HID on third gen focus, WITH DRL - Focus Fanatics
Old 11-12-2012, 10:21 AM   #1
klotche
klotche's Avatar
Fan#: 91834
What I Drive: 2012, Oxford white, Focus
FF Reputation: 3 klotche Good Standing Member
I have realised that many people are still having problems when it's question of DRL + HID with the third generation focus model..
If you have any problem, I can send you a wire diagram showing how to connect all those things !
You'll need
- 1 Standard HID conversion kit 35 w, 12 volt, (bought from vvme.com)
- 1 universal relay harness (bought from vvme.com)
- 2 x resistor of 50 watts 6 Ohms
- couple of extra wires to be able to connect all this (some speaker wires can do just fine... but it isn't the best quality I recommand.. I did use wires from my old car trailer plug 16 gauge)
- Some dexterity to connect wires.. (quick connector or weld skills)
- Please don't forget that resistant gets very hot, put them on a metal surfacež away from other wires... (I have pictures of good positionning as well)
I have had this set-up for 1 year now, and everything works perfectly. I even added a switch in my wire system so that i can close my low beams, without getting any errors in my car...
Feel free to contact me, if you need assistance! I can send you PDF diagram via e-mail
klotche is offline
Old 01-13-2013, 12:56 PM   #2
twinbiker11
twinbiker11's Avatar
Fan#: 108461
What I Drive: 2013 white Focus se, sport package
FF Reputation: 1 twinbiker11 Good Standing Member
Just bought myself a 2013 focus se. looking at getting hid set up for my low beams. have any pictures how to install them?
twinbiker11 is offline
Old 01-14-2013, 07:21 AM   #3
klotche
klotche's Avatar
Fan#: 91834
If you could just PM me an email address, ill be able to send you a HID wire diagram I made, my set-up works perfectly ! installed this a year ago now !
klotche is offline
Old 01-21-2013, 06:07 PM   #4
ad1das
Fan#: 108623
What I Drive: 2013 Sterling Grey 4d
FF Reputation: 1 ad1das Good Standing Member
This is the first mod i did. If you dont have the relay harness, your display will actually tell you "headlight fault" and they wont work. I am running 35 watt ballasts, with 6k beams. let me go take some pics right now and post them.
2013 Focus SE Sedan
- Eibach Sportlines, K&N, MS3 RMM, HIDs, All L.E.D's
2013 Oxford White FX4 F-150
ad1das is offline
Old 01-21-2013, 08:55 PM   #5
klotche
klotche's Avatar
Fan#: 91834
actually, relay harness only allow you to avoid flickering, because mk3 focus receives 9 volt power on DRL..
the ressitor are the things that make you avoid the "dipped beam bulb" - the error
With those resistor in parallele, your computer thinks you have incandescent bulb of 55 watt (original) plugged to it.. relay harness alone isn't enough to imitate the incandescent bulb resistance
klotche is offline
Old 01-22-2013, 07:29 AM   #6
ad1das
Fan#: 108623
Thank you for correcting that. That is what i meant, i was just beyond tired. I had to tuck the resistors away because they get super hott, but they are all a part of that harness. I picked it up on ebay for 13 bucks, and it was the exact same one that my shop uses and sells for 85 :/
2013 Focus SE Sedan
ad1das is offline
Old 01-22-2013, 07:45 AM   #7
klotche
klotche's Avatar
Fan#: 91834
Haha no problem!
wow that's expensive ! 85 $ !!
I bought mine at addison, my local electric supply shop for 1,85$ ea. resistor :)
Have a nice day !
klotche is offline
Old 01-24-2013, 06:50 PM   #8
Brad52693
Fan#: 108986
What I Drive: 2012 Silver SEL
FF Reputation: 1 Brad52693 Good Standing Member
Where did you purchase your HID kit from?
Brad52693 is offline
Old 01-24-2013, 07:15 PM   #9
apaolucci
Fan#: 105905
What I Drive: 2013 sterling grey focus
FF Reputation: 1 apaolucci Good Standing Member
this is what im going to use for conversion ...
http://www.theretrofitsource.com/pro...roducts_id=227
apaolucci is offline
Old 01-25-2013, 06:30 PM   #10
Graeme S
Fan#: 101487
What I Drive: 2012 SBM Focus Titanium A/T
FF Reputation: 1 Graeme S Good Standing Member
I was just turned on to that by a friend of mine who did his retrofit a little while ago. I got in touch with Andrew, and am having a bit of back-and-forth with him discussing different options.
Canadian cars come standard with DRLs (law since '89) and usually it's the highbeams on reduced power. My car's in the shop at the moment 'cause I got rear-ended by an X5 two days ago, so I can't just walk out and check--is it the same for the Focus? If not, I may ask my buddy to see if he can rewire the fogs to just always be on whenever the car's running.
Graeme S is offline
