Tire Question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-08-2013, 10:53 PM   #1
2002FordFocusZX3
2002FordFocusZX3's Avatar
Fan#: 102001
What I Drive: 2002 Black ZX3
FF Reputation: 1 2002FordFocusZX3 Good Standing Member
Tire Question
I have a 2002 ford focus zx3 with stock 15 inch rims and the stock size tires 195 60r 15 i did the aspect ratio on a couple tire sizes and i was wonder what the widest tire is that i could fit without rubbing or needing to roll my fenders i have stock suspension also i was thinking i could maybe fit 215 55R 15 tires without rubbing or little rubbing but i am not sure?
Ain't nothing but a peanut
2002FordFocusZX3 is offline
Old 01-09-2013, 05:46 AM   #2
dodgeguy
dodgeguy's Avatar
Fan#: 85952
What I Drive: 2014 White Focus ST2
Points 578, Level 11
Points: 578, Level: 11 Points: 578, Level: 11 Points: 578, Level: 11
Level Up 56% Completed
FF Reputation: 1 dodgeguy Good Standing Member
I put 205/55/16 on and they rub occasionally, and I am not lowered. Those 215's are pretty big, and I would expect rubbing.
K&N Air filter, uh - thats it, NO CAI, NO FSWerks, NO Exhaust, NO Coilovers, NO Tune, Nothing
dodgeguy is offline
Old 01-09-2013, 08:22 AM   #3
2002FordFocusZX3
Fan#: 102001
Yeah I was thinking they would rub
Old 01-09-2013, 08:28 AM   #4
2002FordFocusZX3
Fan#: 102001
But how do svt rims and tires fit they are 215s
Old 01-09-2013, 09:42 AM   #5
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,742, Level 58
Points: 7,742, Level: 58 Points: 7,742, Level: 58 Points: 7,742, Level: 58
Level Up 96% Completed
Forum Activity 21%
Buy-Sell-Trade Rating: (15)
I'm not sure you can even find a 215.55.15 tire anywhere (none on tirerack)
SVT wheels use a 17x7 rim where as most stock 15" wheels are 15x6, they will better accommodate that wider tire. offset will play a roll in that equation as well.
rambleon84 is offline
Old 01-09-2013, 03:59 PM   #6
2002FordFocusZX3
Fan#: 102001
my rims are 6.5 inches wide from the factory so i think that would help
Old 01-09-2013, 05:55 PM   #7
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,390, Level 61
Points: 8,390, Level: 61 Points: 8,390, Level: 61 Points: 8,390, Level: 61
Level Up 80% Completed
Forum Activity 33%
I have 225/50 R16's Bridgestone Potenza RE960 Pole Position and it is CLOSE. And they are a PITA to get the bead to lock when putting them on the stock rim, the shop had to use high pressure unregulated air to get the tires bead to lock. I do have an aftermarket suspension. The tire rubber is about 1/4 to 1/3" away from the strut/ spring assembly. At full lock I do not rub that I have been able to see. With my after market suspension and LCR Race camber plates I actually bottom out my suspension before the tire is able to rub.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 01-09-2013, 11:22 PM   #8
2002FordFocusZX3
Fan#: 102001
okay cool i think 215s will fit then and i am not worried about mounting them i can do it at my school on the tire machine with no problem because i just mounted some 315 30r 17s on my buddies mustang rims and i think that would be alot harder than the 215s with a bigger side wall
