Dome lights - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-08-2012, 12:15 AM   #61
TSchmi
Fan#: 105240
What I Drive: 2012 Black Hatchback
FF Reputation: 1 TSchmi Good Standing Member
My wife having the same problem with her 2012 SE sedan but I don't have any issues with my 2012 SE HB.
TSchmi is offline
Old 12-08-2012, 02:45 AM   #62
Sonicbluz
Fan#: 100495
What I Drive: 2012 Sonic Blue Focus s
Points 152, Level 3
Points: 152, Level: 3 Points: 152, Level: 3 Points: 152, Level: 3
Level Up 4% Completed
FF Reputation: 1 Sonicbluz Good Standing Member
Originally Posted by supernova1 View Post
Here is how it works for me (my car uses two-stage door unlock):
After your car sits closed for several hours
1. Press "Open" on the key fob once - the driver door opens, but dome light is OFF;
2. Press "Close" on the key fob once - the driver door closes;
3. Press "Open" on the key fob once - the driver door opens and the dome light is ON.
I believe that it is a "stealth" feature in case you want to open your car, but do not want to attract attention to it (you figure the case for this), so it has a mode when the dome light is OFF on the first "Open" click.
It also seems to me that this feature has a timer - if you close your car doors and then after several minutes press "Open" again, the dome light will light up. Only after the car sits closed for several hours (can not get the exact time) the dome light is OFF on the first "Open" click.
I can not still figure out the dome light switch with "OFF" sign - to me it just toggles through two states (switch backlight ON/OFF), but does not do anything other than this.
Mine works the same way. At first I had no clue how it worked, Dealer and manual were no help, but through experimenting and reading this forum figured it out. Double click to open also unlocks all doors and turns on all dome lights. Also found if you open the Door less than a second after stealth open, the light comes on.
Sonicbluz is offline
Old 12-11-2012, 06:49 PM   #63
supernova1
Fan#: 107060
What I Drive: 2012 Ford Focus SEL HB Red Candy
Points 28, Level 1
Points: 28, Level: 1 Points: 28, Level: 1 Points: 28, Level: 1
Level Up 56% Completed
FF Reputation: 1 supernova1 Good Standing Member
My car dome light never lights up if I press key fob OPEN button two times (after the car sits for several hours closed (and it is in two-stage open mode)). The procedure I described in my original post is the only way I can turn the dome light ON.
supernova1 is offline
Old 12-12-2012, 11:38 AM   #64
waypastfast
waypastfast's Avatar
Fan#: 97059
What I Drive: 2013 Ford Focus SE
Points 121, Level 2
Points: 121, Level: 2 Points: 121, Level: 2 Points: 121, Level: 2
Level Up 43% Completed
FF Reputation: 1 waypastfast Good Standing Member
I just picked up my 2013 SE and its doing the same thing! I thought it was so strange the interior dome light had a mind of its own and only came on randomly! I am glad to see other people are having the same issue (well not really wish it wasn't an issue) but some of the tips people have mentioned I am going to try and see if it works! Some good information in this thread
waypastfast is offline
Old 01-22-2013, 01:34 PM   #65
motherfresh
Fan#: 102125
What I Drive: 2012 Sterling Gray Metallic Focus
FF Reputation: 1 motherfresh Good Standing Member
Anyone got this figured out yet? Tried some of the things on the post and it still does it. I am also having another problem... When I turn the car on my doors will unlock and then the lights in the car will stay on unless I open the door or turn off the car and start it again.
motherfresh is offline
Old 01-22-2013, 03:10 PM   #66
riparke
Fan#: 95781
What I Drive: 2012,red,se,hatch,manual,sport pkg
Points 419, Level 8
Points: 419, Level: 8 Points: 419, Level: 8 Points: 419, Level: 8
Level Up 38% Completed
FF Reputation: 1 riparke Good Standing Member
2012 SE hatchback, key fob set to open all doors with 1 press. Dome lights always come on. My problem is a third of the time they do not go off when engine starts. Have to drive around at night with lights on till they decide to shut off.
riparke is offline
Old 01-22-2013, 04:58 PM   #67
Ellellelle
Fan#: 106363
What I Drive: 2013 Focus hatchback
FF Reputation: 1 Ellellelle Good Standing Member
Im having the same issue. I sometimes use double tap to open all doors. It happens either way. It never seemed to be a problem when I first got it; now it always happens unless it's been recently driven. Frustrating when it's pitch black out. I will have to try some of the tricks mentioned here though. Is there a way to disable the stealth setting? I can't imagine I would ever need it.
Sent from my SPH-M950 using FF Mobile
Ellellelle is offline
Old 01-22-2013, 08:25 PM   #68
KosKo425
KosKo425's Avatar
Fan#: 105840
What I Drive: Beast Mode MK3
Points 276, Level 5
Points: 276, Level: 5 Points: 276, Level: 5 Points: 276, Level: 5
Level Up 52% Completed
FF Reputation: 1 KosKo425 Good Standing Member
so basically it seems that 50% of the time it works 50% of the time.
KosKo425 is offline
Old 01-25-2013, 01:39 PM   #69
FordService
FordService's Avatar
Points 3,379, Level 36
Points: 3,379, Level: 36 Points: 3,379, Level: 36 Points: 3,379, Level: 36
Level Up 20% Completed
Forum Activity 22%
Mine works the same way...
My car dome light never lights up if I press key fob OPEN button two times...
Originally Posted by motherfresh View Post
...Tried some of the things on the post and it still does it...
Originally Posted by riparke View Post
...My problem is a third of the time they do not go off when engine starts...
Originally Posted by Ellellelle View Post
Im having the same issue...
I’m sorry for not seeing these updates sooner, guys. I want to check in and offer my help by setting up a call from your regional customer service managers. So I can do this, please PM me with your full name, VIN, approximate mileage, best daytime phone number, and dealer name/state.
KosKo425,
That’s some “fuzzy math” you have there.
Seriously though, please let me know via PM if you’re running into the same thing and I’ll arrange for you to be contacted (please be sure to include the above details).
Originally Posted by waypastfast View Post
I just picked up my 2013 SE and its doing the same thing!...
I see you live north of the border, waypastfast. I recommend talking to one of the skilled agents with Ford Canada at 1-800-565-3673 so they can assist.
Cory
FordService is offline
Old 03-28-2013, 07:02 PM   #70
FocusFoxUS
FocusFoxUS's Avatar
Fan#: 111025
What I Drive: 2013 Oxford White SE HB
Points 92, Level 1
Points: 92, Level: 1 Points: 92, Level: 1 Points: 92, Level: 1
Level Up 84% Completed
FF Reputation: 1 FocusFoxUS Good Standing Member
Kudos to Supernova1 for figuring this out. You'd think it could be explained in the owner's manual easily enough. I was going crazy trying to figure out when and why it turned on or not.
FocusFoxUS is offline
