would make it hard to crank and make the header glow at idle
To little fuel or to much fuel ( this can be checked with a fuel psi gauge and a scan tool) To little or to much ignition timing ( this can only be checked with a scan tool) Cam timing off ( this can be checked by setting the cams and #1 Cly like your going to install a new timing belt ) Vac leak but this would also cause a very high idle , like above 2500rpm (this can be confirmed with a scan tool or checking every vac like for issues , this I do not feel is your issue) I have never seen a CAT cause a hard cranking or a header to glow until you put a load on the engine I think he is either running very lean , overly rich and burning the fuel in the header(rare) or has a valve open when it shouldn't be from cam timing issues , these are the most common then it gets complicated Tom
#17 | ||||
Hatch Nation #31 |
#19 | ||||
FF Affiliate
I cannot rule out a blown intake gasket because that would cause a Vac leak , very right rpm when it did start but wouldnt think glowing headers from an intake leak
I have a few questions and would be easier to phone can you give me a call this evening Tom
#20 | ||||
What number can i reach u at later?
Hatch Nation #31 |
