#12 | ||||
Best thing along with a general "tune up" I did for gas mileage is get an UltraGauge, google it give you instant feedback on miles per gallon, avg mpg and so much more!
#13 | ||||
I did plugs, wires, coil, air filter less than 5k miles ago...running castrol 5w30 full syn...i wanna delete the egr but dont want the check engine light
#14 | ||||
EGR should not impact your MPG in any way. Its an emission controlled device. Its to make your tail pipe emissions cleaner not reduce your MPG. When was the last time you checked tire pressure? Fuel filter? Possible partially clogged CAT? I know sometimes after sea foam in the intake or other aggressive quick intake cleaners could clog up the cat....
2001 ZX3 2.0L Zetec- Hatch Nation #42 Going through Rebuild See "The TICK Build Thread" for details (http://www.focusfanatics.com/forum/showthread.php?t=289168&referrerid=62897) |
#15 | ||||
#16 | ||||
have you checked the PCV hose or the PCV it self?
#17 | ||||
On my old '02 ZTS I was having a similar issue, where my MPG was steadily declining until it got as low as 21-23 MPG. My issue turned out to be my DPFE sensor (EGR pressure feedback).
I found an easy way to test it as well, simply go to your firewall and unplug the wiring pigtail from the DPFE sensor. If, after you unplug it, your MPG improves then you know it was the problem. >Here< is a photo showing the DPFE sensor near the brake fluid reservoir. After I unplugged mine, my MPG immediately went up to 25-27. Another recommendation, if you do find your DPFE sensor is bad, don't cheap out on the replacement. I bought a generic chinese cheap-o replacement on eBay and it was worse for my MPG than the OEM one that went bad. Go with a genuine Motorcraft part, it will be more expensive but its worth the difference. After replacing mine with a quality part my MPG returned to the normal 27-29 MPG.
2003 ZX5 SVT #1345 CD Silver; Red Interior; Audiophile; Moonroof; HID's |
#18 | ||||
Errant EGR CAN cost mileage if causing misfire by being on at wrong time or too much, the misfire wastes fuel.............
#19 | ||||
FF's Night Security
You can always try replacing the O2 sensor. Rockauto has the NTK for a very good price. It's the OEM manufacturer and looks just like the motorcraft at a fraction of the cost.
I started out with nothing and I still have most of it left Hatch Nation #15 (Ole' Yeller') & #150 (The SVT) Moderator for Technical Chat Zetec Performance Chat Southern Fanatics Chat |
#20 | ||||
