Help not sure what this is? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-11-2013, 01:01 PM   #1
derekmcinerney7
Fan#: 88432
What I Drive: 2002 Malibu Blue ZX3
FF Reputation: 1 derekmcinerney7 Good Standing Member
So just driving today everything was ok no indication of anything happening. Came to a stop, car idling fine, then as soon as i take off if im easy on the gas it will shift and run fine, but if i push down on the pedal inbetween flooring it and just driving easy it starts to shake and the car doesnt pick up any speed just gets louder like its trying but can't. Car starts and idles fine. Any idea what this could be?
derekmcinerney7 is offline
Old 01-11-2013, 01:44 PM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,642, Level 94
Points: 23,642, Level: 94 Points: 23,642, Level: 94 Points: 23,642, Level: 94
Level Up 30% Completed
Forum Activity 16%
sounds like a secondary miss... (ignition)
when was the last time you have checked or replaced your plugs and wires?
mikebontoft is online now
Old 01-11-2013, 02:07 PM   #3
derekmcinerney7
Fan#: 88432
I havent replaced or check them ive only had and driven the car a little over 4k miles now. Has 125k on it. No engine lights or anything are on in the car!
Old 01-12-2013, 05:19 AM   #4
Points 3,274, Level 35
Forum Activity 11%
If a radical change in power output and it seems to run fine down low but hits a solid wall and any more throttle just makes engine get louder with no increase in speed then look at cam timing belt, it may have just jumped a small amount. Mine did that, couldn't tell it until 35 mph where car stopped like with a rev limiter on it. One quick check may be yanking top belt cover and look at belt condition, mine had backside scraping and small cuts that indicated a pulley went south, locked and started dragging belt to derail it a couple teeth. Car idled perfect and seemed to rev normal when whacking the throttle.
amc49 is offline
Old 01-12-2013, 06:02 AM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,524, Level 100
Points: 138,524, Level: 100 Points: 138,524, Level: 100 Points: 138,524, Level: 100
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (11)
Could be the fuel pump, though that would have some other symptoms, such as it cutting out when flooring it or above 4k rpm, but if the t-belt has never been changed then it's time to change it also which can cause that too if it was out of time.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 01-13-2013, 11:00 AM   #6
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,408, Level 61
Points: 8,408, Level: 61 Points: 8,408, Level: 61 Points: 8,408, Level: 61
Level Up 86% Completed
Forum Activity 29%
I had a problem similar to that when my coil pack went out... check the wiring into the coil pack and may need to replace? I was 700 miles from home on vacation when this happened to me....
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
