Magnets in/on oil pan - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-08-2013, 04:41 PM   #1
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,620, Level 62
Points: 8,620, Level: 62 Points: 8,620, Level: 62 Points: 8,620, Level: 62
Level Up 57% Completed
Forum Activity 27%
So board at work and was thinking of something. A previous job I worked a lot with rare magnets and thought why not put something like this on or in the oil pan.
I know they make filter magnets that wrap around the filter and also magnetic drain plugs. Is all this just a bunch of snake oil? Any thing big enough would be filtered out in the oil pick up screen that could damage the motor and then any thing else would be filtered by the filter?
The magnets make sense, but do they work worth their cost?
I was thinking of doing some custom work...
I was going to drill out and epoxy in a long magnet in the drain plug to install a magnate like: http://www.kjmagnetics.com/proddetai...IA-N52&cat=168
Then I was thinking of getting something like this:
http://www.kjmagnetics.com/proddetai...8B-N52&cat=168
to put on the out side of the pan, bottom middle. This would be on, and then at oil changes I would remove so the participial would be removed during the oil change.
Worth doing any of this kind of thing. Seems like there are mixed thoughts on this. but overall it sounds like it wont hurt any thing.... but also may not be worth the money.
Thanks.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 01-08-2013, 05:58 PM   #2
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,621, Level 31
Points: 2,621, Level: 31 Points: 2,621, Level: 31 Points: 2,621, Level: 31
Level Up 14% Completed
The only magnets in a motor that help prevent problems, are ones some racers add to the top end oil drainback to grab onto large pieces of broken valvetrain before they fall down into the rotating assembly.
The magnet on the drain plug is more of a warning indicator than a preventative measure.
elsolo is offline
Old 01-08-2013, 06:12 PM   #3
mikeeshaq
Fan#: 72526
Points 626, Level 12
Level Up 52% Completed
Back in 1977 I made my own magnetic drain plug for my Honda Accord
Got a cylindrical magnet, measured the OD and used a numbered drill just slightly smaller than the magnet and then pressed the magnet in.
After that, where I use working , they had an industrial magnetizer, which I inserted the whole drain plug and zapped it a couple of times and I did this to two drain plugs
Whenever I had an oil change I gave them a clean drain plug and they gave me the dirty one. Each time there was small quantity of powdered iron/steel on the magnet.
mikeeshaq is offline
Old 01-08-2013, 06:17 PM   #4
Points 3,368, Level 36
Points: 3,368, Level: 36 Points: 3,368, Level: 36 Points: 3,368, Level: 36
Level Up 12% Completed
Forum Activity 49%
If using the stock smaller steel flat bottomed pan, then using a very thin magnet like the factory one used in older Tempo ATX pan after like 91-92 would work perfect I bet. Very thin and sticks like glue even with the differential thrashing the holy crap out of the oil above it. It would never move if properly placed in a zetec pan..........
amc49 is offline
Old 01-08-2013, 06:37 PM   #5
Fattie
Fan#: 46016
What I Drive: 6 Duratec Focus
Points 8,431, Level 61
Points: 8,431, Level: 61 Points: 8,431, Level: 61 Points: 8,431, Level: 61
Level Up 94% Completed
FF Reputation: 5 Fattie Good Standing Member
friggen MAGNATES , how do they work ?
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 01-08-2013, 06:41 PM   #6
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 27%
The disc magnet I have specified has a pull force of 54.5 lbs when on a steel plate. I think that an act of God would be required to rip that from an oil pan regardless of where I mount it.
The thought was to keep the magnet on the out side so I cull pull it from the pan when doing oil changes to remove the "captured" metal bits. These are Neodymium magnets at the highest strength possible so are not your refrigerator magnets...
if I have them on the inside I could only clean it when I pull the oil pan. and being that its not a easy 5 min task on our motors to do that the magnets would likely never get cleaned.
I am using the stock oil pan.
Edit: thank you for pointing out my spelling error. should have title and all posts updated.
Hatch Nation #42
Old 01-08-2013, 06:48 PM   #7
Fattie
Fan#: 46016
just bustin yer bALLS
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 01-08-2013, 06:51 PM   #8
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 27%
Well it drives me crazy when people spell stuff wrong. yes its the internet yes it a forum, but their is no reason why you cant take 1-2 extra minuets to form complete words ans sentences.
Well I think I will try some of this and get a few of these. My guess is that the distance from the oil pan to the crank shaft is enough that regardless of the strength and number of magnets used it wont through off the balance of the crank shaft due to the magnetic fields possible?
Hatch Nation #42
Old 01-08-2013, 07:00 PM   #9
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,234, Level 41
Points: 4,234, Level: 41 Points: 4,234, Level: 41 Points: 4,234, Level: 41
Level Up 43% Completed
Buy-Sell-Trade Rating: (17)
You could probably buy a magnetic drain plug? Personally, I wouldn't waste my time. If you really want to know the condition of your engine you could get an oil analysis.
I now drive a Japanese Ford.
macdiesel is offline
Old 01-08-2013, 07:09 PM   #10
Fattie
Fan#: 46016
minuets
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
