Clearing Hazy Head Lamps, the DIY way. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-09-2013, 10:34 AM   #1
gsxrboy
Fan#: 103574
What I Drive: 2012 Black Focus Titanium
FF Reputation: 3 gsxrboy Good Standing Member
Original Post
http://www.detailedimage.com/Ask-a-P...s-on-a-budget/
If you drive an aging car with plastic head-lamp housing, then you’re likely to experience the dangers and unsightfulness of hazy head-lights. Faded, hazy, non-clear housings cause light to refract prior to exiting the plastic rather than shining true. Not only does this result in a car looking older and losing resale value; this can also be dangerous for the operator and all others on the road as the driver struggles to make out objects through the dim light output. Changing the bulbs out for newer “true white” ones, converting to an aftermarket HID set-up, or using your brights are only temporary solutions that don’t address the true problem. Many owners are reluctant to fix the issue because of the cost of power-tools usually needed for favorable results. While using a machine like the Porter Cable 7424XP can provide much better results and take much less time to do so, many people are looking for a cheaper solution.
The vehicle being used for this educational write-up had horribly hazed-over head-lamp housings that provided very little light at night.
To begin, the headlights (and car overall) needed to be cleaned to provide a good working surface that allowed for a true inspection of the plastic housing. If you’re not worried about swirls and slight paint defects, you can take your car to a local car wash. For those looking to keep their paint looking its best, the standard two-bucket method is preferred. No-rinse washing using products like Optimum No Rinse can be a great solution for those without access to a hose.
With a clean surface, we can see just how bad things look. This will also show us how well our results may truly come out.
Protect the painted edges of the body and body molding pieces around your head-lamp housings using painter’s tape.
Because we were going to be doing the work by hand, we needed to use a heavy-cut compound. In this case, Meguiar’s M105 Ultra-Cut Compound was paired with a normal foam applicator pad.
Spread a generous amount of the compound on the pad and work small sections at a time.
Working small sections at a time and adding more polish as needed, use the product in a circular “polishing” motion. Here we used painter’s tape to mask off a small area for comparison purposes.
Gently wipe of the polish residue with a microfiber towel and inspect the finish. Though this took over 20 minutes, the results say it all:
Ten-minutes after inspecting the first section, the final results for head-lamp housing number one look stunning. Though this one housing assembly took over 30 minutes to polish by hand, the cost savings for someone without a machine may definitely be worth it.
Hand polishing is slow going, tiring, and won’t yield as good results as using a machine, but you’ll only spend a fraction of the money. If you have any questions or tips to share, please do so in the comments section below.
2012 Focus Titanium Black Manual
http://www.fuelly.com/driver/gsxrboy/focus
gsxrboy is offline
Old 01-09-2013, 10:58 AM   #2
1sloho
12 years strong
1sloho's Avatar
Fan#: 111
What I Drive: '02 zx5
Points 14,515, Level 78
Points: 14,515, Level: 78 Points: 14,515, Level: 78 Points: 14,515, Level: 78
Level Up 17% Completed
FF Reputation: 17 1sloho Great Standing Member
also, suggest putting some kind of protectant over the headlights or, they will just haze back over. something like lamin-x or what i did, use 50/50 mix of spar urethane and mineral spirits and put several coats over the housing.
1sloho is online now
Old 01-09-2013, 11:37 AM   #3
sbc17
sbc17's Avatar
Fan#: 101047
What I Drive: 2003 Pitch Black SVT , '96 Sunfire
Points 2,715, Level 31
Points: 2,715, Level: 31 Points: 2,715, Level: 31 Points: 2,715, Level: 31
Level Up 77% Completed
FF Reputation: 2 sbc17 Good Standing Member
That is a great write up! I will have to do this to my car. They aren't terrible but I am sure it is easier to do when there is less damage.
My only question is, will doing this remove the "tint" from the SVT headlights? I dunno if that is a coating on the lens or if it is part of the plastic.
-sbc
\/ CURRENTLY BEING REVIVED
2003 SVT focus
Pitch Black
Blue Interior
Build number: 61 of 3985
sbc17 is offline
Old 01-10-2013, 08:39 PM   #4
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,615, Level 31
Points: 2,615, Level: 31 Points: 2,615, Level: 31 Points: 2,615, Level: 31
Level Up 10% Completed
If you start with a more aggressive abrasive, it goes a whole lot faster.
I wet sand starting with 1000 grit, then 1500, then 2000.....then a liquid or paste as shown in the pics above.
elsolo is offline
Old 01-14-2013, 08:03 AM   #5
cdbertrand
cdbertrand's Avatar
Fan#: 97547
What I Drive: 00' Infra Red ZX3, gf's 08' SE
Points 3,113, Level 34
Points: 3,113, Level: 34 Points: 3,113, Level: 34 Points: 3,113, Level: 34
Level Up 43% Completed
FF Reputation: 2 cdbertrand Good Standing Member
Definetly trying this soon. What exact product am I to coat the lens with after this step?
Rally Revolution #17
When you turn your car on, does it return the favor?
When in doubt.. Flatout. - Collin McRae
cdbertrand is offline
Old 01-28-2013, 10:05 PM   #6
nickstewartroc
Fan#: 93665
What I Drive: 2011 Blue Focus SE
Points 301, Level 6
Points: 301, Level: 6 Points: 301, Level: 6 Points: 301, Level: 6
Level Up 2% Completed
FF Reputation: 1 nickstewartroc Good Standing Member
If you don't have the cutting compound, you can try toothpaste! Just did it to my gf's Pt Cruiser, and damn, they look brand new! Just another input is all
-Nick
nickstewartroc is offline
Old 01-29-2013, 07:58 AM   #7
cdbertrand
cdbertrand's Avatar
Fan#: 97547
What kind exactly?
Old 01-29-2013, 08:00 AM   #8
nickstewartroc
Fan#: 93665
Points 301, Level 6
I just used some old tube I had, I think it was Crest or something
Old 01-29-2013, 08:06 AM   #9
cdbertrand
cdbertrand's Avatar
Fan#: 97547
Hmmm interesting. might have to hit up dollar general and get a tube haha.
Old 01-29-2013, 08:48 AM   #10
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 36,504, Level 100
Points: 36,504, Level: 100 Points: 36,504, Level: 100 Points: 36,504, Level: 100
FF Reputation: 34 tukaniSVT Great Standing Member
Ive done it that way as well. And It works wonders. Nice job.
Ray
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
