For Sale: Trunk and hatch LED conversion kits - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-16-2013, 01:12 PM   #1
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
What I Drive: 2009 Ice Blue 5 speed 4 door FoFo
Points 36,103, Level 100
Points: 36,103, Level: 100 Points: 36,103, Level: 100 Points: 36,103, Level: 100
FF Reputation: 7 VonKrause Good Standing Member
Are you looking for that extra little bit of flair? Or trying to get an even light source in your trunk so you aren't fumbling around with the terrible stock light? Then check this out, I make conversion kits that turn your stock bulb into a string of LEDs that throw light evenly across your entire trunk or hatch area. I use high intensity, wide beam LED bricks that are premeasured and prewired to fit into your focus' trunk or hatch. The entire kit is plug and play and the LEDs come with double sided tape for easy installation.
I normally keep red, blue, and white LEDs in stock and can normally get a kit made and shipped within 2 days after payment. I can also do kits in amber or green within a weeks time. If there is a specific color you are looking for I can setup custom colors with an additional cost depending on the color.
Visiting or passing through the Houston area and want to get some custom work done? Then let me know ahead of time and I can do many other LED projects from interior lighting to accent lighting outside.
Estimated time for installation:
2000-2011 Trunk kits: 10-15 min
Hatch kits 15-25 min
2012+ kits 20-30 min (Not plug and play)
Kits available for order
2000-2011 trunk kit $35
Zx3-Zx5 hatch kit $35
SVT custom 4 LED hatch kit $35
SVT 3 LED hatch kit $30
2012 trunk kit $35
Not plug and play Includes hardware to splice into stock bulb
2012 hatch kit $30/$35
$30 price is for no sub and two light mounts in hatch area
Ready to ship Amber trunk kit $20 free shipping!
All kits are Plug and Play with the exception of the 2012 trunk and hatch kits.
PM me for info or orders
Shipping
I am currently only taking paypal
I am located in Houston, TX
Ships through USPS
Will ship anywhere in US including Hawaii and Alaska
Cost $3.00
Pictures
White Trunk kit
Red Trunk kit
Blue Trunk kit
Blue Trunk kit
Blue Custom 4 Brick SVT hatch kit
White Custom 4 Brick SVT hatch kit
White Hatch kit
Red Hatch kit
Custom Work
Center console lighting
Front Grille accent lighting
Foot well lighting
I can also wire up multiple strands/colors and have it set to a wireless switch.
-VonKrause-
Get your trunk or hatch LED conversion kits here http://www.focusfanatics.com/forum/showthread.php?p=4542652#post4542652
"2nd Gen problems"
I've spent too long looking into the abyss. It's starting to look back.
SR #233
VonKrause is offline
    Quick reply to this message
Old 01-21-2013, 09:33 AM   #2
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
Little bump
"2nd Gen problems"
SR #233
Old 01-21-2013, 12:07 PM   #3
SVT513
Fan#: 93471
What I Drive: 2002 SB SVT #3729
FF Reputation: 1 SVT513 Good Standing Member
I have a 02 SVT and would love to do this to my hatch. Few questions though: what is the difference between the 3 and 4 LED sets? Do you have any side by sides of the 2? Where are they mounted? Finally, what is the power source for this?
Thank you!
SVT513 is offline
Old 01-21-2013, 01:38 PM   #4
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
I have yet to sell the 3 setup, but there are a couple setups we can do, one on the left side behind the sub and then two on the right side. OR all three on the right side.
They mount under the plastic moldings that are on either side, they mount using double sided tape on the back of the LED bricks.
The power source is the outlet for the stock bulb. There are a couple things you can do, I have the adapter that plugs right into the bulb socket so all you have to do is remove the bulb and insert the wire plug, or you can splice into the bulb wire and place an LED wedge into the socket for more light. Both ways are pretty simple and don't require adding or modifying much.
"2nd Gen problems"
SR #233
Old 01-22-2013, 01:31 AM   #5
SVT513
Fan#: 93471
Awesome thanks for the info!
So basically, I could share the little light/bulb that is in the my hatch by the sub? Can I see the wedge that you will be using?
SVT513 is offline
Old 01-22-2013, 12:45 PM   #6
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Points 12,403, Level 72
Points: 12,403, Level: 72 Points: 12,403, Level: 72 Points: 12,403, Level: 72
Level Up 89% Completed
Forum Activity 76%
Activity: 76% Activity: 76% Activity: 76%
FF Reputation: 10 SvviftSVT Great Standing Member
Justin... if you need help with a stock svt sub set up for pics, let me know.. since i modded mine to fit the 10"
Track build has begun.
slow and steady.. but its going
SvviftSVT is offline
Old 01-22-2013, 01:20 PM   #7
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
This is the plug (Without the wire in it) that plugs into the lamp socket
This is the splicing way that I like to use.
Might have to take you up on that, sometime this weekend perhaps. I also have to install my new flex pipe so if you want to make it a mini meet/install meet I would be game.
"2nd Gen problems"
SR #233
Old 01-22-2013, 01:30 PM   #8
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Forum Activity 76%
i can try. Amber is wanting my time. lol. but i will see what i can do.
Old 01-22-2013, 01:47 PM   #9
RonMaiden
RonMaiden's Avatar
Fan#: 99230
Points 4,169, Level 41
Points: 4,169, Level: 41 Points: 4,169, Level: 41 Points: 4,169, Level: 41
Level Up 10% Completed
What's involved with the 2102 versions? Simple splicing?
I am very interested with tax time coming and this mod will come right after I do the headlamp and tail bulbs.
'99 Toyota 4Runner Sport
'11 Subaru WRX STI Hatch
RonMaiden is offline
Old 01-22-2013, 01:53 PM   #10
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Forum Activity 76%
yeah it should be a simple splice into the hatch light.
