Go Back   Focus Fanatics > Ford Focus Tech Discussions > SVT Performance (2002-2004)
Old 01-04-2013, 08:15 AM   #21
Missourileo
Captain Retard
Missourileo's Avatar
Fan#: 55980
What I Drive: 2002 Black SVT ZX3,93 SVT Lightning
FF Reputation: 20 Missourileo Great Standing Member
Buy-Sell-Trade Rating: (14)
The t-belt is an easy job for the mechanically inclined, not so easy for others. If you do take it to a shop(which I don't recommend), make sure it's one that has done this before, on an SVTF. Reason being, most shops screw this up. I have done 8 of these and know it takes about 3 hours, you should change the water pump as well as the serpentine belt and you DO NEED the timing tools. Forget about the white dot crap. The belt walks 6 teeth per revolution. I have the Ford workshop manual on this that gives you specific step by step pics and instructions, if you're interested. I can email it to you. Also, did you change your valve cover gasket before changing the T-stat housing? If not, that's the reason the O-ring goes bad in the housing. Oil leaks down the head and onto the housing, look for yourself.
"It's the Veteran who salutes the flag, serves beneath the flag, and whose coffin is draped by the flag."
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Missourileo is offline
Old 01-04-2013, 08:19 AM   #22
MustangCRZY302
MustangCRZY302's Avatar
Fan#: 72764
What I Drive: 2004 Sonic Blue SVT 3dr
FF Reputation: 8 MustangCRZY302 Good Standing Member
Yea I can see how it would leak down. My Valve Cover gasket is just fine though. Its not even seaping above the Tstat housing. I will be changing that gasket though when I do the timing belt.
2004 Sonic Blue SVT, 1,185 of 1,978, K&N Filter, Steeda Tri-Ax, Steeda Front Strut bar,Eibach Sway Bars, Fog-Light Mod, Yellow Fogs
1990 Mustang LX 5.0L, Project/race car Vortech'd, DSS Forged 331ci Stroker, 10psi
www.ajsracing.net
MustangCRZY302 is offline
Old 01-04-2013, 08:38 AM   #23
loc0gring0
loc0gring0's Avatar
Fan#: 85659
What I Drive: not enough spaces to list all
FF Reputation: 1 loc0gring0 Good Standing Member
Buy-Sell-Trade Rating: (16)
timing belts are a cake walk.. if you sit and read the ""book way"" it seems scary... you do not need timing tools or even have to take the valve cover off.. just make sure your mark everything correctly and you don't need tools or have to time anything.. ive done about 10 and knock them out in a few hours with a lunch break..
3 focus supercharged
1 turbo
20+ fsvt
04 saleen n2o weekend warrior
loc0gring0 is offline
Old 01-05-2013, 09:20 AM   #24
cmajaa
Fan#: 73417
What I Drive: 2003 ZTW zetec
FF Reputation: 1 cmajaa Good Standing Member
Do it with the alignment tools and exactly the way its explained by ford and you won't have any problems, I've done two cars so far and have never had any codes.
cmajaa is offline
Old 01-12-2013, 03:21 PM   #25
LD5050
LD5050's Avatar
Fan#: 94329
What I Drive: 04 SVTF
FF Reputation: 1 LD5050 Good Standing Member
I had a shop do my timing belt, and I provided them with the cam tool since it's cheap. After researching on here I also had the following preventative maintenance:
timing cover seal
valve cover gasket
VCT solenoid
water pump & gasket
I didn't want to deal with any of these known-issue parts giving me grief down the road, one fell swoop kinda thing.
I should have also done the cam and crank seals.
LD5050 is offline
