Exterior brake lights stay on (right, center, and left) - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-04-2011, 11:58 AM   #11
Luis360
Luis360's Avatar
Fan#: 35708
What I Drive: 2002 Black ZX3
Points 1,781, Level 24
Points: 1,781, Level: 24 Points: 1,781, Level: 24 Points: 1,781, Level: 24
Level Up 81% Completed
FF Reputation: 1 Luis360 Good Standing Member
I had a similar problem. Changed the brake switch under the brake pedal and nothing. I fixed the problem by replacing all the bulbs on my third brake light. Its weird but it worked lol
Luis360 is offline
Old 08-25-2011, 07:23 PM   #12
bt0210
Fan#: 89217
What I Drive: 2002 white ZX5
FF Reputation: 1 bt0210 Good Standing Member
I got lucky with mine
I had the same problem. My brake lights stayed on when my car was out of park. My cruise control would not work either. All of my high mount brake light bulbs were burnt out. When I replaced the bulbs, the problem was solved. Call it luck, or whatever, but that was the problem. Because the brake lights were on, it was telling the cruise control that the brakes were engaged, therefore not allowing the cruise control to come on. Hope this helps.
bt0210 is offline
Old 10-13-2012, 02:20 PM   #13
DoctorDetroit
Fan#: 104822
What I Drive: 2003 Green ZX3
FF Reputation: 1 DoctorDetroit Good Standing Member
I just had this same problem as well. Brake lights on all the time when in anything other than Park, third brake light not working. Not sure about Cruise Control, but guessing it didn't work either. I checked the umbilical harness as described above, but everything seemed to be intact. So I simply replaced the bulbs in the third brake light as the last poster suggested and everything returned to working order. Seems absurd, but there you have it.
DoctorDetroit is offline
Old 01-12-2013, 05:15 PM   #14
muststang66
Fan#: 108430
What I Drive: 2002 Red Focus wagon
FF Reputation: 1 muststang66 Good Standing Member
To 2002focusSEwagon, Brake lights wiring problem.
Thank you for taking your time to post the photos of the focus wagon, i really appreciate it. i would have never isolated this.
muststang66 is offline
Old 01-12-2013, 05:17 PM   #15
muststang66
Fan#: 108430
To 2002focusSEwagon, Thank you for taking your time to post the photos of the focus wagon, i really appreciate it. i would have never isolated this.
Old 03-03-2013, 07:38 PM   #16
Racerbox77
Racerbox77's Avatar
Fan#: 91184
What I Drive: 1993 Mustang SVT Cobra
Points 889, Level 15
Points: 889, Level: 15 Points: 889, Level: 15 Points: 889, Level: 15
Level Up 89% Completed
FF Reputation: 2 Racerbox77 Good Standing Member
Many hours of scratching my head has been avoided because of FOCUSFANATICS.
Awesome.
2004 SVTF ZX5 Competition Orange 1 OF 51 Build #914
1993 Mustang Cobra 1 OF 4993 Run's 10's
Racerbox77 is offline
Old 03-06-2013, 04:04 PM   #17
200two-zx3
200two-zx3's Avatar
Fan#: 108491
What I Drive: 2002 blue zx3
FF Reputation: 2 200two-zx3 Good Standing Member
This site def saves time money and scratched out eyes lol well maybe not the eyes but yea u get the idea also why doesn't ford recall this issue???
Claim not, dynos prove all!
200two-zx3 is offline
Old 05-06-2013, 02:16 AM   #18
hooligan998
Fan#: 114354
What I Drive: 2003 Red ZX3
Points 11, Level 1
Points: 11, Level: 1 Points: 11, Level: 1 Points: 11, Level: 1
Level Up 21% Completed
FF Reputation: 1 hooligan998 Good Standing Member
I posted this up in the other brake light thread, but I'm having the same problem on my 03 ZX3. Brake lights work fine in Park, but if the selector is moved to any other position, the right and left brake lights stay on. I fixed the wiring harness, but that did not solve the problem. Still looking for answers.
I should note that I installed a LED 3rd brake light unit recently.
hooligan998 is offline
Old 05-06-2013, 11:58 AM   #19
dardack
Fan#: 114151
What I Drive: 2003 Red SE Wagon PZEV 2.3L engine
Points 701, Level 14
Points: 701, Level: 14 Points: 701, Level: 14 Points: 701, Level: 14
Level Up 1% Completed
FF Reputation: 3 dardack Good Standing Member
I just bought a used 03 focus wagon to replace a caravan. Was a 2.5hr drive to go test drive/pick up. Internet pictures can only tell you so much.
On way back stopped for gas, wife was like your brake lights stopped working. So stopped at auto zone down street, saw fuse blown, bought a 15, push brake, blown again. Threw a 30 in there, bam push brake, back wiper goes. So I knew it was a crossed wire. Just needed 30 in there to get home without a ticket out of state or something.
Get home, sure enough, think 9 wires in there, 2 big ones I assume are ground. All are either broken or stripped to the wire. The brake/wiper lines were melted together.
I cut it at the top where it comes out near light and on hatch before it goes up.
Soldered new wires that have more insulation, wrapped each solder point in electrical tape. and also gave it more slack to hopefully stop the cracking. Also, I didn't have 2 same gauge wires, so used 2 medium. So 11 wires go up and little bit more slack now.
It took maybe 30-45 mintues to solder/tape/put everything back together.
BTW TY to user for pictures on how to get the plastic thing out. i could only get the rubber back on like 50%, was thinking today of breaking it out and buying a new one. I could not get that plastic piece otu without thinking I was going to break it.
dardack is offline
Old 05-06-2013, 01:14 PM   #20
Elder
Points 13,338, Level 75
Points: 13,338, Level: 75 Points: 13,338, Level: 75 Points: 13,338, Level: 75
Level Up 22% Completed
dardack - good to hear you got yours fixed! I'm sure the wiring job was LOADS of fun.
hooligan998 - I've seen prev. notes that at least SOME LED replacements act like the blown bulb scenario mentioned in this thread, no appreciable "draw" from the LED's so it acts like the bulbs aren't there at all. Might be worth plugging in the old light to see what happens, the only LED's that seem to work for that application have a resistor in them to "mimic" a regular set of lights.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
Exterior brake lights stay on (right, center, and left) red2003 Ford Focus & General Car Chat 1 02-17-2008 01:09 PM
San Antonio Sasca Autox#2- February 24, 2008 @ The At&t Center zetecgt Fanatics: Texas 0 01-21-2008 08:38 PM
my car is left of center, How about yours? infocus1 General Technical Chat 29 07-24-2007 02:20 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
