Complete Work Order that fixed my DCT problems in my 2012 - Page 9 - Focus Fanatics
Old 01-18-2013, 11:15 AM   #81
chief901
chief901's Avatar
Fan#: 86140
What I Drive: 2012 Platinum Titanium Hatch
FF Reputation: 1 chief901 Good Standing Member
Does that mean my car will give me trouble until I die?
EDIT: Was the binding causing the clutch to fail - or were they just having trouble getting it out?
Causing the clutch to overheat and fail. This failure was the cause of the shudder & slippage.
chief901 is offline
Old 01-18-2013, 11:42 AM   #82
PratoN
PratoN's Avatar
Fan#: 88058
FF Reputation: 10 PratoN Great Standing Member
Oh no!
The service rep (allegedly) said he told my dealer to check my bell housing through the starter to check for oil, but the dealer never actually told me if they did anything. He just said the transmission tech said "couldn't replicate" the problem.
So, I don't know if they even checked, but if I don't have oil - this could be my issue and also why the clutch slippage gets worse after extended driving if that bearing is binding and heating up!
2012 FF Ti HB Kona Blue, Built 5/24/2011, 401A + Ti Handling Package, Parking Technology Package, Winter Package, Moonroof, and MFT w/NAV at v3.6 91k miles and counting...
PratoN is online now
Old 01-18-2013, 11:53 AM   #83
chief901
chief901's Avatar
Fan#: 86140
Oh no!
Mine would heat up in as little as 10 highway miles, or numerous start/stop in heavy traffic. One time in the middle of Austin, Tx. on I-35 it totally slipped after a hard shudder start. I managed to finally get it rolling using the S-mode and 2nd gear. Heat was the major factor.
chief901 is offline
Old 01-18-2013, 12:22 PM   #84
PratoN
PratoN's Avatar
Fan#: 88058
The case was causing the input shaft bearing to bind, and was revised after June 2011, mine was built 4/28/2011. Yes the first clutch was fried, they replaced the clutch pack and actuators, and then they put in another clutch assembly when they replaced the transmission.
Right now it drives like new, and is in the adaptive learning mode. I need to put some miles on it to be totally satisfied.
Which transmission assembly did they put in your car? Looking on fordparts.com - they have revisions B through F! Of course, mine is a B. lol
If I eventually need to get a replacement, is the F revision compatible with my car? Because it doesn't say superseded and when I put in my VIN, it tells me to buy a "B" revision. I don't want the dealership to put in another faulty transmission if they didn't rework all of the B revision cases...
Old 01-18-2013, 01:53 PM   #85
chief901
chief901's Avatar
Fan#: 86140
The work order show it to be "D".
chief901 is offline
Old 01-18-2013, 02:03 PM   #86
PratoN
PratoN's Avatar
Fan#: 88058
Thank God it works with newer versions!
