2012 Focus Metal shaving - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-07-2013, 09:52 PM   #1
zick2500
Fan#: 93140
What I Drive: 2012, Black, SE
FF Reputation: 1 zick2500 Good Standing Member
Anyone want to guess what this is from?
Found it on the dipstick and it's none magnetic. Looking down the dipstick tube I can see more and they look like curles of metal shavings. Unfortunately I can't get a good picture of the ones down the tube.
Only 13K miles.
zick2500 is offline
Old 01-07-2013, 10:11 PM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,770, Level 78
Points: 14,770, Level: 78 Points: 14,770, Level: 78 Points: 14,770, Level: 78
Level Up 80% Completed
Forum Activity 17%
Take it to the dealer tell them what you found (show them the bits) and get the oil changed. .
Insist they save the oil and show it to you.
It may be trivial.
(I say that because if the engine is running fine.. it may be something like a oil splash tray or some other non-important thing in the engine. Or a bit of flashing from the engine block casting got left down there..
Anyway, if it is running no problem i would not be too worried.
It may be some bit someone forgot in there, and it got busted up by the crankshaft spinning.
If it was a bearing you would already be sitting with a dead frozen engine..
There is nothing down in the crankcase that matters much from being banged by a small chunk of light metal bouncing around. really. (well maybe the oil pickup tube.. but i bet that is fine since your engine oil light has not gone on..)
So as i wrote. do not worry too much. Just take the car to the dealer..
The oil dipstick goes straight down to the crackcase..
Added:
The only thing i can think of that it might be (if it IS an engine part) is some sort of camshaft chain guide or damper. That could break, fall down into the bottom, and the crankshaft could break up...
Elizabeth is online now
Old 01-07-2013, 11:13 PM   #3
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
That's what warrantees are for.
Having newer owned a car with a warrantee, I would be cutting the oil filter can open to look for glitter.
elsolo is offline
Old 01-08-2013, 12:13 AM   #4
zick2500
Fan#: 93140
Yeah, gonna take it to the dealer tomorrow and see what happens.
2012 Ford Focus SE
zick2500 is offline
Old 01-08-2013, 10:37 AM   #5
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
New engine
If the dealer gives you any crap, then let us contact our Ford Customer Service representative and see what she can do for you. Chunks of metal in the oil are not normal. Those look like parts of a bearing to me, but you never really know until you remove stuff.
Old 01-08-2013, 10:49 AM   #6
AZfocus2012
AZfocus2012's Avatar
Fan#: 92484
That looks like the kind of stuff I have seen come out of every new car and motorcycle I have had. Usually after the first or second oil change it will be gone. That is why I am an advocate of the early oil change on new cars and motorcycles. How many oil changes have you had in 13K miles?
AZfocus2012 is offline
Old 01-08-2013, 12:36 PM   #7
mrdeath2000
Fan#: 91996
What I Drive: 2014 White SE 5spd
Points 1,331, Level 20
Points: 1,331, Level: 20 Points: 1,331, Level: 20 Points: 1,331, Level: 20
Level Up 31% Completed
FF Reputation: 3 mrdeath2000 Good Standing Member
I would try and extract enough of the oil to send off to one of the oil analysis labs (I think one is called blackrock ~$25).
That way if the dealer is blowing you off you can have it analyzed and they will tell you what the material is in there and you can figure out what's toast and maybe have more push on the dealer or Ford customer service.
2014 Focus SE Manual -
2006 Focus ZX4 SE Auto -commuter 110k /traded
mrdeath2000 is offline
Old 01-08-2013, 12:49 PM   #8
AZfocus2012
Fan#: 92484
Another thought is to change the oil yourself. Document it with pictures or video. You would want to let the oil stand in the drain pan for awhile, to let any suspended particulate to settle to the bottom. Photograph and save the stuff in the bottom of the pan, and like the previous poster suggested, send off a sample to Blackstone Labs for analysis.
http://www.blackstone-labs.com/
Old 01-08-2013, 02:03 PM   #9
FordService
FordService's Avatar
Points 3,482, Level 36
Points: 3,482, Level: 36 Points: 3,482, Level: 36 Points: 3,482, Level: 36
Level Up 88% Completed
Forum Activity 27%
Itís great youíre having the dealer check it out, zick2500; Iím sure theyíll take care of you.
Originally Posted by Elizabeth View Post
Take it to the dealer tell them what you found...
Originally Posted by elsolo View Post
That's what warrantees are for...
...then let us contact our Ford Customer Service representative...
Originally Posted by AZfocus2012 View Post
...That is why I am an advocate of the early oil change on new cars and motorcycles...
I love seeing the community help out; thanks, guys!
Cory
FordService is offline
Old 01-08-2013, 06:47 PM   #10
zick2500
Fan#: 93140
Just dropped it off at the dealer. The service writer (or whatever their title is and the service manager (I believe)) both don't seem to be concerned that much.
They pretty much think they'll find the metal shavings in the oil pan and cleaned it out and I'm good to go.
I made my concern about that stuff possible doing damage to the engine and/or that damage has already occurred but he just said they'll document it for future reference...
This is the 2nd oil change, the dealer did the 1st one and I was about to to do the next one until I saw this.
Oh and I forgot to mention that the oil filter had been leaking too. I never noticed because all the oil drips were being caught by the underbody panel which is some kind of cloth like material that the oil was absorbing into.
2012 Ford Focus SE
zick2500 is offline
