2012 installing amP help - Page 2 - Focus Fanatics
Old 12-14-2012, 05:38 PM   #11
BLarson
BLarson's Avatar
Fan#: 58905
What I Drive: 2012 Ox White SE Sports Pack Hatch
Which wire did you guy splice into for the amp remote wire? Installing now and need advise fast. Thanks. Would the antenna power wire work(yellow/orange)?
BLarson is offline
Old 12-19-2012, 06:09 PM   #12
cleonjones
Fan#: 81265
What I Drive: 2008 Red SES
FF Reputation: 1 cleonjones Good Standing Member
You could go off a fuse for the remote wire from something that is only on when the car is on?
And I have only heard of people tapping into the rear speakers, if your amp comes with an adapter/converter thing that should be fine. Most LOC I have seen are mounted in the trunk?
cleonjones is offline
Old 12-20-2012, 04:44 AM   #13
eyeballeater
eyeballeater's Avatar
Fan#: 87226
What I Drive: 2012 Sedan SE with sport appearance
FF Reputation: 1 eyeballeater Good Standing Member
I used the remote antenna wire for my loc. Fuse would work too though.
LOC in the trunk would be easy if the new Focus would have speakers there. But seeing it doesnt, it would be more work installing it there and then running wires from your doors to the trunk for the LOC and then run wires back again to the door from the amp.
2012 SE Sedan Spec 201A, Sport appearance package and 17" wheels
eyeballeater is offline
Old 12-21-2012, 06:55 AM   #14
cleonjones
Fan#: 81265
Ah, I haven't had the chance to look at the new ones everyone I know has first gen.
Old 01-15-2013, 08:46 PM   #15
tt69camaro
Fan#: 108118
What I Drive: 2013 focus SE 5-speed
FF Reputation: 1 tt69camaro Good Standing Member
"I'm hooking up an amp to my 13' focus se hatch. I will be mounting (behind the rear seat) one amp and loc for subs only. What are the best speakers to use (front or rear) for the LOC? Do you have to wire in a fuse on the power antenna or is there one already there from the factory? I will be mounting (behind the rear seat) one amp and loc for subs only.
tt69camaro is offline
Old 02-16-2013, 05:24 PM   #16
jev425
Fan#: 97314
What I Drive: 2012, Sonic Blue, SE
FF Reputation: 1 jev425 Good Standing Member
X2
and can you tap into the power antenna wire for the remote turn on for the amp?
jev425 is offline
Old 02-17-2013, 07:08 AM   #17
tt69camaro
Fan#: 108118
I ended up using my front speakers for my LOC. I also used the Audio control LX2i and it uses the speaker wires to turn everything on so I didn't even need the power antenna wire. But you could use it if you bought something else. Mine sounds great and is definitely overkill.
Old 03-09-2013, 11:37 PM   #18
jev425
Fan#: 97314
alright got most everything installed now and fed the wires under the carpet but....i only have to tap into the wire by the shifter...how do u take off that "retension plug"....I dont want to break anything so I would rather ask
jev425 is offline
Old 03-06-2014, 12:34 PM   #19
h4ck3d
h4ck3d's Avatar
Fan#: 131929
What I Drive: 12' Focus Titanium 5dr Tuxedo Black
FF Reputation: 1 h4ck3d Good Standing Member
Originally Posted by jev425 View Post
X2
I am about to hook subs up into my car, the only issue I am running into is the remote wire to turn the amp on and off with the car. Does the power antenna wire act as a proper remote wire for me to accomplish this?
2014 Focus ST - Tuxedo Black - COBB Stage 1
h4ck3d is offline
Old 03-06-2014, 12:41 PM   #20
cleonjones
Fan#: 81265
I used a fuse for my radio I can't remember exactly which but I also put a switch in near my fuse panel to turn my amp on and off. I've had it in for a few years now and still working fine.
There may be a better solution but I like being able to turn it on and off as I want.
