Dogbone install issues need help ASAP - Page 2 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus First Generation > DURATEC Performance (2003-2007)
Old 01-10-2013, 01:21 PM   #11
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
Buy-Sell-Trade Rating: (13)
If I recall correctly, I put the bolt through the engine block side first then pushed the engine + mount back to get it lined up to the subframe. That poly is really stiff.
I have the same exact mount on my '07, I know it fits!!!!!
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
D23 Crew: #07
Jgrove998 is offline
Old 01-10-2013, 04:28 PM   #12
mashore81
Fan#: 105575
What I Drive: 03 Pitch Black Sedan PZEV
FF Reputation: 1 mashore81 Good Standing Member
Is that mount reversible? Could you have it backwards? Worst case return it and get inserts.
mashore81 is offline
Old 01-10-2013, 04:49 PM   #13
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
FF Reputation: 28 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Put your car on either jackstands or ramps. Take your jack with a block of wood on the lip and place that under your car. Raise the jack until it is supporting the motor. Loosen up the passenger side motor mount but don't take the bolts all the way out. This will give you a bit more of swaying motion in the motor. You may need someone to hold the engine while you place the dogbone mount into position. After you get the mount into position put the bolt in there and then tight the passenger mount back down.
zetecDon is offline
Old 01-10-2013, 04:50 PM   #14
Svt_kid
Svt_kid's Avatar
Fan#: 94202
What I Drive: 2004 Silver zx5 Svt
FF Reputation: 1 Svt_kid Good Standing Member
Have you tired to put the bolt that connects to the transmision first and then the one to the sub frame?
Svt_kid is offline
Old 01-10-2013, 06:12 PM   #15
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
FF Reputation: 21 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (14)
TKE your almost there. This is normal, especially if our other months are oem. Brute force that piece in there. If you have ratchet straps you could ratchet the trans towards the rear and jack it up. Everyone gave good advice on alternative solutions.
I now drive a Japanese Ford.
macdiesel is offline
Old 01-10-2013, 08:07 PM   #16
PSUrivie
PSUrivie's Avatar
Fan#: 67329
Buy-Sell-Trade Rating: (9)
What I did was remove the bracket from the tranny (3 bolts). I then installed the mount to the subframe and the wiggled the tranny bracket onto the front of the mount. You will need an offset wrench to tighten the bottom bolt on the tranny mount if you go this route.
150whp/135lbs-tq @ 13lbs.
PSUrivie is offline
Old 03-04-2013, 10:18 PM   #17
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
FF Reputation: 22 freemind Great Standing Member
Buy-Sell-Trade Rating: (20)
^This
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 03-05-2013, 03:05 PM   #18
Milton
Fan#: 89715
FF Reputation: 6 Milton Good Standing Member
I just finished doing a 2007 ATX, the replacement dog bone was an OEM. I had the front wheels on ramps and ran into the same issue. I used a jack and block of wood to align the holes. It'll work.
Milton is offline
Old 03-21-2013, 10:32 PM   #19
streetfocus
streetfocus's Avatar
Fan#: 5768
What I Drive: 2004 Black Focus SVT
FF Reputation: 2 streetfocus Good Standing Member
So what is the outcome? Is the mount better or the inserts? Opinions after install from those who have the D20?
05 ZX3: Steeda intake, 67mm TB, custom 2.5 Magnaflow exhaust, Tom's Tune.
New: 04 SVT : K&N panel filter, 3 performance motor mounts, Taylor wires, orp, 67mm TB, Tom's Tune.
streetfocus is offline
