05 ST Dead, need suggestions/experiences - Focus Fanatics
Old 01-20-2013, 01:13 AM   #1
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
What I Drive: 2005 ZX4 ST
FF Reputation: 24 afraziaaaa Great Standing Member
Buy-Sell-Trade Rating: (10)
134k on my focus. Drove to the gym today (3 miles from my house) and died then came back to life 3 times on the way. When it died, the engine almost went out and the dash flickered like the battery had been unplugged and reconnected quickly. When I went to leave the gym I tried to start the car and there was one flicker. Now, the car will not respond at all when I turn the key. It does not crank, nor does the starter relay even click. I can not even turn any lights on interior or otherwise. It is as if there is no electrical system at all.
Some things I think might be causing the problem:
1. Ignition switch shorted/bad.
2. Alternator is dead.
3. Short somewhere else.
Any suggestions, experience or feedback is appreciated!
afraziaaaa is offline
Old 01-20-2013, 01:20 AM   #2
jetrinka
jetrinka's Avatar
Fan#: 45622
FF Reputation: 180 jetrinka Excellent Standing Memberjetrinka Excellent Standing Member
Check those battery connections first thing. Kinda just sounds like a bad/loose connection. Sometimes even just a little corrosion between the battery post and connector is all it takes.
Other than that, it sounds like the alternator is failing.
jetrinka is offline
Old 01-20-2013, 01:27 AM   #3
Black00ZX3
Fan#: 104714
FF Reputation: 3 Black00ZX3 Good Standing Member
Battery connection or bad battery would be something Id check first.
Black00ZX3 is offline
Old 01-20-2013, 08:58 AM   #4
Bad battery connection.
Bad negative connection.
Bad battery -old batteries that show 12v can be bad, will have voltage, but no current.
Bad alternator not charging battery or overcharging the battery by sending high voltage to it.
Old 01-20-2013, 09:55 AM   #5
mainest
mainest's Avatar
Fan#: 60163
FF Reputation: 7 mainest Good Standing Member
I had a similar experience with my '05 ST. Battery voltage was 12.5 v at both battery terminal, and at the battery cable ends. However, I discovered that the positive cable end was not tight enough on the battery terminal. I removed both cables, tightened each fitting with a wrench on each end of the screw clamp, then reattached them to the battery terminals. No issues since. Good luck.
mainest is online now
Old 01-20-2013, 10:05 AM   #6
05focusST91
05focusST91's Avatar
Fan#: 83640
Check the alternator too, make sure its charging over 14volts, your battery could have proper voltage with a low cold cranking amps so if u can get a battery tester it could help to check
Funtion>form.
FLOOR IT!
2005 focus ST (gone)
Still here!
05focusST91 is offline
Old 01-20-2013, 02:34 PM   #7
focusonthefocus19
Fan#: 104272
What I Drive: 2002 yellow focus zx3
FF Reputation: 1 focusonthefocus19 Good Standing Member
Same exact thing happened to be a while back. No lights came on, the car didn't even want to make a sound when I tried to start it. I jumped my car off, and it worked just perfect. Try jump starting your car, and let it run for a minute or to, and then try to start it again. When I jump started my car it ran just fine, but as soon as I turned it off, same thing happened.
The problem was loose battery connections. Even when it's just a little loose it will cause problems.
focusonthefocus19 is offline
Old 01-20-2013, 07:58 PM   #8
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
Thanks to all for the responses. I will check the battery connections.
I do have a voltmeter hooked up that shows the battery voltage while the car is running. Lately it has been dipping below the normal 14.5V to about 13 or even 12V while the car is running. That is why I suspect the alternator.
Old 01-20-2013, 09:50 PM   #9
jetrinka
jetrinka's Avatar
Fan#: 45622
12-13 is too low while the car is running. Should be high 13's or 14.
jetrinka is offline
