02fordsvt Build/Mod/Random Thread - Page 120 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-10-2013, 07:46 AM   #1191
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
What I Drive: 2002 SVT, 2001 SE (Rusty)
Points 57,502, Level 100
Points: 57,502, Level: 100 Points: 57,502, Level: 100 Points: 57,502, Level: 100
Forum Activity 18%
FF Reputation: 49 02fordsvt Great Standing Member
Buy-Sell-Trade Rating: (11)
First day off in about a week yesterday and here are the results.
Moonroof
PS window
DS Window
These three switches are mono color (only white). I didn't really want to string wires through the doors again to get two colors.
It's Bryan, not Brian
RSVT-170 Build in Progress
Derusting Rusty Build in Progress
02fordsvt is offline
Old 01-10-2013, 07:53 AM   #1192
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Points 12,410, Level 72
Points: 12,410, Level: 72 Points: 12,410, Level: 72 Points: 12,410, Level: 72
Level Up 90% Completed
Forum Activity 77%
Activity: 77% Activity: 77% Activity: 77%
FF Reputation: 10 SvviftSVT Great Standing Member
those look awesome Bryan!!!
Track build has begun.
slow and steady.. but its going
SvviftSVT is online now
Old 01-12-2013, 12:59 PM   #1193
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
Points 7,474, Level 57
Points: 7,474, Level: 57 Points: 7,474, Level: 57 Points: 7,474, Level: 57
Level Up 62% Completed
Forum Activity 41%
Activity: 41% Activity: 41% Activity: 41%
Buy-Sell-Trade Rating: (8)
Hey Bryan, since you've messed with leds for the front overhead light I had a question. I got a 3w festoon led to replace my regular one. Its nice and really bright. Problem is it has no built in resistor so there is a faint glow when the light is off(standby). If I flip the swtch from door to off it goes all the way off. So I need to add a resistor to the line. But there are 2 lines connecting to the switch. Do you know which one Iwould splice the resistor into? Thanks.
Team Focalize
Hatch Nation #9
"2 by 2 Hands of Blue."
Blue5ive is offline
Old 01-12-2013, 01:49 PM   #1194
stealthzx3
Enthusiast
stealthzx3's Avatar
Fan#: 94260
What I Drive: 2003 Black ZX3 SVT, 2001 Black ZX3
Points 11,387, Level 70
Points: 11,387, Level: 70 Points: 11,387, Level: 70 Points: 11,387, Level: 70
Level Up 35% Completed
FF Reputation: 10 stealthzx3 Great Standing Member
Buy-Sell-Trade Rating: (22)
Wow that looks amazing. There's no green film on the back of thise switches right? IIRC they just have green leds that you swap out?
Focus Revolution
2003 EAP SVT #2752
stealthzx3 is offline
Old 01-12-2013, 05:44 PM   #1195
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
Forum Activity 18%
Mine have the same glow but since I never have the switch on door (it always off unless I turn it on manually) I've just ignored it. I just assumed it was a bad ground somewhere in the door ajar system but you very well could be right.
The three wires that run into the dome light are a power wire (orange or yellow) and two grounds (both some kind of black). I never hooked up a resister so I don't know witch side of the light it needs to be on. I also don't remember which ground is the door ajar ground and which one is the normal ground but I can look at it if you need that information.
Sorry I couldn't be more of a help.
You would be correct. I ended up screwing up my moon roof switch so I'm in the process of trying to find another one. I've also given in and decided to put duel colored lighting in the switch because the white is just too bright at night. It may be a while before that happens though.
Old 01-12-2013, 06:04 PM   #1196
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
Forum Activity 41%
That's cool. I know it has to do with needing to add a resistor to eliminate the glow from what I've read a ling time ago. Guessing i might need to add it to the ajar ground? Or maybe the power supply? Guess at some point soon I will figure it out.
Team Focalize
Hatch Nation #9
Blue5ive is offline
Old 01-12-2013, 06:06 PM   #1197
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Points 11,527, Level 70
Level Up 70% Completed
Buy-Sell-Trade Rating: (48)
I have the same problem. But the light is really faint, so it doesn't bother me. After you turn the car off wait 15 min and the bulb will be all the way off.
LED's look really good Bryan!!!
Hatch Nation #8
katiekay is offline
Old 01-12-2013, 06:10 PM   #1198
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
Forum Activity 41%
I will try the 15 min or so thing to see if it does go out. And yeah it is very faint. Probably only drawing 1/2 watt or less in power.
Team Focalize
Hatch Nation #9
Blue5ive is offline
Old 01-16-2013, 07:48 AM   #1199
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
Forum Activity 18%
I had to take the door card off on the PS to run wires for the blue/white window switch lighting and decided to add a little blue to the speaker.
Wire running to the LED's
LED's wrapped around the stem of the speaker
The LED's reflect on the speaker which is a little disappointing but livable. You are able to see the speaker working now, however, which is pretty cool IMO.
Finished. I also did the map pocket a couple months ago but don't think I ever posted it in here. It simply a strip of blue LED's glued under the top lip of the pocket.
Old 01-16-2013, 07:52 AM   #1200
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
That looks awesome!
Hatch Nation #8
katiekay is offline
