Dogbone install issues need help ASAP - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-09-2013, 07:10 PM   #1
TKE_Quailman
FF God of South FL
TKE_Quailman's Avatar
Fan#: 44442
What I Drive: 07 Pitch Black ZX3
FF Reputation: 35 TKE_Quailman Great Standing Member
Hey i am midway install in the dark getting eaten by mosquitoes is FL and im installing a CFM ply dogbone mount and i have run into 2 issues 1) it looks like my tranny doesn't align with the body mount. 2)The CFM mount wont go into the tranny mount like if the poly urethane bushing is to large it gets 85% in and then gets stuck i dunno if i should grease it up and try and shove it in there.
Also i have a 2007 manual i am 100% i ordered the correct mount just checked my order with CFM
02 Black ZX5 R.I.P.
07 Black ZX3 Work in progress
Last of the Hatches #1
XBOX LIVE:TKE428
GIVE REP POINTS IF IM HELPFUL
TKE_Quailman is offline
Old 01-09-2013, 07:19 PM   #2
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,234, Level 41
Points: 4,234, Level: 41 Points: 4,234, Level: 41 Points: 4,234, Level: 41
Level Up 43% Completed
Buy-Sell-Trade Rating: (17)
Pry bar, wood block and hammar will be your friends with this install.
I now drive a Japanese Ford.
macdiesel is offline
Old 01-09-2013, 07:35 PM   #3
mashore81
Fan#: 105575
What I Drive: 03 Pitch Black Sedan PZEV
FF Reputation: 1 mashore81 Good Standing Member
I did a poly bushing swap by myself at night. when I needed that extra push I started the car up and rocked the engine. Probably not recommended but I had work in the morning. Good luck.
mashore81 is offline
Old 01-09-2013, 07:38 PM   #4
macdiesel
macdiesel's Avatar
Fan#: 31579
You don't need to start it up? Can also use a jack under the trans to help manipulate the position.
Old 01-09-2013, 09:04 PM   #5
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,893, Level 59
Points: 7,893, Level: 59 Points: 7,893, Level: 59 Points: 7,893, Level: 59
Level Up 72% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (15)
that's what I had to do. needed lots of help getting it lined back up. pita but worth it. just have to use force, be good to have some one else helping, wasn't easy with the car only on jack stands getting leverage
rambleon84 is offline
Old 01-09-2013, 09:07 PM   #6
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Forum Activity 50%
Buy-Sell-Trade Rating: (11)
Yup, I used a jack to help align it as well, though other times I didn't. Have you ever replaced your passenger side? I know mine was worn out and was letting the motor sit a lot lower than it should have.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 01-09-2013, 09:59 PM   #7
Svt_kid
Svt_kid's Avatar
Fan#: 94202
What I Drive: 2004 Silver zx5 Svt
Points 987, Level 16
Points: 987, Level: 16 Points: 987, Level: 16 Points: 987, Level: 16
Level Up 87% Completed
FF Reputation: 1 Svt_kid Good Standing Member
yea jack it up and manhandle it into place. Best part about these engines is when you take off the motor mounts everything shifts position.
Svt_kid is offline
Old 01-10-2013, 01:38 AM   #8
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,154, Level 74
Points: 13,154, Level: 74 Points: 13,154, Level: 74 Points: 13,154, Level: 74
Level Up 76% Completed
Forum Activity 37%
Buy-Sell-Trade Rating: (46)
Moved to "Duratec Performance".
zetecDon is online now
Old 01-10-2013, 11:54 AM   #9
TKE_Quailman
FF God of South FL
Fan#: 44442
Still not going in i am open to ideas and suggestions
tools used a jack and a crowbar so far and nothing
Also while down there i discovered my flex pipe was broken =(
02 Black ZX5 R.I.P.
XBOX LIVE:TKE428
Old 01-10-2013, 02:10 PM   #10
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Forum Activity 31%
Well my experience isnt going to help, I had the opposite problem. Those two points were too close and I had to push the engine away. Along with my floor jack and a block of wood under the tranny/engine to support/move the weight while trying to get it to line up
If you raise the car higher/lower, will that create a pivot and let gravity push those two points closer? (I'm trying to orientate myself to that picture, front of the car is to the right, correct?) Do you have any ratchet straps you can hook around the subframe and engine to pull those two points closer?
No idea if either of those are viable or dumb...just throwing out ideas. I'm getting the impression you are working on this yourself. Glad you stopped on it last night, sounded like it had be super frustrating (I know i had to sleep on mine after not getting it done the night i tried to install it.)
