Ford's letter regarding the "PowerShift 6 Speed Operating Characteristics" - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-22-2013, 12:26 PM   #31
Scott02
Fan#: 108080
What I Drive: 2012 Ox White SEL DCT 5dr
FF Reputation: 1 Scott02 Good Standing Member
Originally Posted by paul21 View Post
Having worked in the industrial control industry, a lot of onlookers used to say fix it with software. Sometimes a kludge can be done, but it's really hard to fix broken actuators and leaky seals with a software update.
And as far as Ford not working on this, I've had 4 different versions of DCT software installed on my car so far (2011 factory, December 2011, 12B37, and a newer version when I took it in Jan 2013.) Somebody is doing something, I'm just not quite sure what it is. It still hasn't removed the oil from my clutches or fixed my squeaking actuator.
Currently working in the industrial controls industry, I 100% agree. The "mechanicals" always think it's my software's issue, when it's typically a valve sticking or something of the sort. Therefore, if it's a broken actuator or a leaky seal, then of course that cannot be fixed with program updates. Those parts need replaced by the dealer.
I personally (to my knowledge) do not have hardware problems. So, I only notice the software issues, which is what I was commenting about above.
Scott02 is offline
Old 01-22-2013, 12:27 PM   #32
cobie56
Fan#: 84403
Originally Posted by Scott02 View Post
I actually purchased this car because it had the DCT transmission. I had one in California for a rental and really liked the DCT. As a general comment, I think the DCT actually functions quite nicely considering it IS a manual transmission, and also for how new the concept is.
Being 100% realistic, 50% of the manual transmission drivers I've driven with, drive more jerky than this DCT. Seriously... Think about that one.
I actually feel the DCT up and down shifts quite smoothly, and was also pleasantly surprised on how well it takes off from a stop in 1st gear.
However, that said, there are certain situations where things can go awry. For instance, when driving slowly (just above creeping) up a decent slope, say from a stop light. The programming makes it upshift to 2nd gear WAY too early, and the car starts jerking and lunging.
Is this the transmissions fault? Nope.
Is this the drivers fault? Nope. (but in hindsight, he/she could just simply press the accelerator pedal a little bit more like he/she would have to do in a manual car, and the car wouldn't try to upshift into 2nd)
Is it the Transmission Controller's programming fault? Yes, I do think so.
In my opinion, the majority (if not all) of the "issues" that people have with the DCT, could be fixed in the software.
So to me, this leaves two questions...
Why is Ford Engineers not working like crazy on updated software?
Why is NO ONE ELSE working on better software?
~~~If I had more time, I'd be all over this.
In the VW world many manufacturers flash the DSG Trans Controller for better performance, firming shifts, moving shift points, making it all around "better", etc.
If there is something sketchy or quirky with a car (or anything for that matter) it only takes someone with enough drive to fix it.
REF your quote below... I solved that problem by leaving the tranny in S mode when creeping... that pretty much eliminated the problems you are describing.. good luck.
cobie56 is offline
Old 01-22-2013, 12:37 PM   #33
Scott02
Fan#: 108080
Oh, I do know that switching into S will drastically help the too quick upshift problem, but honestly, I do not think that the programming should be written in a manner that the operator needs to shift it into S, when he/she does not want to be in S mode.
Scott02 is offline
Old 01-23-2013, 05:06 AM   #34
flyboyike
Fan#: 98206
What I Drive: 2012 Race Red SE sedan
Points 335, Level 6
Points: 335, Level: 6 Points: 335, Level: 6 Points: 335, Level: 6
Level Up 70% Completed
Forum Activity 7%
FF Reputation: 3 flyboyike Good Standing Member
Originally Posted by roswelltop View Post
Dear Ford,
Regarding your letter acknowledging the grinding, whining, clicking, clunking and other sounds of metal on metal, it is only fair that copies of this letter be clearly posted on EVERY new Focus with the 6 speed Power Shift Transmission.
I would think that the letter should be affixed next to the manufacturer's "window sticker" so that every potential customer can make an informed decision.
In other words Ford, this is nothing more, nothing less, than drug manufacturers do in posting the possible adverse affects to those who use their drugs right their on the bottle. And in your television advertising, you can run a little banner right there at the bottom of the screen.
What? It might decrease sales? I say poppycock! Despite being told that drugs will make users bleed, choke, cough, wheeze, poop, pee uncontrollably, vomit, forget stuff....and on and on, it makes NO difference. Prescription drug use is at an all time high. Heck, you might even sell more cars.....
