How-to: Shift cable replacement, adjustment. MTX75 2000-2002.5 - Ford Focus Forum, Ford Focus ST Forum
Old 01-19-2013, 10:11 PM   #1
gondorian
gondorian's Avatar
Fan#: 105695
Points 1,387, Level 20
Points: 1,387, Level: 20 Points: 1,387, Level: 20 Points: 1,387, Level: 20
Level Up 87% Completed
My shift cables were like this.
I had "fixed" the broken one with zip ties but the shifter felt horrible. So last weekend I replaced my shift cables. I saw some how-to threads but none for my specific setup with pictures. Here is mine. If you have a 2002.5-2007 check out whynothinkwhynot's thread here: http://www.focusfanatics.com/forum/showthread.php?t=304574
First off you need to gather all your tools and decide how you plan to go about the change. You could possibly do this without going underneath your car or jacking it up, but what I did involved jacking it up. If you are going the underneath route you need more tools.
Here is what I used.
A new shift cable (Part # 1S4Z-7E395-HA)
Phillips screwdriver
Torx screwdriver (t25 I think)
19mm socket and wrench (lug nuts)
10mm socket and a wrench
Two pairs of vice-grips
Wire cutters
Two flat head screwdrivers
A pry bar (1ft.)
A jack
A jackstand
Jack up your car, place a jackstand underneath and take off you wheel and inner fender. The inner fender has a torx screw underneath the rocker panel area right by the driver's door that is hard to see as well as some phillips screws.
Take the center console out. Mine was already out so I don't have pictures of this. To do this you need to unscrew the two screws in the cupholders and take off the armrest, which has a couple screws. It will then look like this
Then take out the black trim piece by removing the plastic fasteners (where the zip ties are in my car)
Then take out the air box by unhooking the tabs and unscrewing the screws. There is one screw on the passenger side and one on the driver side.
Passenger side. This one is not the easiest to see but it is there.
Driver's side. That other plastic fastener does need to come off but it could if you want.
To make things easier take away the air tube to the back seat. I had to bend mine to get it to come free from the seats so be careful if it is really cold out when you do this as it might break.
gondorian is offline
Old 01-19-2013, 10:11 PM   #2
gondorian
gondorian's Avatar
Fan#: 105695
Next cut away the carpet covering the shift cables. Make sure you cut wide enough to get to the bolts that hold in the shift cables.
Then you can remove the shifter cables from the shifter base
Pry them off the shift tower itself and then untwist the knobs holding them to the shifter base. Pull up after you have untwisted them enough.
Unbolt the two bolts holding down the rubber seal. Now it's time to get under the hood.
Remove your airbox and your fuse box. Mine just pop off when you pull on them. Supposedly not all of them are like this.
Then you need to pop off your old shift cables.
If you look in the picture you can see that the rubber bushing is still stuck on This isn't all that easy to get off. I cut off all the rubber with wire cutters. Then I used two screwdrivers to pry off the metal part which was still stuck on. I had to pry on both sides simultaneously or it wouldn't come off. It took me a while to figure this out. Then pry off the other cable end. I used a pry bar and it came right off.
Now comes the fun part. You can try to untwist the knobs holding on the cables with your hands, but unless they are super strong and super small at the same time it won't work. Attach the vise grips to the knobs and untwist them with the vice grips. You will need to twist them and unlock the jaws and twist again several times if you shift cables are like mine. Do the top cable with the black end on it first. The picture shows on the white cable what I did.
Your shift cables are now free!
You can now go in the car and start pulling them out. However, if they are like mine, they will get stuck on the exhaust shield, since there is a protective metal shield over them with lots of ridges on it. To get rid of this problem, go underneath and move the exhaust heat shield out of the way. You may need to drop the exhaust to do this. I did not have to because my exhaust support is broken. Your cables should now pull free.
Installation is mostly the reverse of removal, but you need to careful of some things. When you put the knobs into their support there is a little plastic ring in between. It helps keep the knobs from closing down on you while you are putting them in. It comes off after they are installed, so don't worry about that. You also need to make sure that the orange button protrudes from the shift cable end. In this picture the button in the white end is correct and the one in the black end isn't. If just the white one is protruding you may not have reverse, at least I didn't.
If you don't do this it will become disconnected like this
To adjust them follow S2's method listed here. It really helps to have another person when you are doing this. Then put everything back, unless you want to delete your armrest or something (I like no armrest). Now you are done Happy driving
Old 01-19-2013, 10:20 PM   #3
gondorian
gondorian's Avatar
Fan#: 105695
Mods. I wasn't sure if this should go in the general or Mk1 forum so if it is wrong please move it.
Old 01-20-2013, 09:37 AM   #4
Points 27,103, Level 97
Points: 27,103, Level: 97 Points: 27,103, Level: 97 Points: 27,103, Level: 97
Level Up 76% Completed
Nope, just fine where it is. We've moved it into the How-To Archive. If the Mk1 mod wants to put up a link to it in that forum, then I'm sure that's ok especially since this only applies to early Focis.
Old 01-24-2013, 01:57 PM   #5
Tom
FF Founder
Tom's Avatar
Fan#: 2
What I Drive: 2005 Saleen ZX3 SES Turbo
Points 84,815, Level 100
Points: 84,815, Level: 100 Points: 84,815, Level: 100 Points: 84,815, Level: 100
FF Reputation: 60 Tom Excellent Standing Member
Buy-Sell-Trade Rating: (7)
Added this to the how-to archive. If you want to email me your address and color preference I can send you out a couple of decals.
Tom is offline
Old 09-18-2013, 09:40 PM   #6
Justcantfocus1627
Fan#: 119061
What I Drive: 2002 custom green zx3
FF Reputation: 1 Justcantfocus1627 Good Standing Member
I was wondering if I could get more information on taking off the cable clamp I can't seem to get it off. It's sliding freely with the orange button pushed in but it won't come off the black part due to a little bump it's the white clamp
Justcantfocus1627 is offline
Old 05-25-2014, 04:40 PM   #7
FocusedDriver_02
Fan#: 165634
What I Drive: 2000 Red Ford Focus SE
FF Reputation: 1 FocusedDriver_02 Good Standing Member
Exclamation About adjusting the cables.
I was wondering if there is a video showing how to adjust my cables. I already installed them. And Both orange clips are showing. The Gearbox counterweight has plenty of space. But I still can barely shift it into reverse. and The fluid level is topped off. The only thing I believe is left is to just adjust them. But I'm confused by just reading it. The cables don't seem to have that much play to begin with. I would really appreciate if you could help me out.
FocusedDriver_02 is offline
Old 06-30-2014, 06:34 PM   #8
Cruizer
Fan#: 172481
What I Drive: 2002 Gray ZX3
FF Reputation: 1 Cruizer Good Standing Member
All I had to do was hit neutral and had someone hold the shifter dead center inside, then hit the orange buttons. I heard them move a little when I hit the buttons. The main thing is to be sure your in neutral. Not an expert, but if you can't hold centered on the shifter and stay in neutral, you may need to hold the button and move the shift linkage by hand.
I just wanted to tell the op thanks for the write up. Great job identifying all the hidden screws on the interior. Still lots of wiggling things around to get them moving on this job though. She's done now and shifting great. Now on to the lower ball joint, lol.
Cruizer is offline
