Old 12-21-2012, 05:22 PM   #51
Malibooya
Quarter Tank Racer
Malibooya's Avatar
Fan#: 68054
What I Drive: 2003 Pitch Black ZX3
FF Reputation: 5 Malibooya Good Standing Member
Originally Posted by pyroinsa View Post
Doesn't have to be a 1.5 gen all Foci from 2003 - 2007 came with the color-matched hatch strip
Not true - mine is just like the OP's. Granted, my car is black so it's not that noticeable anyway.
Originally Posted by iminhell View Post
Summation: MK1, not for fat people.
Malibooya is offline
Old 01-15-2013, 05:48 PM   #52
seventystangfan
seventystangfan's Avatar
Fan#: 104922
What I Drive: 02 Frost Silver ZX3
FF Reputation: 1 seventystangfan Good Standing Member
Update-
I changed the valve cover gasket, I was getting a slight but smelly burning at stops and I could see some oil leaking. Also, after having Nite-Shade for awhile I finally applied it to my taillights. I still need to do the third brake light. Expect at least a few more things before FocusFest 2013, I will be doing everything in my power to make it.
2002 CD Silver ZX3 5-speed
Basketball goals=EVIL
Hatch Nation #wannabe
seventystangfan is offline
Old 01-15-2013, 06:32 PM   #53
stealthzx3
ɔıʇɐuɐɟ snɔoɟ
stealthzx3's Avatar
Fan#: 94260
What I Drive: 2001 Black ZX3
FF Reputation: 8 stealthzx3 Good Standing Member
Buy-Sell-Trade Rating: (20)
Wow that's dark! Looks good though
Focus Revolution
Focus Central
stealthzx3 is online now
Old 01-16-2013, 12:15 PM   #54
cdbertrand
cdbertrand's Avatar
Fan#: 97547
What I Drive: 00' Infra Red ZX3, gf's 08' SE
FF Reputation: 2 cdbertrand Good Standing Member
They look pretty bold, i like them man.
Rally Revolution #17
When you turn your car on, does it return the favor?
When in doubt.. Flatout. - Collin McRae
cdbertrand is offline
Old 01-16-2013, 12:32 PM   #55
seventystangfan
Fan#: 104922
Thanks! I only did "three" coats, but I may have done them a little thicker than usual. I'm loving the way it accents the silver of the car. I'll get a better picture up when I get some free time. Also I need to do the third brake cover, but I'm satisfied for now. It is too cold to do anything. I barely had the patience to put oil in one of my parents' cars yesterday.
Old 01-16-2013, 12:36 PM   #56
stealthzx3
ɔıʇɐuɐɟ snɔoɟ
stealthzx3's Avatar
Fan#: 94260
Just a heads up!- when you go to tint your third brake light, do not just spray niteshades on it! It will crack and look terrible. You need to spray down some gloss on it first, let it dry, then tint. Believe me, mine was bad before i sprayed gloss first lol
Focus Revolution
Focus Central
Old 01-16-2013, 04:09 PM   #57
seventystangfan
Fan#: 104922
Thank you very much! I totally would have done it without too. Will any urethane style work or what would you recommend?
Old 02-15-2013, 01:28 AM   #58
seventystangfan
Fan#: 104922
So, I had a crazy experience with my Focus the other day. It started bogging down when load was being put on the engine. There was a green liquid in the spark plug wells so my immediate thought was cracked head. Turned out to be degreaser from the car wash the other day. Vacuumed them or and changed the spark plugs just for good measure and is working great!
Side note: having some noticeable noise coming from the front passenger tire area. It's almost a knocking nose accompanied by a shake at highway speeds. Could it be an unbalanced wheel, bad alignment, warped rotor? How should I diagnose it?
Sent from my SCH-I605 using FF Mobile
Old 02-16-2013, 11:34 AM   #59
seventystangfan
Fan#: 104922
Any input on this? I've got what seems like a bad tie rod end. Would this cause a lot of vibration?
Old 02-18-2013, 02:11 AM   #60
seventystangfan
Fan#: 104922
New tie rod ends, still a noticeable intermittent vibration/borderline knock at mid to high speeds. Hopefully I'm getting an alignment tomorrow and I'll see if it is a suspension component. If not it seems the most likely explanation is a bad motor mount(s).