Yours very truly,
The Average Joe
You're probably right. After all, our is a society that carries cups of hot coffee in its crotch, burns itself with said coffee, then sues the provider of said coffee for excessive hotness.
flyboyike is offline
Old 06-03-2013, 01:46 AM   #35
1940150
Fan#: 89751
What I Drive: 2011, charcoal,se focus
FF Reputation: 1 1940150 Good Standing Member
Or, what would have been wrong with the focus tranny they had? My 2011 shifts as smooth as cream, I get from 35 to as much as 45 MPG. Why fix what ain't broke????
1940150 is offline
Old 06-03-2013, 01:52 AM   #36
Points 10,060, Level 67
Points: 10,060, Level: 67 Points: 10,060, Level: 67 Points: 10,060, Level: 67
Level Up 3% Completed
Forum Activity 22%
Because the 4F27E was broken. It's wasn't very smooth or efficient. It had four widely spaced ratios so unless you could keep it in 4th gear with the torque converter locked it got terrible fuel economy, it also tended to shift all over the place with the lightest change of throttle application.
I was not fond of the sloppy transmission behavior of the 2009 and 2011 models I'd driven.
The DCT I owned operated properly and was so much nicer to drive than any MKII automatic.
A 4 speed is less efficient than a 6 speed, the only car in the class still using the old gearbox technology is the Corolla, and although they still sell well it's well behind being the best in class.
I did however end up with an ST because that was what I really wanted in the first place.
suss6052 is online now
Old 07-22-2013, 03:41 AM   #37
njkphoto
Fan#: 117005
What I Drive: 2013 Black Ford Focus SE
FF Reputation: 1 njkphoto Good Standing Member
New Car Saturday--Noise
Hello to all
I just bought my first 2013 Ford Focus SE (and ford in general) this Saturday. Love the style and drive. I am originally from Europe so I always wanted a fairly small stylish car. Now..That was Saturday..Drove the car from the dealer home with windows up. Didn't hear anything. When got close to home and turned down window I heard a regular grinding noise, rattle, (I am horrible explaining noises in English) going very slow and between 1-2. This is not happening all the time. I am suspecting it's the regular noise but because its not really bad I was thinking mounts, something loose..etc..I read the Ford Letter here but still I am thinking to call the dealer tomorrow morning and bitch..The car has 450 min..got it with 177miles on cause the had to bring me a black. I would say you hear it 2 times out of 5 maybe? If this was the DCT should be doing it all the time? Ford says the clutch needs to brake in..so is that BS should I wait?
Sorry for hijacking the thread..I just dint want to make a new one for this issue.
Thanks in advance
njkphoto is offline
Old 07-22-2013, 09:16 AM   #38
joshuafail
joshuafail's Avatar
Fan#: 115261
What I Drive: 2013 Ingot Silver SE w/MFT
Points 466, Level 9
Points: 466, Level: 9 Points: 466, Level: 9 Points: 466, Level: 9
Level Up 32% Completed
FF Reputation: 9 joshuafail Good Standing Member
I would wait until at least 1,000 miles before taking it to the dealer. Green clutches take a while to break in, and like the letter says, it can take up to 1k miles. Mine made the same noises until around that time, and I now have 2,100 on the car with zero issues.
Give it a few hundred more miles and see what happens. My car is a 2013 and from what I've experienced, they've fixed a lot of the problems that affected the 2012's, so after your inital break-in period, you should be fine :)
joshuafail is offline
Old 07-22-2013, 09:46 AM   #39
mishka
mishka's Avatar
Fan#: 107408
Points 2,315, Level 29
Points: 2,315, Level: 29 Points: 2,315, Level: 29 Points: 2,315, Level: 29
Level Up 10% Completed
I have 12,000 miles. They replaced my clutches/seals around 4,000 miles. It's been great since then, but if I rev high in the lower gears 1,2, or 3, the higher it revs, once it gets passed like 4,000 RPM, I start to hear a high-pitched grind, but as soon as I shift up it squeels again but then goes away. Is that normal/anyone else experiencing this? I have the DCT. Basically I don't hear any noises unless I rev high. It's not a loud grind/squeel but sounds like metal on metal for sure.
I wanna install my Injected tune but am thinking to take it in and have it checked by the dealer first?
opinions? thanks.
mishka is offline
Old 07-22-2013, 09:58 AM   #40
dan50
Fan#: 91789
Points 3,035, Level 33
Points: 3,035, Level: 33 Points: 3,035, Level: 33 Points: 3,035, Level: 33
Level Up 90% Completed
opinions? thanks.
Sure doesn't sound normal to me...but who knows what the dealer will tell you.
Before you do your "injected tune", be aware that this could compromise your factory warranty. There's another thread about this topic, but the bottom line is that Ford and other manufacturers are aware that aftermarket tunes are available that can be "undone" by owners before bringing the car in for service, and they have developed ways to determine if the tunes have ever been done.
Naturally, if Ford has any reason to presume the tune contributed to an otherwise-warrantable claim, they will likely deny coverage.
dan50 is offline
